Results 1 to 20 of 26
Thread: 04 tj build v3.0
    Belleville
    Time Online: 1 Wk 2 Days 15 Hrs 35 Mins 20 Secs
    Avg. Time Online: 47 Secs
    04 tj build v3.0
    redoing my tj.... ground up.... she a 04.. only got 31000 km on it
    pulling out
    30/35 410's with super 35 detroit locker
    4" skyjacker
    33" boggers on ion rims
    ^ all going to be for sale once jeep is all done
    going in
    waggy 44s. front arb. rear spool 488's
    37' claws ion rims
    tnt customs front axle truss
    6' rough country long arm
    tsm rear disk convertion
    advanced adapters sye and tom woods drive shaft
    rubicon express bracket kit for the rear
    -- probley a fue other things i'm forgeting
    Belleville
    question i got thinking about.. go high steer or cross over steering... track bar is going to be in stock location. so i don't know if the t bar and the steering need to be at the same angle for no bump steer
    Belleville
    i'm looking for a tie rod reamer.. 1.5" per foor or 8*
    any one got one tks
    Courtice, ON
    Quote Originally Posted by jeep_tj_driver View Post
    if you have the option of moving the trac bar mount, in order to match the drag link angle, I would definitely do it.
    after spending the time and money your going to be, why not set it up properly?
    you want the trac bar length and angle to match (as closely as reasonable) the length and angle of the drag link (from pitman arm to knuckle)
    keep in mind simply matching the bars parallel to each other may cause binding problems when you flex the pass. side down (depending on what links you use, IE heims, TRE's). the bars don't need to mirror each other, but if you draw an imaginary line from each link (frame to axle) those distances/angles should match closely. so if you need to put a bit of a bend in the trac bar to keep the heims flat at ride height it's no problem, or to make it fit around the pumpkin/oil pan when stuffing.
    plenty of really good set-ups to look at if you look around on here or other sites, pics are worth a thousand words as they say.
    as for the reamer, check princess auto every now and then they have them, and on sale too.
    insert something witty here
    TNT has a TB mount for that truss if you go Hi Steer
    Belleville
    i got the tnt with the tb in the stock location... regreting it now..
    i was going to use stock steering set up but the stock holes have been drilled out in the stock spot... so now going to use hi steer .. same cost for all the steel and tie rods just a coulpe bucks more for the arms
    i was thinking about the flip kit for the steering where ya weld in the sleave.. that any good
    i just don't think i need to go all the way to high steer.. only running 6" +/- of lift
    Where is the magic lift height to go all the way to Hi Steer?
    Get that stuff up outta the way given the chance I'd say
    Belleville
    good call.. there is 100 different post on the lift hight
    i just messed up on the tb order,, should of got the tnt with the hi steer set up..
    so the agles are going to be way off between the tb and the steering .. how close do they need to be.. i really don't want to cut a brand new truss apart
    order the correct one and give it to someone handy with a welder, you'll never notice it was changed it it'll be done right
    Belleville
    ya talked me into it lol
    all ready going to have 7500 in the swap whats another 100 bucks
    Sounds like familiar thinking
    Belleville
    o ya one thing leads to another ... new brakes for the rear.. got thinking hell well i`m in there lets go disk..
    i got one big parts pile don`t know where to start. and spring is here already i don`t even want to work on anything just want to go and play
    I'd offer ya my waggy 44 front 8.8 rear that are bolt in ready,
    But they are apt to be under the truck for a little here yet
    Belleville
    well thats a little late lol ...
    but if you are going to pull them off .. could use them for the girlfriends jeep.. i don't think i'm going to be doing a complete home build for awile...
    deffently bolt in next time...
    Belleville
    hey what are your pinon angles????
    Belleville
    the rear set up with the disks.. just need finshed weld and paint
    Attached Thumbnails Attached Thumbnails DSC05330.jpg   DSC05333.jpg   DSC05335.jpg
    Newmarket, ON
    Avg. Time Online: 58 Secs
    Looks good so far dude!
    Any plans on stretching it?
    Now's the time
    Belleville
    was looking into the 3 link in the rear with the stretch ... but i think that will be v 4.0.. when i'm board with this set up and its time for 40s and dana 60s lol
    hopeing a coulpe years..
    next winter will be adding power and lots of it
    also changed my mind on the tires.. now i'm going to be running 35 bfg krawlers.. so the 37 claws might be going up for sale
    Belleville
    new tires
    Apr 2006
    Waterford
    Time Online: 4 Days 4 Hrs 38 Mins 6 Secs
    Avg. Time Online: 20 Secs
    how much you want for your 30/35 with the locker ?
    If it ain't redneck it ain't worth doin
