Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: emissions
  1. #21
    Jul 2006
    Guelph
    Bitchy
    Time Online: 1 Wk 3 Days 14 Hrs 31 Mins 10 Secs
    Avg. Time Online: 52 Secs
    Hey Bryn, Not sure where you are located but give Shaine a call at ToyWorks 519-938-9844 he is in Orangeville he is a 22re Specialist. He will get you better milliage and more power and if you havent passed allready help with that too.
  2. #22
    Bowmanville
    Time Online: 1 Wk 4 Days 11 Hrs 41 Mins 10 Secs
    [QUOTE=Noltz;1060563]The dilution is the ambient dilution, not the air/fuel mix. It's a compensation number factored in by the OTU. If the number is really high, it indicates there's a small leak in the exhaust system and ambient air is being drawn in.
    I did not say the dilution was an air/ fuel ratio. I said the number should be higher such as an A/F number. I Understand the number dictates a dilute of the emitted exhaust .
    Explained... Receive the entire flow of vehicle exhaust;
    – Dilute the exhaust with filtered ambient air;
    – Continuously extract and collect a proportional sample of the
    dilute exhaust; and
    – Accurately meter the total volume of dilute exhaust
  3. #23
    st catharines
    Time Online: 4 Days 8 Hrs 24 Mins 22 Secs
    Avg. Time Online: 21 Secs
    Are my reading skills correct in assuming this car is an '88? I thought cars over the 20 year mark are exempt from the e-test.
  4. #24
    binbrook ont.
    Time Online: 3 Days 21 Hrs 13 Mins 36 Secs
    Avg. Time Online: 19 Secs
    yeah 88 it sucks. last year i bought it so they said this is it last time. then they change it again. so mabey next time ime done. the cat might be a problem my muffler blew up under water one time. plus ive had it deep in water a {few} times. probably plugged up with gopher dunes sand. if the law includes the 88 the next time around ille buy older.
    Bryn; 86 chev k5 blazer
  5. #25
    binbrook ont.
    so you know. ime going to replace the cat ,i found one at a&a {woodward} for 60.00. cats have a rule that states even if required the replacement of the cat will not go towards the 450.00 conditional pass.so ille replace it myself.then test it. ille keep you posted!!! thanks for all your advice. Bryn
  6. #26
    Sep 2009
    oakville
    Time Online: 5 Days 12 Hrs 40 Mins 55 Secs
    Avg. Time Online: 27 Secs
    i don't know where you heard that law but it is not true. if it is an emission related component than it qualifies for the RCL but only if an accredited repair facility diagnoses and replaces it. if you have anymore questions you can pm me i'll be happy to help you with any answers you need.
    Jeff
  7. #27
    binbrook ont.
    whell i finally had time to pick up a cat {69.95} at a&a. cut the old one off then welded the new one on ille try to test it asap.
  8. #28
    Oct 2003
    London, Ontario
    Time Online: 1 Mth 2 Wks 3 Days 15 Hrs 42 Mins 42 Secs
    Avg. Time Online: 3 Mins 55 Secs
    if you passed the 40km test, make sure you have correct tires with correct pressure! underinflation messes up your test. I would do the seafoam with oil change anyways on an old car.
    My personal favorite is running water in the intake through a vacuum line, steam cleans all the combustion cghamber, 02 sensor and your cats if they are starting to clog. High idle and 5L of water ought o do it, make sure your engine is hot when you do it. dont let it suck too much at a, lilttle bit-little bit
    Want to see the future, past or the unknown? Learn to be psychic. Ask me how!
    A good time to invest in spf3000 if you live on the NK penninsula.
    Oh November 17, how I fear thee...
  9. #29
    binbrook ont.
    they dont do the 40k static only. 4x4 thing i guess.explain the seafoam ive barely heard of it.
  10. #30
    Seafoam is a cleaner that can be purchased from parts supply stores. It's almost kerosene with detergents... It's really good at decoking engines and breaking up carbon deposits. You can put it in your crankcase oil for a through flush, or burn it slowly through a vacuum line while the engines running to clean up the intake plenum and valves. You can pour it into the cylinders through the plug holes to free up sticky rings too. Basically if you've got an engine that burns oil at all, this stuff will clean any residue up and make the engine perform like it was just put together.
  11. #31
    binbrook ont.
    how often would you use it? and when do you know your engine is a good candidate for it?
  12. #32
    Jan 2010
    barrie
    Time Online: 3 Wks 6 Days 8 Hrs 12 Mins 45 Secs
    Avg. Time Online: 2 Mins 15 Secs
    Dude
    forget the sea form!
    just run some water into the intake as i said it post 3 or 4 and as bandit just said!!!!
    and i dont know who the hell told you that if it needs a cat it doesn not apply for the conditional but they are full of shit!
  13. #33
    Gof, make sure you tell them all the information they need dude! Not to say Bryn would dump water into his crankcase, but sometimes folks read these threads and go "oh, ya that's my problem too".
    Water is a INTAKE ONLY solution to decarboning your engine. You only use Seafoam when you have a carbon deposit issue internally, such as a neglected engine that has crud built up inside. Or if you've got a engine with a lot of blowby and it's burning a bit of oil. Water will literally steam clean the inside of the cylinder walls, as well as wash down a lot of the deposits in the intake manifold. You can do that once a year or so... doing it any more is a waste of time. But GOF is right about the cat issue - it's absolutely part of the repair cost limit.
    How'd you do with the universal cat?
  14. #34
    Jan 2010
    barrie
    i told him in post 3 how to do it correctly and the guy above my post also told him how to do it
  15. #35
    Ah, sorry! Didn't re-read the whole thread and forgot!!
  16. #36
    binbrook ont.
    the cat went in great my little mig works great . i might even have time friday to go get it e checked. ille let you know how it went .it even sounds better !
  17. #37
    binbrook ont.
    IT PASSED. i changed the oil re&re d a cat. drove the crap out of it . heres the results. hc before 121 now 24 at idle before 175 now5co before .33 and .93 now 0.0 on both.thanks guys for your help.i just didn,t want to do a list of things i didn,t need to do.
  18. #38
    Tired cat. Glad it passed.
