Page 6 of 7 FirstFirst 1234567 LastLast
Results 101 to 120 of 123
Thread: TJ Cutting Brake ?!?
  1. #101
    Time Online: 6 Mths 2 Wks 10 Hrs 1 Min 4 Secs
    Avg. Time Online: 16 Mins
    Is the new brake lever your only rear brake. if it is, its not road legal if it matters to you
    Thanks for the concern.
    The pedal actuates the rear disc brakes just like normal. The Cutting brakes override them for independent control on the rears
  2. #102
    Oct 2012
    Windsor,On
    Avg. Time Online: 24 Mins 47 Secs
    How is it plumbed Is there a check valve to not let fluid to the main master cyl. I have rear calipers from an eldorado and was thinking something like this but using the E brake to actuate each wheel. What do ya think?
  3. #103
    Avg. Time Online: 28 Mins 57 Secs
    Moved to hardcore...because I think it deserves to be there...
  4. #104
    It is another pair of independent cylinder set inline to the rear brakes.
    My rear brake line come into the Tub, goes through an adj Porp valve then through a line lock, then into the CNC Cutting brake where it is split into the R and L feed.
    The hydraulic setup works well. Eldo e brakes are a mechanical setup are they? If you can get enough leverage it it may work, but I'd hookup something hydraulic I think
  5. #105
    I guess I did move up from the 37" Maxxis that were holding me to the mini build arena
  6. #106
    Quote Originally Posted by Reverage View Post
    NO MECHANICAL E-BRAKE!?!??! Somebody should warn the nuns, cheerleaders, school band, children, orphans, etc., etc., etc.
  7. #107
    Proper warnings were given,
  8. #108
    Oct 2012
    Windsor,On
    what prevents the cutting brake fluid from back feeding the main master cylinder? is there a check valve in the proportioning valve or do you activate the line lock and then cutter brake
  9. #109
    But did you warn the golfers?
  10. #110
    yup
    Yelled the same warning, from the same hill top
  11. #111
    The mini master in line with rear brake line is whats stopping the fluid from charging the whole system. Its pushing fluid to the wheel cylinder, not the master.
    Porp valve and line lock are not used in conjunction with Cutting Brake to make them function
    http://www.4wheeloffroad.com/techart...utting_brakes/
  12. #112
    Some clips from the last couple weeks,
    playing around with new software and not getting it as clear as it should be from a Hero2
    Don't mind the clip that in there twice, I somehow didn't notice that last night
  13. #113
    Jul 2005
    Oakville
    Time Online: 1 Mth 2 Wks 6 Days 1 Hr 14 Mins 32 Secs
    Looking good.
    Looking at a few rad options for my current build. What part number Griffin did you end up using?
    Team Juggernaut - The Unstoppable Fire Dancer
    1999 TJ - RockCrusher 60's, Linked, 109" WB, Coilovers, 40" MT/R's, Atlas, PSC Cage, Armor.
    Down to one Jeep.....
    powered by - CT MOTORSPORTS
  14. #114
    Part Number Part Description QTY Tracking Number
    Carrier: Est. Arrival
    GRI-1-26221-X UNIVERSAL RACE RADIATOR 1 43312982090
    from summit this one was
  15. #115
    Jul 2005
    Oakville
    Thanks a bunch!
  16. #116
    These PBR's have been exceptional all winter....click HD
  17. #117
    Oct 2012
    Windsor,On
    what happened to the link , just a white screen. what gives?
    OF4WD #7392 88 Romeo
  18. #118
    hmmm, maybe cause its hosted on FB.
    Not sure I'll upload else where
  19. #119
    Quote Originally Posted by biohazard View Post
    some day ill be cool!!
    Were waiting ?!?
  20. #120
    Toxic River?
    Time Online: 4 Mths 2 Wks 1 Day 1 Hr 59 Mins 18 Secs
    Avg. Time Online: 11 Mins 7 Secs
    It's hard to PM you when your storage space is full!
