Results 1 to 20 of 25
Thread: How to add an ebrake to a Dana 44 coverted to Disc Brakes
    peterborough
    Time Online: 6 Days 19 Hrs 38 Mins 7 Secs
    Avg. Time Online: 33 Secs
    I am trying to find out how I can add an emergency brake to a dana 44 that has been converted to a disc brake system. I am not sure what make/model the calipers have come off of. This is really holding me back on getting the TJ certified.
    Jun 2008
    Osgoode area
    Time Online: 2 Wks 5 Days 4 Hrs 8 Mins 44 Secs
    Avg. Time Online: 1 Min 34 Secs
    I "DON'T" think all calipers have e-brakes.... ???
    Perhaps yours is one of them? I know that the caddy calipers do (Hence the relatively high demand on them).
    RIP OD, YOU'LL BE MISSED.... BUT that's OK 'cuz you've been REPLACED !!!
    Time Online: 10 Mths 3 Wks 5 Days 38 Mins 51 Secs
    ^ That would need all new brake parts....everything would have to be changed.
    If that is the GM caliper 7" bolt center size I think they are, you can use these:
    http://www.tsmmfg.com/3120.htm
    If it is the smaller GM 5.5" caliper bolt center, use these:
    http://www.tsmmfg.com/3110.htm
    Avg. Time Online: 4 Mins 45 Secs
    ^ That's what I was thinking too, but it's an annoying design. Wonder if there's a way to convert the caliper to use a cam style cable actuated master cylinder.
    Quote Originally Posted by EngineerJoe View Post
    Wonder if there's a way to convert the caliper to us a cam style cable actuated master cylinder.
    Not sure what you mean....can you post an example?
    peterborough
    Is their anything in particular that I could look for on the caliper to identify the make?
    ^ Measure the caliper bolt center and read post #4. That should answer all of your questions. Judging by the pic, it *looks* like a large GM. A tape measure will end the speculation. They are a 76-78 Eldorado caliper.
    peterborough
    thanks guys.. measured the bolt centers and they look to be 7". I ordered the new calipers and they should be here in a couple weeks. What do I use for the ebrake cable?
    Did you order the TSM calipers with the integeral cable brackets (#3120) or the 76-78 Eldorado calipers from another source?
    TSM #3120 (Eldorado caliper with integeral bracket) = should be able to use OE TJ cables.
    76-78 Eldorado parts store caliper = *should* be able to use OE TJ cables BUT you will have to provide a bracket/mount for the cable housing to slide into.
    Time Online: 3 Wks 3 Days 8 Hrs 17 Mins 55 Secs
    Avg. Time Online: 2 Mins
    I think the Lumina car has a small caliper ebrake you would have to buy the cable / hydraulic actuator though, you'd be cheaper just going back to drums or getting the 05 and up rd44 set up.
    Back to drums = gayer than cum on a moustache. tisk tisk
    gotta look at his cost and what brake performance he can afford + drums work better than the stock rd44, It's cost me almost $500 to get them to actually brake like disk brakes should. Think the Acura Legend also ca\me with a small caliper for ebrake.
    peterborough
    I ordered the TSM 3120. The jeep has 5.5 inch suspension lift and 1 inch body, i was concerned that the OE cables would be too short
    Aug 2009
    peterborough
    Time Online: 4 Days 23 Hrs 2 Mins 7 Secs
    Avg. Time Online: 24 Secs
    i used fiero calipers and stock cables but had to relocate the bracet to hold the cables ive got a 9 inch
    BONES BOUGHT HEEP...BONES BUILT JEEP....BONES BROKE JEEP.....BONES IS NOW BROKE
    Quote Originally Posted by murdlem1 View Post
    I have never heard of anyone having trouble with the OE e-brake cables being too short but perhaps a TJ expert can chime. I'd be willing to bet that you will be fine with the stock cables.
    peterborough
    Thanks everyone.. I just looked under the jeep and I am missing the emergency brake adjuster and the cables.. the list keeps growing
    Newmarket Ont
    Time Online: 6 Days 19 Hrs 30 Mins 59 Secs
    Hi. From experiance, as a GM parts Guy. Those GM calipers and e brake set ups are CRAP, with a very short lifespan on cars, so they sure wont last long on a Heep. You need some special tools to make them retract, and they seize up just sitting in the driveway. The Cutlass/Lumina they they came on where recalled at least 4 or 5 times. Seems to me, they used a vented rotor as well, so the thickness would be way off (could be wrong on that, but the wheel bolt circle would be way wrong)
    As far as the 44 goes, a lot of Grand Cherokees, came with 44A rear ends if equipped with a factory trailer hitch ( I own one) and they have disc brakes, with shoes inside the rotor. It works. Also, Ford Explorer 8.8's have exactly the same set up, and the parts exchange from the 44 to the 8.8 ( I also have one of those in my YJ). Seems to me the cables are also the same, or very similar. I just hooked up Ford stuff to my YJ last week, and if you use the Ford stuff, you dont need the adjuster bolt and Rube Goldberg set up..just grind down the front cable end ball and use a short connector..total no brainer
    Yesterday's HISTORY, Tomorrow's a MYSTERY. LIVE FOR TODAY
    peterborough
    My calipers arrived today so I am going to try putting them on tonight and see how they work. I am still trying to find some ebrake cables for it if anyone knows of anybody parting their jeep out.
    ^ Not worth your time putting used parking brake cables on your heep. They are inexpensve enough to buy new....there is no way to tell the condition of a used cable....and they can seize and cause you grief.
    peterborough
    Thanks CTD Nut.. i don't know what i was thinking when i typed that. I have ordered cables as well, the part that I am looking for is the ebrake cable adjuster. The part that connects the cable coming from the hand lever to the two cables going to the rear.
