Thread: Rear Bumper Project
    Highest populated point in ON!
    Time Online: 2 Days 11 Hrs 38 Mins 4 Secs
    Avg. Time Online: 12 Secs
    Rear Bumper Project
    Started with stock bumper and previous owner made "hitch":
Name:	Web DSC07554.jpg
    Decided on something a little more substantial, with an integrated CIII tow point and recovery points.
    Decided on 3"x4"x0.25" tubing for the main body, and 2"x4"x0.25 for the end sections.
    The ends need a little style rather than just plain old flat...
Name:	Web 100_0208.jpg
    Wanted something a little different for the ends. Thought that I'd like a little rear quarter protection (with style of course!). Just tacked up:
Name:	Web 100_0212.jpg
    My buddy Mike stopped by, so he got put to work finishing up some of the welding:
Name:	Web 100_0214.jpg
    Fully welded and ground:
Name:	Web 100_0221.jpg
ID:	55224Click image for larger version.
Name:	Web 100_0225.jpg
    'll be taking it over to the local welding shop to get the receiver and recovery points cut in with the plasma.
    I'll make a set of frame tie-ins for the inside corners, and probably a set to pick up the attachment points on the bottom of the frame rail as well.
    It'll have to be rattle can black for now, but eventually I'll blast it and either powdercoat, or do it up with bedliner when I do my interior.
    I'll get more pics up as it progresses!
    '04 LJ
    Screw this web-crawlin', let's go Wheelin'!
    Courtice, ON
    personal preference, but I am a big fan of the rubberized rockergaurd stuff from CTire. Stays fairly black over the years, and if/when you get a scratch you simply spray that spot and don't worry about it.
    the bumper looks good, simple, clean lines and like you said, it's not "plain old flat"
    insert something witty here
    Ottawa
    Quote Originally Posted by beakie View Post
    +1. did that with my front bumper. easy fix.
    Thanks for that idea guys. I think I even have a can of that kicking around... I was thinking that it might be hard (impossible) to patch up if done in either PC or BL.
    Got the holes burned for the receiver and tow points today. Got them welded in and all the splatter knocked off, just need a little finishing touch. I'll post up some finished pics here shortly, and some pics mounted up tomorrow.
    May 2008
    Tillsonburg
    Time Online: 4 Mths 4 Days 16 Hrs 58 Mins 58 Secs
    Avg. Time Online: 10 Mins 17 Secs
    Looks good! nice and beefy
    OF4WD #5678
    Tri-city jeep club
    2005 LJ Rubicon
    2008 WK CRD
    2010 Ram 6.7 Cummins
    Well finally remembered to bring the camera home from the shop...
    After the second coat of primer:
Name:	Web photo.jpg
    With the rubberized undercoating (thanks for the suggestion!!):
Name:	Web 100_0227.jpg
ID:	55893Click image for larger version.
Name:	Web 100_0228.jpg
    Mounted up:
Name:	Web 100_0229.jpg
ID:	55895Click image for larger version.
Name:	Web 100_0230.jpg
    Overall pretty happy with the way it turned out. I forgot to weld on the lower brackets before paint, so that's happening this week.
