Thread: 33 inche tires ....15x10 or 15x8 ?
    Thunder Bay
    Time Online: 16 Hrs 52 Mins 38 Secs
    Planning on runnin 33's on the Tj this summer.
    Curious if anyone has pics showing the difference between these 2 wheel sizes.(15x8 and 15x10)
    Thanx
    Wrong forum but:
    How wide of a tire? For looks I like a wider rim, for bead pressure I like narrower.
    Brampton
    Time Online: 3 Wks 3 Days 8 Hrs 17 Mins 55 Secs
    Avg. Time Online: 2 Mins
    10s you can go with the 8 12s you gotta go with 10 or the rub I have 10os with my 33 12s
    Lanark, ON
    Time Online: 4 Wks 1 Day 21 Hrs 14 Mins 14 Secs
    33 12.5 15 min is 8" looks good, im going to be running 33 13.5 on 10s
    barrie
    Time Online: 3 Wks 6 Days 8 Hrs 12 Mins 45 Secs
    Avg. Time Online: 2 Mins 15 Secs
    iran/run 33x12.5 on 8 inch rims. makes it harder to know off the bead and looks nice
    Williamstown Ontario
    Time Online: 2 Days 10 Hrs 12 Mins 8 Secs
    Avg. Time Online: 12 Secs
    go 8's. all you need.....theyre cheaper than 10's too i think, but that's just an quasi -educated guess...
    -Marco
    98 TJ SE Apex
    2010 JKU-S
    M i k e oOI I I I I I IOo N o v e m b e r
    The infantry is challenging. Both mentally, and physically. To do this kind of work you must appreciate being mentally and physically challenged.
    12/04/2010 - Black 2010 JKU-S Order Placed
    21/04/2010 - VN Created
    04/04/2010 - Build Sched, Rail # assg
    15/05/2010 - Recd - 17km ODO
    Dec 2006
    Time Online: 1 Wk 2 Days 14 Hrs 42 Mins 56 Secs
    Avg. Time Online: 47 Secs
    Quote Originally Posted by dan379 View Post
    Theres no way of knowing if its gonna rub or not unless you know what lift he's got, what axles, what offset the rim is etc. etc.
    You can put a 33x12.50x15 tire on a 15x10 rim on that truck with no rubbing with the right setup.
    You need to provide more information if you want an accurate response.
    Thunder Bay
    Oops, sorry next time ill put in the right column.
    As for specs its a 2000 TJ with dana 30 and dana 35 axles. The lift kit sitting on my kitchen floor that will eventually be installed will be a rough country 4 inche.
    Planning on 33x 12.5 x 15 tires.
    Thanx
    GTA
    Time Online: 1 Day 14 Hrs 6 Mins 23 Secs
    I have a 4" lift with 33x12.5 tires on 15x10 " rims 5 ON 4.5
    Ok so let me start by saying I placed 4th on the RTI wramp at the BAJA Jeep meet with this setup! I am also running bushwaker flaires and the wheels still stick out a bit ( NICE LOOK)
    wHEELING WELL NEVER TOOK IT OUT YET ,HAWEVER WHEN AIRING DOWN YOU MIGHT BE GIVING UP A COUPLE OF POUNDS, not the bigges deal..I think!
    TURTLECON WINS THE RACE!!!!!!
    If you're wheelin it get 8's, if it's a mall crawler get 10's
    Edit - just realized this is an oldass post. Thanks goggles. Who got first?
