Results 1 to 15 of 15
Thread: need help with knock in bottom end of my 96 eagle talon tsi(awd-turbo)
    Jul 2009
    brantford ontario
    Time Online: 1 Day 1 Hr 34 Mins 52 Secs
    hi all im looking to see if ne one can help me with a knock im having in the bottom end of my 96 eagle talon tsi .it is a 2.0l turbo i bought it from a guy who did a bounch of work to the top end but not the bottom end.it runs good at an idle but once u rev it up alittle u can hear a knock in the bottom end.ive had a few friends look at it an sum said its a journal bearing but no one can tell for sure.ne one out there have ne knowlage of these motors????????
    Georgetown
    It's hard to say without hearing the noise...could be rod bearing, or wrist pin, or piston slap, or.......
    Could you post a sound byte??
    Time Online: 1 Mth 3 Wks 4 Days 4 Hrs 51 Mins 45 Secs
    Avg. Time Online: 4 Mins 33 Secs
    Try here lots of good info my buddy was on here not sure if he still is but it has a huge user base
    http://www.dsmtalk.com/index.php?
    94 YJ 5" lift with D44 35 x 12.5 on Steelies 4.0L 5 speed
    86 MJ 3" lift on 31" BFG's 4.0 HO 4x4 conversion - 96 Cherokee update
    More on the way
    OF4WD #6421
    Jul 2009
    brantford ontario
    yes ill try and recorded the know with my phone tonight and post it
    somewhere
    Avg. Time Online: 15 Mins 1 Sec
    It sounds like a main bearing is toast... probably spun in the block.
    Jul 2009
    brantford ontario
    thats another thing i was told
    mississauga
    Time Online: 4 Hrs 5 Mins 9 Secs
    crank walk.. you most likely have a 4g63 7 bolt.. its a common problem on the 7bolt engines.
    [RIGHT]35X12.5R17" DC MUD COUNTRY'z / 6" HELLAS / FLOWMASTER 40 SI/DO / SuperChips 91 tune / COLD AIR INTAKE / 3.92 ANTI-SPIN / TAYLOR WIRES / POWERAID TB SPACER / TRANSGO SHIFT KIT / 12" SOLOBARICS / CUSTOM HOMEBREW FIBERGLASS'D BOX / LoRider CARPETED TONNEAU
    Jul 2009
    brantford ontario
    yes ive done some looking into it and it is 4g63 7 bolt crank...and i have also heard that this a common problem with that motor
    oshawa
    chances are u need a motor ive put 3 in my talon
    milton
    Avg. Time Online: 39 Secs
    ill buy the car off ya. lol. had a few of the actually good non neon motor 6 bolts. if you wanna get rid of it you know where i am
    '99 superduty, 7.3L diesel. 4x4, ex cab short box. edge evolution programmer. straight pipe, torque converter lock up switch. single 7" stack, built tranny with some billet bits inside, 7' trac bars, pyro,boost an tranny guages. 4" lift in the front 5" rear. 305 70 16 mickey thompson baja mtz's on m/t classic 2's. now with dana 60 front, 10.5" rear 3:7.3's. 5" airlift bags in the rear.
    2002 polaris pro-x 440 with 2004 600 motor. walker evans remotes all the way around.
    Jul 2009
    brantford ontario
    how much?here a list of things we just did to the car .....New 4G63T motor, all new brakes, Blow off valve 1g crushed, highflow upper intercooler piping, new T25 Garret turbo, stainless oil feed line SS,all new accessory belts, timing belt upper and lower, balance shaft kit, crank position sensor, cam position sensor, sanded valve cover, HKS Super Mega Flow Reloaded intake Kit, output shaft seals, thick wall Extreme PSI vacuum lines,all new top of line fluids, new rear wiper motor, new jndercoating, new energizer battery, I have 17" Enkie rims with low pro tires on it now, . Engine bay is painted black. ........illl try and put pics up
    Jul 2009
    brantford ontario
    actually heres my email address shot me a msg if u wanna chat and i can send u some pics of it
    Jul 2009
    brantford ontario
    milton
    added you to msn.
    Jul 2009
    brantford ontario
    new laptop give me a few to download msn
