Your cart is empty
+ Reply to Thread
Thread: Problem with quadradrive
  1. Join Date
    Nov 2004
    Exeter, On
    Gameroom Cash
    $520
    Time Online: 1 Day 3 Hrs 17 Mins 8 Secs
    Hey guys. My 02 Overland- when its cold out, and only at night for whatever reason, the passenger side front tire grabs. I think something weird is going on in the front diff or transfer case. It does it whether its slippery or not until things get warmed up a bit. Could a little water in the diff or xfer case be causing this? It vibrates pretty good, likely because its grabbing on dry pavement.
    If anyone has anything to try, I'd appreciate it.
    Rick
    2002 Jeep Grand Cherokee Overland
    4.7L HO
  2. Join Date
    Gameroom Cash
    $700
    Time Online: 1 Wk 2 Days 5 Hrs 50 Mins 1 Sec
    Avg. Time Online: 53 Secs
    Caliper starting to seize up? Or a CV at the knuckle going south causing bind?
  3. Join Date
    Campbellton
    Gameroom Cash
    $500
    Time Online: 45 Mins 9 Secs
    I've had drum brakes "freeze up" before even during warmer temperatures but not disc brakes.
    Is the tire skidding when you pull away from a stop? Does it free itself?
    I'd have to guess too that your disc brake pads are literally freezing to the rotor.
    just my two cents...take it for what its worth...
    95 YJ, RE 4" lift, 33" Procomp Extreme M/T's, Warn M8000 and mud - Trail Queen
    04 Liberty Sport, 2.5" Rusty's lift, ProComp LT245/75R16 AT's & a pair of Hella 700FF Lamps - Highway/Trail Ride & sometimes tow rig
  4. Join Date
    Nov 2004
    Exeter, On
    Gameroom Cash
    $520
    It doesn't feel like "grabbing" in the sense that its not turning, it feels like its grabbing on the road surface, like its using 4WD, but shouldn't be because its dry and bare.
    It does eventually "let go", sometimes harder than others. It feels like a bit of a lurch forward, and then everything is smooth again. Before it lets go, there is a growling noise somewhere, and it pulls pretty strongly to the right.
    4.7L HO
  5. Join Date
    Gameroom Cash
    $515
    Time Online: 1 Day 6 Hrs 10 Mins 21 Secs
    Is it when just turning or even when going straight? Transfer case is more of an issue when warmed up and the steering turned. Is yours eqquiped with the Vari lock diff? If so, was the right diff fluid and additive used( 75-w-140 synthetic and diff additive).
  6. Join Date
    Nov 2004
    Exeter, On
    Gameroom Cash
    $520
    I notice it mainly when going straight. It just wants to pull to the right. When it finally stops, its like a lurch and then normal, the pulling goes away. I guess I'll have to swap the fluid out, I don't know when it was done last anyway. QD does have the vari-locks, yeah.
    Thanks for your replies guys.
    4.7L HO
+ Reply to Thread
