Results 1 to 15 of 15
Thread: Aztek tranny issues
    Aztek tranny issues
    So my 2001 Aztek has been acting up... my issue:
    the tranny doesn't shift into 4th gear.
    It shifts though all the gears smoothly up to then. When I drive with the shifter in D it shifts smoothly but never tries 4th.. the fluid is topped up and it looks good. there is 250+ thousand KM on it.
    any ideas?
    Time Online: 3 Days 10 Hrs 8 Mins 55 Secs
    Avg. Time Online: 16 Secs
    Is it in limp mode, check engine light on?
    Time Online: 2 Wks 2 Days 10 Hrs 10 Mins 17 Secs
    Avg. Time Online: 1 Min 21 Secs
    what speed and RPM are you maxing out at?
    Re: Aztek tranny issues
    Keep in mind i don't know my arse. From a hole in the ground... But is that a 4spd auto? If so wouldn't you only get 4th in od?
    Jul 2010
    Time Online: 3 Wks 1 Day 2 Hrs 42 Mins 44 Secs
    tranny ever been serviced ? filter / oil change?
    rockwood
    Time Online: 3 Wks 6 Hrs 1 Min 57 Secs
    Avg. Time Online: 1 Min 44 Secs
    there is a valve in the trans that goes bad and in to limp mode and wont let it in to od because it doesn't have enough pressure . Thia vavle is behined the side the side inspection cover and needs to have half the cradle /engin/trans dropped to get to it.
    I just got the guy's at work to do mine was 100 for the pan gasket and 130 for the valve and the labour i don't know about.Any trans shop can check the preshure for you with the right tool
    Quote Originally Posted by Maxwell View Post
    I have no idea if its in limp mode... the check engine light has been on for 3-4 years and the last time I had it dignosed (about 4 months ago) it was due to some sensor in the gas tank.
    Quote Originally Posted by stuck View Post
    well its not maxing out as I don't push it that hard.... but when driving at highway speed (100 Kph) it revs at about 3000 RPM...
    yes 4spd auto.... it used to shift into 4th when I would drive normally around town. now when I do HW speeds it pretends like its a 3 spd
    Quote Originally Posted by MudSir View Post
    No never has... I check the fluids regularly and It doesn't leak nor has the fluid changed colour
    Quote Originally Posted by giezy View Post
    I will look at it tomorrow.... does this seem to be a common issue?
    Will lucas tranny fix help me out here?
    thanks for the info... keep it comin please.
    Ottawa
    Change the oil and filter. forget the lucas and other crap until you do that.
    ^OK that I will do.....
    Read the DTC's Jimmy. You will have a valve DTC if one isn't tossin fluid in the right directions. You may have all four gears but no torque converter clutch lockup. The TCC solenoid is common in the 4t series trannys. For god sakes man change the fluid and filter.
    rockwood
    be a good to get the trans flushed then drop the pan and do a filter
    CC... how do I read the DTC's? this valve thing easy fix?
    and yeah man... I know Fluids... probably this weekend.
    Flush with what?
    Just change the fluid and filter. then repeat 5000 or so later and you should be good for another 60k if nothings burned up. The codes can be read with a simple code reader. To get to the valve body in a 4T40 you need to drop the tranny 1/2 way out of the vanthingy and remove the side cover. Verify the concern first tho.
    rockwood
    Flush with what?
    if you go to a shop ask if they have a flush machine they can tap into the cooler lines and change 100% of the fluid with out the pan drop think it was 50$ when i did my jeep then a wek later i dropped the pan and did the filter my self
    ^ i ll check that out
    thanks CC... I'll let you guys know how I make out
