Thread: Axle swap
    Paris, ON
    Time Online: 1 Day 1 Hr 59 Mins
    Axle swap
    Hey just wanted to know what I need to do to if I'm going to swap Dana 30 and Dana 35 Axles from a YJ into a CJ that has an AMC 20 and a Dana 30. Any help would be great.
    Mar 2003
    Hamilton, ON, CA
    Time Online: 1 Wk 4 Days 9 Hrs 35 Mins 12 Secs
    Only question: Why?
    A Dana 35 is a POS....
    Cambridge, ON
    Time Online: 2 Wks 3 Days 16 Hrs 40 Mins 23 Secs
    Avg. Time Online: 1 Min 27 Secs
    Dana 30 from a CJ is passenger side pumpkin and Dana 30 from a YJ is driver side pumpkin so you would also need to change your t-case.... at least. Also, the spring perches on the YJ axles will be in a different location. Unless you have a really good reason, this does not sound like a great plan. And , Like Pins CJ said, Dana 35=POS
    GoGetMuddy
    OF4WD#6121
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 28 Mins 58 Secs
    Quote Originally Posted by CJ7 Money Pit View Post
    Start with a 2x4 and smack yourself on the head. Seriously, that swap makes absolutely no sense on every conceivable level.
    Georgetown
    Time Online: 5 Mths 3 Wks 5 Days 23 Hrs 16 Mins 16 Secs
    Avg. Time Online: 14 Mins 32 Secs
    Are you pulling our legs LOL.
    If you are serious though, way too much work to do the swap, the front pumpkin is on the wrong side as stated above.
    If you're doing the swap for better gearing, put up a post in the wanted section for CJ axles, if your looking for stronger axles, YJ ones are not the way to go. Look for some dana 44's.
    Mar 2003
    Hamilton, ON, CA
    Quote Originally Posted by pav1 View Post
    If you're doing the swap for better gearing, put up a post in the wanted section for CJ axles....
    I happen to have a set that was just removed.......a built AMC / Detroits / 4:56's / etc and a Dana 30 / Open/ Milemarkers / Shafts / 4:56's / etc.........
    Anyone can PM me for details....
    Time Online: 3 Mths 2 Days 4 Hrs 33 Mins 57 Secs
    Avg. Time Online: 7 Mins 34 Secs
    i have some cj axles, locked with 5.38 gears im looking to get rid of...
    Ajax Ont
    Cynical
    Time Online: 3 Wks 3 Days 6 Hrs 38 Mins 4 Secs
    Avg. Time Online: 1 Min 59 Secs
    Ya the d20 is stronger then then d35 (and if you truss it) and one piece shaft is kind of close to a d44
    and if you dont want to put in a d44 front.. keep the d30 and chromo the shafts at lest..
    but your best bet is scout axles or old waggy axles (pre 79 i think) had the driver side drop
    Jeeps, Bitches and Guns... Nuf Said
    Paris, ON
    OK Guys I'm a dumb ass!!! Thanks for the info. I'll keep looking for 3:73 or 4:10's for my AMC 20 and Dana 30
