Page 1 of 5 12345 LastLast
Results 1 to 20 of 87
Thread: Build Day July 24th.
    ontario's west coast
    Avg. Time Online: 17 Mins 35 Secs
    Hi folks. I've decided to call upon you folks for some help in getting some work accomplished on my wife's YJ. Time is running out before our vacation in the end of august and lots of work is left to be done. Most of which i dont know how to do....lol
    I've got permission to use my parents place on july 24th to try and host a build party and would certainly appreciate any efforts by you fellow members.
    I know there is a couple folks already willing to help out so it was suggested i start a thread and post what needs to be done ahead of time.
    so here goes....
    The YJ has a 4.3/700r4/231 tcase w/sye. mounts are not welded in place as of yet because the driveline angle hasn't been set yet. (one of the things i'm not sure about tackling on my own).
    - the motor will also need to be wired up.
    i believe all the wiring and necessary gm hardware is there, but wont know till someone who knows what they are doing looks at it. torque convertor is not bolted into place yet, but is in.
    1.- all the usual bullshit that goes with putting in a new motor. oil change, plugs, wires, pcv valve, yadda yadda yadda.
    2.- skid plate fabrication for tummy tuck
    sarge volunteered for this task
    3.- front shocks and hoops to be fabricated and installed.
    tubes are bent, just need to flex the jeep and finish off..
    4.- trans cooler, and rad installation
    5.- the transmission kickdown will need to be setup as well.
    I have a ratchet shifter that i THINK will work...lol. if not, i'll find one.
    7.-brake lines need to be reconnected and extensions installed.
    have extensions.
    8.- complete wiring for the jeep. kill switch, tail lights,electric fan, dash and gauges, start.
    9.- install new seats, seat belts, tuffy console.
    would prefer to mount seats to the roll cage, but for now they are on yj frames to save time.
    10.- front and rear bumper fabrication. (not priority)
    11.- secure roll cage to tub. ( will make frame tie-ins later on) DONE
    12.- drain fuel tank and handle fuel system.
    (chassis sat for a while with the fuel tank exposed, so there is a good chance of moisture in the tank... hopefully not rotted...lol)
    13.- rear passenger side corner needs body mount installed
    will need to open up the box from the inside to get a nut on the body mount bolt.
    14.- may need differnt shackles made.
    15.- bolts bolts bolts..... everything needs to be tightend or checked. the trans, t-case, driveshafts, will all need replacements
    16. - remove rear track bar and bracket.
    17. - fab a set of sway bar discos
    Jb70 has a set of discos he will be bringing! THANKS JB!
    18. - install soft top.
    Thats just off the top of my head for now. i'm sure the motor and trans stuff will be a series of small jobs and pains in the asses.
    Food and drinks will be provided. since it is only a day build, we cannot have anyone getting drunk, but some beer or other alcoholic beverages will be provided to those that can drink responsibly. I trust you understand.
    we have a fair selection of tools, but you may want to bring your own preferance of hand tools. sockets, and wrenches are scattered at our place, but we do have a 220 mig, plasma cutter and a good supply of air.
    Let me know if you are interested in helping out. I know my Mrs will certainly appreciate it as much as i will. Theres talks of a sunset ride on the beach nearby to finish off the day.
    if theres something in particular job you want to tackle, let me know the parts you will require, and i will get them ready for you. The main thing is to try and get it running. once its at that stage, it should be home free from there....lol (crossing fingers)
    Thank you for reading.
    Billy and Kelly.
    Whitby, Ont
    Time Online: 8 Mths 3 Days 23 Hrs 10 Mins 32 Secs
    I'm in.
    FREE FOOD LOL
    ᄅ# pɐǝɹʇǝɹ
    Dec 2008
    Bitchy
    Time Online: 2 Mths 4 Wks 1 Day 8 Hrs 41 Mins 35 Secs
    Avg. Time Online: 7 Mins 20 Secs
    you know ill be there after work, with my whip and all!!!!
    Filthy Dirty Jeep Girl!!!
    '00 Wrangler. Lifted and rear locked. R.I.P
    '98 XJ 3.5 inch lift with 31's- sold
    '03 Cherry Rubi!!
    Fine
    Time Online: 5 Mths 1 Wk 4 Days 14 Hrs 1 Min 39 Secs
    Avg. Time Online: 13 Mins 17 Secs
    jeeps,food...and whips...i'll see next week if i have to work or not
    6#DAERTER
    01 TJ
    Cheerful
    Where is the build going to be Billy? I'm def in if nothing else comes up!
    OF4WD 5435
    2dr - 2010 - Rubicon
    Cake bakers united
    the build will be held at my parent's place between parkhill and port franks.
    Cheerful
    Ahhh, that's kewl.
    I'm not going to be able to provide any real technical know how, but I can turn a wrench!
    Quote Originally Posted by JB70 View Post
    Ahhh, that's kewl.
    sounds good mang! u and me both! lol.
    Near London
    Avg. Time Online: 4 Mins 13 Secs
    you know ill b there
    Quote Originally Posted by Cherokee Steve View Post
    excellent! anything in particular you want dibs on? just so i can get materials you may need.
    Tired
    Avg. Time Online: 13 Mins 6 Secs
    I am working down in Exeter at the time so I can likely swing over.
    #16. Dont step on Sarge's balls whilest he is under jeep.
    Near London
    Quote Originally Posted by MayhemInc View Post
    they dont fukn work anyway so whats the problem?
    Aug 2003
    Ipperwash
    Time Online: 1 Mth 1 Wk 4 Days 2 Hrs 47 Mins 53 Secs
    Avg. Time Online: 3 Mins 22 Secs
    If you want I can stand back and watch
    2dr 5spd Cherokee
    I want to be tugged
    SMWIA 539
    Near London
    Quote Originally Posted by 10tapper View Post
    fuk i didnt know that was an option, put me down for that to
    lol.... every worksite needs a health and safety rep to make sure everyone is working safely...
    K.... well today i got the roll cage finally mounted , so thats off the list...lol.
    driver side windshield hinge has been replaced, but now doesnt match the passenger side, so it needs to be replaced as well...lol.
    Just trying to get a head count for next weekend so i can get parts, and food arranged, so if everyone thats coming can let me know as soon as they can, it would be great!
    Whitby, Ont
    well ya know I'm in
    the other question is...... what do you all want for supper? is there any food that is off limits?
    was thinkin of makin some chilli for lunch if everyone is fine with that.... but havent decided on supper yet. will throw out an idea when i get one...lol.
    k... so far for confirmations, we have steve, sarge, tim, craven, chicky,and igottafrigginlongassnickname
    not sure if i've missed anyone...
