Results 1 to 8 of 8
Thread: Nissan Stentra
    Dec 2006
    Hamilton(Waterdown)
    Nissan Stentra
    my buddy at school has a nissan sentra R or something like that, it has an intake, and header, it runs fine and all but sometimes it wont start.. its been doing this for months, randomly it will only crank, but not fire... then you go back a little while later and vroom fires right up!!!
    it wouldnt start the other day he towed it to CT and they tried it that afternoon and it fired right away...
    Im thinking maybe the CPS?
    can anyone help me out so i can let him know things to try!?!?
    Thanks Steve
    Watch the fuel pressure. The sender will bleed the lines back to the tank and cause a no run. If you key it on a couple of times it should start right up.
    thessalon
    Time Online: 1 Wk 23 Hrs 54 Mins 50 Secs
    Avg. Time Online: 39 Secs
    my dodge avenger with the mits engine and it did it all the time. well all the time kinda. replaced crank sensor and boom fixed, $40 bucks
    92 4.0L HO (sold dwnpmt on a new car for teh wife AFTER OLY HAVING ON THE ROAD FOR 3 WEEKs!!!!!!!!!!!! wow that felt good
    1979 CJ-5 ;ifted with 33's ford 302 4 spd
    I'd ask you to step away from the welder, but it might do the world some good if you clamp the ground electrode to your big toe, put the MIG handle to your temple and pull the trigger.
    There was a cam and crank sensor recall on the 2.5
    Sep 2006
    Elora, Ontario
    Bored
    Time Online: 2 Days 9 Hrs 17 Mins 33 Secs
    Avg. Time Online: 11 Secs
    This is going to sound retarded, but Nissans are truly finnicky when it comes to voltage. If the battery terminals are dirty, the car won't start. The ECM wants something like 11.376587 volts (+/- 0.456) or it will fail to start. It'll seem dead.
    Although the CPS seems like a good bet too.
    Square headlights rock! []|||||[]
    Dec 2006
    Hamilton(Waterdown)
    Well im not sure which engine it has, its the bigest 4 cylendar engine out there he said so im assuming 2. something... ill let him know about the CPS and crank. Car only has like 60,000km on it and he already blew up one engine in it haha
    It is never dead dead, it just wont fire sometimes, turns over all day long but no spark i guess!
    thanks for the tips guys! deffinatly look into it
    cheers
    When it's not firing, you'd need to see if there's a CPS signal to the ECU. Unfortunately that means you'll need to drive around with a good (datastreaming) scanner until it does it. CPS's are common for intermittent failures (4.0, anybody?) causing no-starts.
    If it's cranking all day without starting it's unlikely to be fuel pressure bleed-down.
    Dec 2006
    Hamilton(Waterdown)
    ok thanks buddy
