Thread: MSD 87 yj
    niagara falls
    Time Online: 1 Wk 5 Days 7 Hrs 32 Mins 53 Secs
    Avg. Time Online: 1 Min
    MSD 87 yj
    really easy to install and helps a lot with performance, plus you can pick your max rpm just by swapping out a chip, super easy.
    Attached Thumbnails Attached Thumbnails 0912097-1.jpg   0912097-2.jpg   0912097-6.jpg
    1987 yj, 44 front, 9" rear, ramsey winch, 38.5" Boggers
    360ci, BACK IN ACTION
    1996 Grand Cherokee Limited, STOCK .....BOOOOOOOOO
    I drove a 4x4 Commanche last year before and after an MSD was installed. The difference was very impressive. Idled smoother, pulled harder, and emissions had improved over the last Drive Clean test. That was a 92 4.0 that was swapped in.
    I'd tell ya not to rev past the factory redline, but it looks like everything factory left that engine bay long ago
    niagara falls
    does all of the above, very impressed.
    there tough units but generaly dont do well under the hood of a dayly driver.
    what kind of switching device are you using for the ign? eg: points,electronic conversion like pertronics.
    you want to see big gains on ign try one of these in there too.
    http://www.performancedistributors.com/amcdui.htm
    niagara falls
    that dui looks pretty cool, and it eliminates the coil.
    I'm using the stock magnetic pickup
    good call on the rubber mounting blocks.
    if you can find these anywhere there alot better and easy to mount but it takes a larger hole in the fender.
    good thing is there is no metal on metal contact and they never come loose
    rubber well nuts http://www.desmoparts.com/ducati/wellnut/wellnut.htm
    niagara falls
    those look a bit more sturdy
