Thread: failed an e-test - would new cat help?
    Oct 2003
    London, Ontario
    Time Online: 1 Mth 2 Wks 3 Days 15 Hrs 42 Mins 42 Secs
    98 passat 1.8L turbo, failed last week, good idel but 40km/h high co and high nox (1000 and limit is 450)
    did some things to it, fuel system cleaner, combustion chamber cleaner, oil change, was nice and hot for the test, but failed again, co was barely ok and nox was down to 700.
    Since the cat is a dealer only job, I was thinking about adding another generic cat just past the flex pipe. ANy ideas if this will fix a high nox problem?
    Hamilton/Stoney Creek
    Time Online: 2 Mths 4 Days 13 Hrs 42 Mins 54 Secs
    Avg. Time Online: 5 Mins 19 Secs
    Why would the cat be dealer only Job? unless you mean to buy the OE part as it is not available aftermarket which would be odd for a 98...
    If your interested in adding a second Cat why not just replace the current cat with an aftermarket weld in cat? I do not think it would help
    you that much to add a second cat as the first one if faulty will only clog up and eventually be blocked off alltogether...
    I would replace the cat and Do a tuneup...
    1983 Jeep CJ7: SOLD
    I'm with Alex on this one... why a dealer cat? Quality 3-way replacements are about $200. I am not familiar with VW but I'm fairly certain there's no EGR on them, so the cat must be a 3-way, to control the NOx levels. High CO is often caused by sticky oxygen sensors... but again if the cat is no good you're gonna have trouble regardless if the O2 is working or not.
    Oct 2003
    London, Ontario
    the cat is beside the engine mounted right to the turbo. I didnt know there was an aftermarket replacement
    Flippin' VW's. Why?!?
    I see what you're saying there. Yes, a second cat would probably be easier than replacing the OEM unit. Talk to your local fab shops about fitting another cat in.
    There ARE aftermarket bolt-in cats available for VW's though. I just don't know where. Lapointe in Quebec used to do a lot of the weirder stuff, but I haven't used them in a couple years.
    ---------- Post added at 10:21 PM ---------- Previous post was at 10:17 PM ----------
    PS; I just googled it and there are a few sites that sell bolt-in aftermarket pipes w/cats. Prices aren't very good though. I again suggest heading to a local Zorro or Speedy and see who can weld in a new one for you.
    Oct 2003
    London, Ontario
    I guess the egr units are known to carbon up. might be worth the while to clean them out
