Results 1 to 20 of 25
Thread: Re-building CJ-7 with a bit of YJ
    Campbellville, Ontario, Canada
    Time Online: 1 Wk 5 Days 3 Hrs 13 Mins 5 Secs
    Avg. Time Online: 59 Secs
    Working on rebuilding my 85 CJ-7… Last time I rebuild it was back in 2000 when I bought it. My frame is rotted, so it is time to start over again.
    The plan for the build is:
    CJ – Frame, Axles, Transfer Case, Grill, Fenders, Brakes
    YJ – Engine, Transmission, Leaf Spring, Tub,
    I have picked up an older CJ Frame not sure what year, but there is an extra cross member my 85 didn't have. I have been welding it up fixing some hole. I have it primed and just starting the painting.
    Attached Thumbnails Attached Thumbnails P1080205.JPG   P1080203.JPG   sP1080161.JPG
    1991 XJ - Sold
    1985 CJ-7
    1985 CJ-7 - parts - gone
    2006 LJ Unlimited
    Ripping apart the old one...
    Lots of work, but it'll be worth it when you're done.
    Are you going with a newer 4.0?
    I don't know if I would say "newer" but... I have a 1992 4.0L with AX-15 which I will be trying to attach a Dana 300 to.
    Not sure if that will work out or if I need a clocking ring.
    PM Bonecracker, he swapped a 94 4.0 and AW4 from an XJ into his CJ-7, and used his old Dana 300.
    AW4 in a CJ? Wow, shoehorn needed there!
    Are you going to swap to fuel injection this round? I would strongly recommend it - eliminates all the issues the Carters had. Of course there's the Motorcraft carb swap option too.. but I'd rather do some extra wiring and have a self-tuning vehicle.
    Cambridge, ON
    Time Online: 2 Wks 3 Days 16 Hrs 40 Mins 23 Secs
    Avg. Time Online: 1 Min 27 Secs
    Not sure about the AX-15 but I do have a 4.0HO with the AW4 in my 86 CJ with my original Dana 300 bolted to it. I used a clocking ring, the bolt pattern for the AW4 and 300 are the same but the output shaft on the AW4 was a little too long and I wanted it clocked flat anyhow. I used an XJ transmission cross-member which fit beautifully on the CJ with just a little trimming to the length. Custom drive shafts front & rear because the Dana 300 moves back by 4-6" from stock when bolted to the AW4(again, not sure about the AX-15). I put the entire wiring harness from the cherokee in the CJ, but I have read that it is fairly simple to mate the two using the CJ harness. I got some info from JeepKings but cjoffroad.com was the main source for the swap info. Every issue you will run into for a 4.0 swap in a CJ is covered step by step there, with pics. Good Luck with your swap.
    GoGetMuddy
    OF4WD#6121
    Cottam, ONT
    Time Online: 4 Wks 1 Day 9 Hrs 30 Mins 51 Secs
    send a message to Possumjeep, he is currently in the process of making a dana 300 work with an ax15
    Essex County Jeep Club
    -1999 TJ "50 Shades of Jeep"
    Leamington
    Time Online: 1 Wk 4 Days 10 Hrs 59 Secs
    Avg. Time Online: 56 Secs
    yup I ve got an AX15 between the 304 and my Dana 300
    I bought a clocking ring from a member of another forum but I had to drill it myself for whatever degree I wanted
    with the AX15 Ive heard that you encounter some contact between the side of the AX15 case and the Dana 300 shifter I dont have this problem since my shift mount has been modified to accomodate a twin stick configuration
    hope this helps
    Ill get pics of my setup up as soon as I can find the cord for my camera
    Rolling Chase...
    So I managed to get the wheels and engine on... It turns out that you don't need a engine hoist to put the engine with tranny on to the frame... Got it done with 2 people helping. Put the frame on the engine, then the axles on the frame.
    To connect the AX15 to the Dana 300, I picked up at spacer/clocking ring from DVSJEEP.
    I have also manged to break my camera... it didn't like being droped on cement
    Attached Thumbnails Attached Thumbnails sP1010756.JPG   sP1010757.JPG   sP1010755.JPG
    Gas Tank
    The plan for the gas tank was to attach the YJ fuel pump to the bottom of the CJ flange removing the CJ filter. I was worried about the pump as it would have been unsupported; I would have needed to run the wires etc… so I just put the whole YJ unit in. I am hoping the 1” body lift will allow the enough clearance for YJ Gas/Vent hose.
    Attached Thumbnails Attached Thumbnails sP1010769.JPG   sP1010768.JPG   sP1010771.JPG
    Clocking Ring/Spacer
    Here is the clocking ring/spacer. I am going from AX15 to Dana 300. With the spacer in the Dana 300 Shifter Bracket is hitting the transmission, it will clear it if a use a different clocking hole. I want to keep the shifter brackets level. I will be shaving the bottom of the shifter bracket off, until there is clearance.
    Attached Thumbnails Attached Thumbnails sP1010762.JPG   sP1010766.JPG   sP1010759.JPG
    Oct 2005
    Norval
    Time Online: 6 Days 14 Hrs 27 Mins 54 Secs
    Avg. Time Online: 32 Secs
    Its about time you got something done with that poor jeep. So your going to be ready for next weekend right?
    Sure... next weekend n/p. Are you making my drive shafts (again) :P
    Oct 2005
    Norval
    More...............You want MORE. I hope you need it shorter.
    Dana 300 install
    Attached are pictures of the Dana 300 installed. You can see where the Shifter bracket was shaved down.
    Mounting the Transmission
    For mounting the transmission I decided to use the AX15 bracket and with the CJ poly mounts attached to it. The bolts into the AX15 where hitting the raised part of the CJ skid plate... So I removed it. Will be welding in a piece of flat steel.
    Drive Shafts
    Quote Originally Posted by Rholden1 View Post
    One Shorter, One Longer...
    Mounting the Transmission -
    Here are pictures of the YJ - AX15 mounting bracket and the CJ Skid plate after I modified them.
    AX15 Transmission Mount Plate - cut a 1/4" off the back so it would not hit the Dana 300, Cut off the exhaust mount.
    CJ Skid Plate - cut off the raise section and replaced it will flat steel.
    Morgan
    Attached Thumbnails Attached Thumbnails P1010797.JPG   P1010792.JPG   P1010796.JPG
    Hamilton/Stoney Creek
    Time Online: 2 Mths 4 Days 13 Hrs 52 Mins 19 Secs
    Avg. Time Online: 5 Mins 18 Secs
    Good Job so far...
    1983 Jeep CJ7: SOLD
