View Poll Results: Do you like the slimmed down or do you like to see the chitter chatter?
Voters
15. You may not vote on this poll
  • Yeah short and sweet, let me ask the questions but clean it up now and again.
    13 86.67%
  • Put the chitter back up. I need to read it all.
    2 13.33%
Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: The Silverfish WJ build on a budget (lots of pics and tricks)
    So let's say you have a WJ cherokee and you want it bigger. Let's see how it's done. First you need to select a kit that will suit all your needs. I chose the ZONE 4" kit from Jim over at Rockspyder. It came with EVERYTHING for under a G-note. And pic 5 is one of our club stickers. I think the logo turned out killer. (yeah shameless SSO plug)
    Attached Thumbnails Attached Thumbnails 027.jpg   lift silverfish 001.jpg   lift silverfish 002.jpg   lift silverfish 003.jpg   lift silverfish 004.jpg
    First thing first the WJ is already 2" over stock from a BB and is running 245/75r16 tires (31's) Plus to solve the stock rear arm bushing problem I installed a set of BDS TJ front lowers in the rear with some home brew shims (big washers). Work MINT for less then the price of factory rear lowers. The pics below show the jeep on 29's. the ones in the previous post are the most recent.
    Attached Thumbnails Attached Thumbnails my new grand.jpeg   my new heep.jpeg   lift silverfish 005.jpg   lift silverfish 006.jpg
    Start by removing the stock shocks, trackbar, bumpstops, and disconnecting the swaybar links. Prep the new front arms by installing bushings, fittings, and spacers. Remember to support the axle.
    Attached Thumbnails Attached Thumbnails lift silverfish 008.jpg   lift silverfish 009.jpg   lift silverfish 010.jpg   lift silverfish 007.jpg   lift silverfish 011.jpg
    Install the bump stop extensions, new lower arms one at a time, then the new springs.
    Attached Thumbnails Attached Thumbnails lift silverfish 012.jpg   lift silverfish 013.jpg   lift silverfish 014.jpg   lift silverfish 015.jpg   lift silverfish 016.jpg
    Install the new shocks and seat the upper part of the spring. Prep the trackbar for installation. lower the vehicle after putting the wheels back on. Jounce the suspension and install the new track bar with the front axle centered. Due to the design of the WJ no new brake lines are required.
    Attached Thumbnails Attached Thumbnails lift silverfish 017.jpg   lift silverfish 018.jpg   lift silverfish 019.jpg   lift silverfish 020.jpg   lift silverfish 021.jpg
    Move on to the rear axle. Support the axle and remove the rear links, shocks, springs and undo the center link. Install the new rear springs then the center link spacer.
    Attached Thumbnails Attached Thumbnails lift silverfish 023.jpg   lift silverfish 025.jpg   lift silverfish 026.jpg   lift silverfish 024.jpg
    Install the rear shocks, and extended links. Lower and install the t-case drop. 1" to make the driveline not shake.
    Attached Thumbnails Attached Thumbnails lift silverfish 027.jpg   lift silverfish 028.jpg   lift silverfish 035.jpg   lift silverfish 036.jpg   lift silverfish 037.jpg
    Put her down stand back and have a look.
    Attached Thumbnails Attached Thumbnails lift silverfish 001.jpg   lift silverfish 029.jpg   lift silverfish 003.jpg   lift silverfish 030.jpg
    Either center your steering wheel or now would be a great time to get an alignment done.
    Attached Thumbnails Attached Thumbnails lift silverfish 033.jpg   lift silverfish 032.jpg   lift silverfish 031.jpg   lift silverfish 038.jpg
    First impressions: The ride is great and the lift has netted about 5" over stock. I'm sure it'll droop to the advertised 4" after it settles. The steering is still predictable without any twitchy attitude and there is no vibration while driving.
    PS anyone wanna buy a 2"BB or stock springs?
    Attached Thumbnails Attached Thumbnails lift silverfish 039.jpg   lift silverfish 040.jpg   lift silverfish 041.jpg
    So some silverfish updates.
    The front driveshaft is now a double cardan type. I got the shaft from a '95 ZJ and the yokes from Waggy on the board. (cherokee) The front yoke fit no problem the rear I had to machine 1/3 of an inch out of the inner spline to tension the bearings.
    Added recovery points. Just took pics of the front cause everyone knows what a trailer hitch looks like right?
    And made a filter for the throttle body.
    And a 3 month review for the zone kit. Thanks Jim for serving up one quality lift. The truck still rides perfectly. The front trac bar squeaked like a mo-fo so out came the drill and some grease fittings at either bushing and bippity bopity bam perfect again. In all I'm thrilled with the quality of the Zone 4". Tune back in in may for the offroad performance review.
    I found this really cool. This thread is linked form Zone Offroad.
    http://zoneoffroad.com/blog/?tag=zone-wj-lift
    If the folks at zone are reading, I could use some swag and swaybar discos!
    Moving on I wanted 15's. But I didn't want to break the bank so I went and found Chev 1500 / Caprice rims.
    They need to be blasted and sprayed (saturday night WOOT!) but they cost $50 for the set off Kijiji. They measure 15x7 with 5x127 bolt patern and a 4" backspace.
    Now to make a 15" fit a WJ is a weeeeee trick.
    Grinding. 1/8 of an inch off the calipers. There's a stupid amount of meat tho so no safety issues. I got 1/8 inch spacers just to make sure the caliper face wont rub the welds in the rim.
    Attached Thumbnails Attached Thumbnails 007.jpg   006.jpg   010.jpg   011.jpg   003.jpg
    Plastic is for sandwich baggies and toy cars. The rot collectors had to go..... So they did.
    Plus a couple rim and offset pics.
    Attached Thumbnails Attached Thumbnails 012.jpg   004.jpg   005.jpg   009.jpg   001.jpg
    Trimmed for tires. The first pic is not trimmed for reference.
    Attached Thumbnails Attached Thumbnails 009.jpg   003.jpg   002.jpg   001.jpg   004.jpg
    Rims are blasted and painted. Not bad for a $50 set. Plus the tires showed up.
