Results 1 to 13 of 13
Thread: please help!
    Jan 2011
    Barrie Ontario
    Doh
    Time Online: 5 Hrs 30 Mins 2 Secs
    please help!
    my reverse gear in my 1987 yj 6cyl stopped working. i bought a used tranny,and just installed it with a used t-case. went into every gear great. i started the jeep and now it wont go into any gear. just back and forth in neutral. the jeeps up on jack stands and it seems when i let out the clutch and its running the rear wheels spin... im confused cause its not in gear or so it seems that its not.. i know im a newbie on the forum but i really need this figured out.
    hamilton/norfolk
    Time Online: 4 Mths 1 Wk 4 Days 17 Hrs 32 Mins 32 Secs
    Avg. Time Online: 10 Mins 48 Secs
    welcome to jeepkings 240sx. don't be alarmed if this thread is moved to another forum, the Stuck need Help NOW is for people stuck on the trail and in need of help. your problem is mechanical.
    on that note, can you provide any more info about the problem? did you put a new clutch in when you swapped the new tranny in?
    Quote Originally Posted by Mayheminc View Post
    Life is good in the republic of bacon
    RETREAD #9
    Jan 2011
    Barrie Ontario
    Doh
    hey, sorry about that. i had pulled the clutch off and checked it to see if it was in need of replacement and it was actually newish so i put it back on.
    shift linkage issue? To be honist have never looked at the setup under there but if there's a linkage from the shifter to the trans it could be messed up, therefor makeing you think it's out of gear when it is and in gear when it's out.
    Mar 2010
    Mississauga
    Time Online: 1 Mth 7 Hrs 28 Mins 2 Secs
    Avg. Time Online: 2 Mins 29 Secs
    I'd guess its probibly more so a clutch issue with air being in the hydrolic line. Bleed again.
    Mississauga
    If your stick will move from side to side but won't move forward or backward to go into any gear & the tranny is already in gear, I'd say that you installed the stick improperly & missed putting the tip of the stick properly into the shifter linkage. Take the stick back out and look into the shifter pedestal & you'll see exactly where the tip of the stick belongs - put it there & try shifting again without the engine running. If this works then you can push the spring retainer back on, put the tranny in neutral, start the engine and try shifting.
    Jan 2011
    Barrie Ontario
    Doh
    the trans shift lever i have tried lining up 30 times.. i am going to try to bleed it some more.. i pray thats what it is. i have had nothing but headaches with this.
    ill let you all know in a few.
    Just a thought... Your t-case isn't in neutral is it? With engine off and trans in gear, can you turn the rear driveshaft?
    Jan 2011
    Barrie Ontario
    Doh
    it was in 4 lo when i started it. it was really hard to put into 2wd. i cant pull it outa gear and i cant even feel the gears, i can only move side to side with the shifter which i just have sitting in the top. i thought maybe i dropped a dash screw into it or something but i cant see anything at all.. im really starting to get frustrated. like i said its on jack stands. so when i go to start it the rear wheels spin. i push in the clutch and it stop spinning. but still no gears to go into...
    Mar 2010
    Mississauga
    Did you check to see if the transmission imput shaft was the same on both trannys.(the one that sits in the pilot bearing) I know there were a few differences thru the years in the size of the tip.
    Just throwing around some ideas.
    Mississauga
    Take the shifter off and remove the pedestal, next see if that piece that the shifter fits into for gear selection will actually move. What transmission is it?
    Have a look here to find some exploded views - it might help to see what's supposed to be moving.
    Jan 2011
    Barrie Ontario
    Doh
    i got it... ready?? i dropped the tranny and t-case. took it all apart just to the tranny. still no luck.. pulled the back of the trans off to see shift linkages for the gears and found things were misaligned.. referenced off my old tranny with blown reverse gear.. ty everyone!!! was only something i had to learn.. now i know!
    Awesome that you got it fixed!
Tags for this Thread
