Page 2 of 7 FirstFirst 1234567 LastLast
Results 21 to 40 of 123
Thread: TJ Cutting Brake ?!?
  1. #21
    Aug 2004
    Stoney Creek
    Time Online: 1 Wk 1 Day 12 Hrs 50 Mins 27 Secs
    Avg. Time Online: 42 Secs
    LWB jeeps rock.
    Winter.will be here soon. Let the drama begin.
  2. #22
    Okay serious jealousy sitting at this keyboard!
  3. #23
    Time Online: 6 Mths 2 Wks 10 Hrs 1 Min 4 Secs
    Avg. Time Online: 16 Mins
    Here's a good one
    Fuel cell was here
    Didn't really like the wasted space below, or having to reach over it that high, so I think we should put it hereish. 6.5" lower
    but still don't have brake lines, doesn't mean I'm not closer.
  4. #24
    Time Online: 9 Mths 5 Days 19 Hrs 54 Mins 22 Secs
    Avg. Time Online: 22 Mins 42 Secs
    Sexy
  5. #25
    New floor time for the Fuel cell and a skid plate flat across the new frame for it
    Then the yellow part needs to be cut out and raised 2" for the truss at full bump
    Still no brake lines that hold pressure
  6. #26
    Bowmanville
    Breezy
    Time Online: 1 Mth 3 Wks 5 Days 9 Hrs 47 Mins 20 Secs
    Wow, you went thru some trouble to get cutting brake in.....:-)
    Hope it works out for you. Nice job soo far. Glad i finally decided to peak in.
    #4700
    Rubi....
    buggy...
  7. #27
    Quote Originally Posted by Sancza View Post
    It is one of the longer installs I would guess for some cutting brakes likely
  8. #28
    Frames welded on and links being made
  9. #29
    Dec 2010
    Corunna, Ontario
    Daring
    Time Online: 1 Mth 1 Wk 19 Hrs 41 Mins 31 Secs
    Avg. Time Online: 3 Mins 6 Secs
    probably a goofy question, but are you going to have room under there to run your exhaust pipes around that tank?
    Roads?...Who needs roads?
    Where we're goin', we don't need roads.
    2000 TJ Sport 4.0L
    2015 JKU Rubicon
  10. #30
    Quote Originally Posted by Smiley 10070 View Post
    Not goofy at all, Good eye
    Exhaust on this truck has ended at the skid plate for a few years, and will continue too
  11. #31
    This could slow the install down
  12. #32
    ontario's west coast
    Avg. Time Online: 17 Mins 37 Secs
    what type of axle housing is this noobie looking at kind sir?
  13. #33
    Quote Originally Posted by KillBilly View Post
    Same guys as rear
    http://www.ruffstuffspecialties.com/...x.php?cPath=49
  14. #34
    Well the rear now supports it weight
    ORI's through the tub going up/ Fuel cell through the tub going down
    These struts sure make for a clutter free install, no limit straps, no sway bar, no bump stops
    So the truck did a 180 flip in the hoist and
    Commenced cutting more stuff off
  15. #35
    Sep 2010
    petawawa....
    Time Online: 2 Mths 2 Wks 10 Hrs 39 Mins 8 Secs
    Avg. Time Online: 6 Mins 7 Secs
    subscribe
  16. #36
    Front shafts of to get splined
    mm beefy
  17. #37
    Sweet! Is that ride height?
  18. #38
    Nope,,,Rear is just up from bump at this time, front is,,,well just sitting there awaiting an axle
    Got some notching and frame chunks to come out for the rear to come down a bit more.
    Then once the front is in I'll final burn the ORI tabs home where they need to be. The strut bar and uppper/lower tabs are just tacked for cycling so far
    Into some brake work ( rear line to porp valve to line lock to C Brake to calipers) and gettin some PSC stuff in now.
    Side note those stock steering wheels are on there good
  19. #39
    And back where we started
  20. #40
    Port Elgin
    I finally found the brake line tools you requested. do you need the steering wheel puller as well? I may be around tomorrow. depends on how tonight goes.
    KUSS
    Stupid Fukin Nature
    OF4WD# 2660
