Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: 1983 CJ7 rebuild
    Georgetown
    1983 CJ7 rebuild has been abandoned and all parts will be sold :(
    The Goal:
    A fairly stock CJ7... don't see a lot on the road on the more anymore. Only doing a 3" lift and 33's.
    4.2L, t4, dana300, 3.31 axles
    Black interior - ??????????? exterior
    The History:
    - had a 89 yj sahara 3" leaf, 3" body, 33's, american racing rims, HEI distributor, custom carb, tube bumpers....
    - first daughter came sold jeep
    - didn't have any 'toys' picked up a really rough brown cj7 limited
    - picked up a green fiberglass body
    - found a better dark aqua 83 cj7 'donor' and took apart the limited for extra parts.
    - putting the fiberglass body on the better 83 frame
    The Good:
    - rebuilt engine, trans
    - too many new parts to list
    The Bad:
    -Typical cj frame repairs
    The Ugly:
    - my fiberglass body looks like the last owner was a blind woodsman judging by how hacked the firewall and other sections of the body are. Shouldn't have bought the body, may find another, may be doing some 'itchy' work on it.
    Attached Thumbnails Attached Thumbnails 100_0808.jpg   100_0809.jpg   100_0813.jpg   100_1698.jpg   100_1699.jpg
    Georgetown
    I won't bore you with the teardown, here's a pic in the foreground of the frame. I tossed the body onto another frame in the background for now.
    I'm on the frame.
    Attached Thumbnails Attached Thumbnails 100_1584.jpg   100_1583.jpg   100_1685.jpg   100_1684.jpg   100_1682.jpg
    Georgetown
    The welding started tonight.
    Paris
    Time Online: 1 Mth 1 Wk 22 Hrs 36 Mins 41 Secs
    Nice looking CJ, gives me some inspiration to get back in the garage and work on mine.
    Only thing i would suggest with the welding would be to weld in some fish plates over the patched up areas for reinforcement
    '02 TJ - DD/Parts Runner
    '83 CJ8 - Toy/Project
    Georgetown
    That's a good idea. I'll probably fish plate at the rear, since I'm pulling a trailer. I think where I welded the inside of the frame under the rear spring front perch is okay.
    ---------- Post added at 10:32 AM ---------- Previous post was at 10:30 AM ----------
    Hope you get onto the cj, don't see enough of them around any more. I'll probably have left over parts at the end of the build. I think I have enough to build two complete cj's LOL.
    Jul 2010
    Time Online: 3 Wks 1 Day 2 Hrs 42 Mins 44 Secs
    i would take the time to plug the manufacturing holes in the frame it will stop from filling with mud.
    Georgetown
    Good idea, but I need a couple of holes for my trailer hitch, but I will be drilling a hole in the crossmember so I can hose out the frame when it gets filled with crap.
    Feb 2003
    Orbiting Earth, currently over Binbrook, ON
    Time Online: 4 Wks 1 Day 22 Hrs 40 Mins 39 Secs
    Avg. Time Online: 2 Mins 28 Secs
    bookmarking this build - nice start, sounds interesting
    Member & Supporter of:
    Rockspyder4x4, Krawlerz Off-Road Enthusiasts, Central Ontario 4x4, Canadian Nissan Truck Club, London & Area Jeep Owners Club, Tri-city Jeep Club, and Ontario Federation of 4wd Recreationalists
    Georgetown
    Thanks to all for the kind words,
    I need the encouragement at this point, I found out last night that my frame measurements were way off and I have to cut off the rear crossmember that I just welded to spread the rear frame apart so my springs will be parallel.
    OffroadDaddy - I still have your emergency brake pedal for when you need it. I also have cables for you now, so I have everything except the parts inside the rear axle drums. Let me know when you want to come out.
    Feb 2003
    its a pain in the a$$ to back track - but when its complete and done the way you originally intended, you'll be glad you did !
    Need to goto London either Sat or Sun...I will know this evening, so I can definitely make it to you this weekend. Tks for holding onto those pieces for me !
    Georgetown
    Spent the day with my friends grinder, sawsall and air chisel. I got the rear crossmember back off.
    One step forward and three steps back. Oh well, here's some pics.
    There's a couple of pics when I was moving the nuts in the frame to the proper location. I want to make sure the spring mounts are lined up.
    Attached Thumbnails Attached Thumbnails 100_1709.jpg   100_1708.jpg   100_1706.jpg   100_1707.jpg   100_1705.jpg
    Good work!
    Apr 2006
    Dresden Ontario
    Looking good! From the pics it looks like your starting with a pretty good CJ frame, be sure to check around the main eye spring hangers closely for cracks. They like to split where the factory welded the two halves together.
    1985 CJ7 Aluminum tub, 31's
    1985 CJ7 All steel
    Georgetown
    Thanks gents. I got out the hydraulic jack and easily made the 38 3/4" width for the outside frame rails.
    I will look for the cracks. Is the cracking normally between the outside and inside rails or where the inside rail is spliced together at the rear hanger.
    Or is it around the front hangers?
    I'm almost thinking of starting a frame measurement post and common problems for the cj, yj, tj frames.
    Apr 2006
    Dresden Ontario
    I hope that 38 3/4 is a typo! The dimension is supposed to be 37 3/4
    As far as the cracks go they usually start at the spring hangers and run longitudinally along the frame where the seam of the inner and outer frame rails meet on the bottom of the frame. Also check for cracks running vertically just behind the front main eye spring hanger as well.
    Just for clarification check around the hangers that hold the main eye for the spring. Don't usually see cracks at the shackle hanger end but it is possible. Usually rust at the rear is the problem which you obviously know about.
    Georgetown
    38 3/4" I meant 37 3/4" .... The coffee hadn't quite kicked in yet. LOL I will take a close look for cracks before the finishing stage. I'm willing to go the extra mile to make sure I have a solid foundation.
    I think I will be adding fish plates on the outside just to ensure strength.
    Apr 2006
    Dresden Ontario
    Phew!!!
    Jul 2010
    Not to steal the thread but since your talking cj's what is the wheel base of a cj 8?
    103", iirc...
    Georgetown
    All hail 37 3/4"............. and the hanger bolts are smack on 36". I was definitely worth re-doing.
    Next step, a little grinding and some fish plates.
    Is the plate in the last picture factory, or was it from an old trailer hitch. It goes between the frame and rear crossmember on the gastank side.
    Attached Thumbnails Attached Thumbnails 100_1715.jpg   100_1714.jpg   100_1712.jpg   100_1717.jpg   100_1716.jpg
