Results 1 to 8 of 8
Thread: Changing Roll Cage on '91 YJ
    Sep 2010
    Caledon Ontario
    Time Online: 54 Mins 41 Secs
    Thumbs up Changing Roll Cage on '91 YJ
    Hi all, I am new to the forum and Have just bought my first Jeep. It's a '91 YJ and I wanted to change the roll cage to a family cage. Is it possible to change with a '94 YJ and how difficult is it for a newbie. I am mechanically inclined but have never done anything like this. Any info would be greatly appreciated. Thanks
    Aug 2007
    ElliotLake, Ontario home of the bugs
    Time Online: 1 Mth 1 Wk 6 Days 19 Hrs 52 Mins 46 Secs
    Avg. Time Online: 3 Mins 36 Secs
    can be done for sure.....should bolt right in
    only really problematic thing would be rust levels....rustier = higher difficulty level
    hope that helps
    97 tj 4" lift rollin on 33"trXus m/t
    YOUR AN APPLE ( annoyingorange.com)
    "the purpose of life is to end" (agent smith)
    "to crush your enemies, see them driven before you and to hear the lamentation of their women" (Conan the barbarian)
    Time Online: 3 Mths 2 Days 4 Hrs 14 Mins 38 Secs
    very doable. and i have one if you wanna buy it... 50 bucks
    Sep 2010
    Caledon Ontario
    Thanks for the info, picking one up, gonna give it a go
    Time Online: 8 Mths 3 Days 22 Hrs 33 Mins 25 Secs
    Avg. Time Online: 20 Mins 7 Secs
    Well if it is rusted be prepared for some work.
    Soak all your bolts with a good penetrating lube and let sit.
    Have a small torch handy to head up the bolts, you will need this, The small propane ones are fine.
    When you put your torx driver in the head, give it a good hard strike with a hammer try and shock the rust loose. Have plenty of spare torx bits, you may break several.
    If you have an impact gun, even better.
    Heat the bolt up as hot as possible.
    No impact, use a breaker bar and QUICK SNAP it loose, steady constant pressure will not work
    Once you strip the torx heads, you have a couple options.
    Weld a bolt to the head and use that to turn them out, or if no welder
    grind the head off the bolt and drill out later.
    Hope this helps
    Acton / Mississauga
    Time Online: 1 Mth 2 Wks 23 Hrs 37 Mins 32 Secs
    ^thing1 hit it bang on...only other thing i would say is if the bolts dont come out in the first 15 min or so each, just cut em....itll take you less time to driill em later then to fight with em now.
    Sep 2010
    Caledon Ontario
    thanks guys, really appreciate all the advice.
    let us know how you make out, good luck
