Results 1 to 12 of 12
Thread: P Code Help/Fix
    UXXXBRIDGE
    Time Online: 4 Days 6 Hrs 25 Mins 7 Secs
    Avg. Time Online: 21 Secs
    P Code Help/Fix
    Hey,
    The wife 02 TJ is throwing 2 codes.
    1) PO455 Evaporative Emissions System Leak Detected (small leak)
    2) PO422 Evaporative Emissions System Leak Detected (Gross Leak/no flow)
    My questions are
    Is that the GAS cap Code...think I'll take it off and on
    Can I drive it for a day like this
    If an easy fix what do i fix?
    Brian
    I'm not easily distracted. I...hey look, rocks!
    08 JK Rubicon
    CO4X4 Member
    OF4WD-5687
    Campbellville
    Do the gas cap up tighter, then reset the CEL.
    I bet that's it.
    UXXXBRIDGE
    Hmm, just removed the gas cap and re tighten...code wont clear says Failed and enging light still on lol
    barrie
    Time Online: 3 Wks 6 Days 8 Hrs 12 Mins 45 Secs
    Avg. Time Online: 2 Mins 15 Secs
    it is safe to drive
    no damaged will be caused
    barrie
    there are several this that can cause a small and large evap leak
    would try gas cap first,
    code wont clean by itself
    the jeep will run a evap check only under proper conditions, ie fuel level at a certain level, when temp is at a certain tem ect ect ect
    UXXXBRIDGE
    Thanks Guys.
    I suppose I'll have a quick look around and if its nothing obvious see my Mechanic buddy on Friday
    It'll take about 25 days (40 run cycles) for the evap code to clear.
    Time Online: 4 Mths 1 Wk 11 Hrs 29 Mins 36 Secs
    Avg. Time Online: 10 Mins 30 Secs
    Code Clearing
    Or start your jeep and turn it off a bunch of times (40)
    and clear it in a day or two...
    Billy
    Brampton Ont
    Fine
    Time Online: 2 Days 13 Hrs 27 Mins 52 Secs
    Avg. Time Online: 12 Secs
    Disconect the negative lead on your batery for an hour and the code will clear. I had the same problem when I didn't tighten the gas cap after fueling once.
    Hummer Stuck? Call 1-800-GET(a)JEEP!!
    Billy, it won't clear that way. It needs 40 drive cycles. Engine must start cold, warm up so many degrees, be driven above 25mph for so many miles, fuel temperature be at a certain point... etc. Just cycling the key won't do it.
    Kojack, I believe you're correct.
    barrie
    disconnect the neg battery cable and push the brake pedal to make sure you empty all the capasiters. that will clear it
    UXXXBRIDGE
    Thanks Guys,
    It cleared it's self by Monday just by normal Driving I suppose.
    Advise appreciated. I Call in for a price on an OEM gas cap it was 40.00 The CT one was 9
