Results 1 to 16 of 16
Thread: The Joop
    Straffordville
    Time Online: 1 Mth 1 Wk 3 Days 6 Hrs 34 Mins 27 Secs
    Avg. Time Online: 3 Mins 18 Secs
    The Joop
    Well, it finally seems that ive collected enough parts to start building... Its a 88 yj thats gonna get a fuel injected chev v8 auto trans, full width dana 44 front, corp 14 rear . Suspension is going to be spring over with wagoneer front springs all the way around and hopefully clear tires around 38". Here are some pics of the frame with the springs mocked up just to see what things are gonna look like and some of the other parts for the build.
ID:	64276Click image for larger version.
ID:	64277Click image for larger version.
ID:	64278Click image for larger version.
ID:	64279Click image for larger version.
ID:	64280Click image for larger version.
    Milton
    Avg. Time Online: 4 Mins 43 Secs
    5 months until the wheeling season opens again... think it'll be done by then?
    OF4WD Member # 5887
    For Sale:
    Coming Soon:
    Straffordville
    Ha 5 months.... I was hoping I would have it drivable by summer but that all depends on time and money, I have little of either
    Dec 2010
    Peterborough. Ontario. Canada.
    Time Online: 5 Days 10 Hrs 10 Mins 14 Secs
    Avg. Time Online: 26 Secs
    This thing will be a beast.
    Working On A 97 TJ
    Straffordville
    Rescued the rear diff tonight, took a few hours to get all stripped down. Lots of hammering, double hammering ( two people at once ) air chiseling and heat. Im hoping to do a rear disc brake conversion, TMR has some fancy caliper brackets for a 14b that im thinkin of using. A couple pics of the ugly mess once stripped
    I used the 14 bolt TMR brackets and they worked great. Rotors and calipers are from a 1975 Chev 3/4 ton 4x4 front Dana 44.
    Straffordville
    Thats the set up id like to go with
    Milton
    Quote Originally Posted by misfitmechanic View Post
    Good luck to ya... this looks to be a promising build!
    Straffordville
    I hope it turns out, Ive been jeepless for over a year now and cant stand it. Been collecting parts for a while too.
    Straffordville
    Got a little work done on the jeep today. I had to bundle up because I was working outside in the nature bay. Got the old engine mounts cut off and ground nice and smooth. Next I gotta get some u bolts and make up some spring plates so I get my rear axle mounted up. I bought some sweet caliper brackets and spring perches from TMR customs and have the perches all fitted to the axle but waiting to weld them untill I can figure out my rear pinion angle. Just gotta get workin on it more.....
    Attached Thumbnails Attached Thumbnails CIMG1851.jpg   CIMG1849.jpg   CIMG1850.jpg
    May 2008
    Tillsonburg
    Time Online: 4 Mths 4 Days 17 Hrs 18 Mins 38 Secs
    Avg. Time Online: 10 Mins 13 Secs
    Looks good, thats one of the cleanest YJ frames I ever seen.
    OF4WD #5678
    Tri-city jeep club
    2005 LJ Rubicon
    2008 WK CRD
    2010 Ram 6.7 Cummins
    Straffordville
    Thanks, my frame and tub came from california. I bought them from bleniumboy off this site last spring. My last yj was riddled with rust and I didnt want to deal with all the rust repairs again
    Straffordville
    Got my rear axle mounted up yesturday, and got some old dually wheels bolted up so I can roll it around a bit easier. This thing has gained a lot of weight in just one weekend
    Attached Thumbnails Attached Thumbnails CIMG1856.jpg   CIMG1854.jpg   CIMG1853.jpg   CIMG1857.jpg
    Straffordville
    Mocked up the front end today. I need to move the front shackle mounts outwards on both sides to accommodate the wider axle, its3/4" wider at the spring perches and they definatly need to be beefed up. There pretty wimpy.
    Straffordville
    Got the front shackle mounts and spring plates made up, some better mock up tires and the tub set on the frame to get some ideas on engine placement. Looks goofy as hell with the little tires but I hope leaves settle down a bit once they get the full weight and some breaking in.
    Attached Thumbnails Attached Thumbnails CIMG1882.JPG   CIMG1877.jpg   CIMG1885.jpg   CIMG1890.jpg   CIMG1888.jpg
    Straffordville
    Some progress.
    Got the engine striped down and cleaned up, new freeze plugs, motor mounts and a fresh coat of paint. Its gonna get a new rear main and oil pan before the final install. Im leaving the old pan on for now as there is no point of bashing up the new one just mocking it up. Almost a professional rattle can rebuild. Also got the jeep rolled into the shop to figure out where I gotta put the engine mounts. I need to find the balance between clearance at the rad and rear driveshaft length before I weld the mounts. Is there enough clearance to run a pusher fan infront of the rad and do they provide enough air flow? If they do Im gonna keep the engine as close to the rad as possible to keep my rear driveshaft as long as I can.
ID:	74391Click image for larger version.
ID:	74392Click image for larger version.
ID:	74393Click image for larger version.
ID:	74394Click image for larger version.
ID:	74395Click image for larger version.
ID:	74396Click image for larger version.
