Your cart is empty
+ Reply to Thread
Results 1 to 12 of 12
Thread: jeep wont start sounds like no compresion
  1. Join Date
    Dec 2009
    chatsworth
    Gameroom Cash
    $515
    Time Online: 22 Hrs 27 Mins 50 Secs
    ok well i have a 95 jeep grand cherokee with the 5.2L v8, i boght it about a month ago it needed a water pump so i drove it home kept the coolent toped up, a few days later got the time to take the old water pump off and went to car quest and got them to order me a new one in , few days later got it and instaled it got every thing back together and went to start it but it wouldnt , sooooo i got my mechanic to stop by and take a listen and he said it sounds like there is no compresion!...... so before i went and did the timeing chain like he suggested i asked a buddie that is very mechanily inclined and he said to smell the oil on the dip stick and see if it smells like gas so i did, and low and behold it is thiner then it should be and smells like gas! now my question is, would gas in the oil make this jeep not wanna start? can any one help me figure this out before i do the chain! thanks
  2. Join Date
    selkirk ont
    Gameroom Cash
    $10205
    Time Online: 1 Mth 1 Wk 3 Days 12 Hrs 56 Mins 18 Secs
    gas will wash the oil off of the cylinder walls. without that oil you will not have enough compression for your engine to run
    WHAT WOULD MACGYVER DO?
    84 cj7, 4.0 ho conversion, 2.5" lift, 33" trail diggers, front and rear lockers, 8500 lb superwinch, cobra 29 cb
    VA3 HWG
    OF4WD #5571
  3. Join Date
    Dec 2009
    chatsworth
    Gameroom Cash
    $515
    ok thanks for the quick reply, so do you think a oil change will help at all?
  4. Join Date
    selkirk ont
    Gameroom Cash
    $10205
    definitely change the oil.
    VA3 HWG
    OF4WD #5571
  5. Join Date
    Dec 2009
    chatsworth
    Gameroom Cash
    $515
    ok will do thank you very much , ill post what happens in a few hours
  6. Join Date
    Kingston
    Gameroom Cash
    $595
    Time Online: 1 Wk 5 Days 16 Hrs 10 Secs
    Avg. Time Online: 1 Min 13 Secs
    pull the plugs one at a time and put your finger over the hole and have someone crank it over, it will tell ya if ya got compression pretty quick
  7. Join Date
    6 feet under
    Gameroom Cash
    $3600
    Time Online: 1 Mth 1 Wk 3 Days 9 Hrs 19 Mins 38 Secs
    Avg. Time Online: 3 Mins 54 Secs
    You may also want to find out why you have gas in your oil.
  8. Join Date
    selkirk ont
    Gameroom Cash
    $10205
    ^ is your engine fuel injected or carb? if you have a carb and has a mechanical fuel pump on the engine you could have a leaking diaphragm allowing fuel to leak into the engine.
    VA3 HWG
    OF4WD #5571
  9. Join Date
    Dec 2009
    chatsworth
    Gameroom Cash
    $515
    ok i changed the oil but i think ima get my mechanic over to take another look at ill run these ideas by him ... thanks again to every one
  10. Join Date
    Kingston
    Gameroom Cash
    $595
    keep us posted as to what he says
  11. Join Date
    Milton
    Gameroom Cash
    $10222
    Time Online: 1 Wk 2 Days 6 Hrs 7 Mins 22 Secs
    Avg. Time Online: 53 Secs
    To me, it sounds like a problem with the rings. The 5.2 is fuel injected, not carb. I think the last carb engine was an Isuzu back in '94, but don't quote me on that.
    Bad rings will usually also cause increased engine vibration as the lack of compression also means the firing forces are now not balanced.
    Damn, where's C.C. when you need him.
  12. Join Date
    Sep 2009
    oakville
    Gameroom Cash
    $499
    Time Online: 2 Days 12 Hrs 5 Mins 53 Secs
    Avg. Time Online: 14 Secs
    first thing i would do is pull the plugs change the oil and do a compression test and actually see what the numbers are
+ Reply to Thread
