Results 1 to 11 of 11
Thread: Project XTV
    Leamington
    Time Online: 12 Hrs 23 Mins 14 Secs
    Project XTV
    I started a custome buggy build about a year ago. It has been a slow process, as I am still in school. Here are some of the specs
    Engine:
    chevy 350 4 bolt mains
    bored 0.30 over
    machined crank
    low compress pistons
    double roller timing chain
    TPI intake
    T4 turbo
    custom S.S exhaust (fab by me)
    mega squirt 2 V3.0 EFI
    Trans:
    chevy turbo 350
    B&M shift kit
    B&M rebuild (by me)
    custom deep trans pan (fab by me)
    Under Drive:
    Its an old NP 241 stripped down to just the planatary gears, than I made a flange to bolt onto the NP 205.
    Transfer Case:
    Rebuilt NP 205.
    Axles:
    Custom build dana 60 front and rear, rear has a welded diff. Looking at putting and ARB in the front.
    I am going to run some 44" rubber, but I cant decide what to go with. interco TSl, pitbull rockers. It is going to be a bush only buggy.
    Attached Thumbnails Attached Thumbnails P3270749.JPG   P4170311.jpg   P3260745.JPG   P1300520.jpg   P4260562.jpg
    Leamington
    Got a few more pics of my build. I got some free ford F-350 rear dual piston caliper brakes, so I built them int omy rear axle. So far so good, I have to figure out my front axle angles, then I can put the inner C's back on and finish the front axle.
    Attached Thumbnails Attached Thumbnails P5210592.jpg   P5220615.jpg   P5220613.jpg   P5210601.jpg   P5210598.jpg
    Time Online: 10 Mths 3 Wks 5 Days 14 Hrs 51 Mins 22 Secs
    Interesting project....have a chassis yet?Good job with the headers and turbo flange. I like seeing that snail hanging off of the side!
    Nice setup. What are the specs on the turbo and what are your projected boost levels? What guage are you using for the tubing on the manifolds?
    Plan on using Megasquirt to control your spark?
    Plan on doing my twin setup next year but keeping the propane.
    North Bay
    Time Online: 2 Days 20 Hrs 51 Mins 5 Secs
    Avg. Time Online: 14 Secs
    This drivetrain is right up my intrest ally looks like yo uhave a good start going there. I think everthing is kick ass except the 350/350 combo hahaha but thats just my taste.
    Id be interested in more info on the turbo/ megasquirt setup and alot more info on the 241 dbler
    Propane+ turbo = good possibilities. propane is very high octane
    ---------- Post added at 04:18 PM ---------- Previous post was at 04:14 PM ----------
    It looks like stainless to me you could get away with thin wall stainless but I would use 1/8 wall. I used it on my turbo mani. Id use regular steel in 1/8th on a bush truck.
    Just rethinking this 1/8th might be heavy for such a long header not sure though.
    Leamington
    I m designing the chassis right now. looking at 110 WB 1 3/4 x .120 tube all about tig welded. i got a pic of what i want it to look like, but it is kindad complex to get all that suspension lined up.
    ---------- Post added at 11:13 AM ---------- Previous post was at 11:08 AM ----------
    i m using the mega squirt to control advance/dwell. not to fire the coil directly. that way if i lose spark timing from mega squirt i will still have spark at 10 degrees spark advance which is good to make the engine run.
    ---------- Post added at 11:25 AM ---------- Previous post was at 11:13 AM ----------
    Quote Originally Posted by frank View Post
    the headers aer 16 guage 304 ss bought from columbia river mandrel bend. looing at about 10 psi boost. should put me near 400 Hp but gobs of torque which i will need to move this 4000lb buggy.
    ---------- Post added at 11:41 AM ---------- Previous post was at 11:25 AM ----------
    I just got a new welder. miller 250 DX so now my rear axle is assembled just have to build the truss for it and i will post pics. anyone know someone in canada that does axle splining.?
    ---------- Post added at 11:42 AM ---------- Previous post was at 11:41 AM ----------
    Leamington
    Got a new set of pitbulls and some 12-bolt hummer wheels. 44" rubber is awesome.
    I also have my front axle near complete, the truee is done and steering cylinder mounted.
    The little bracket I built is for the rear of my NP205, its the mount.
    Attached Thumbnails Attached Thumbnails P7170704.jpg   P7170710.jpg   P7240720.jpg   P7180718.jpg
    Leamington
    I have a few pic's of my insperation just to give you guys an idea of what I am building exactly. Its kinda different.
    windsor, on.
    Time Online: 1 Wk 5 Days 13 Hrs 56 Mins 58 Secs
    Avg. Time Online: 1 Min 1 Sec
    Man o man Frank, I can't wait to see this baby done! Everything looks awesome so far! And you're right 44"rubber is amazing!
    Apr 2005
    Time Online: 2 Wks 5 Days 8 Hrs 46 Mins 28 Secs
    Avg. Time Online: 1 Min 35 Secs
    Forrest racing can respline (and anything else axle related really) they are in Alymer
    Leamington
    Actually I found a guy state side to respline for $75. Quite a good price, everywhere I called in Canada was charging $100+ just to set up the machine.
    Front shafts are at the heat treater right now. I have my new H! wheel centers tacked in, post some pics soon.
