Results 1 to 20 of 39
Thread: amc v8 into a yj frame
    port lambton ont
    Time Online: 1 Wk 1 Day 14 Hrs 22 Mins 52 Secs
    Avg. Time Online: 42 Secs
    im currently installing an amc v8 into my cj7 that has a yj frame.
    before i weld the engine mounts to the frame rails. i would like some opinions on the space needed for a electric fan ex(ford taurus).
    i currently have 2" between the radiator and the mechanical fan mount.
    my rear drive shaft length currently is 27.5" from center to center.
    if i have to move the engine back ild rather do it before i weld it into place obviously...
    thanks for your opinions.
    ---------- Post added at 08:16 PM ---------- Previous post was at 08:14 PM ----------
    also if anyone has a pair of waggy dana 44 axles passenger drop let me know thanks
    Georgetown
    Avg. Time Online: 14 Mins 32 Secs
    The taurus fan is about 5" deep, but you may be able to shave some of the shroud.
    If driveshaft length is not an issue, try to get the engine as far back as you can to center the weight better in the vehicle
    port lambton ont
    how far is to short for a rear drive shaft?
    i always thought longer was better
    if i move the engine back say 2" that would give me 4"+ is the mechanical fan bracket removable. didnt want to hit it incase i damaged anything.
    if it is i would have about 6" of space for my fan.
    Georgetown
    The aluminum spacer on the water pump pulley can be removed and then install short bolts.
    It looks (from the pics) like a taurus fan will fit with where your at.
    A longer driveshaft is definitely better.
    port lambton ont
    should i move it back an inch or two just incase?
    what should be done about the skid plate? the tranny mount is 4" higher than the bottom of the transfercase. so im gunna have a lump sticking out of the skid plate 4" lower. thats gunna make a great rock catcher
    Georgetown
    Get a hold of the fan you will use and leave 1/2" gap to the pulley for movement and twist.
    What's the spacing between the transfer case and the skid plate???
    Port Elgin
    Ill have to measure my fan when i get home but i shaved alot off. im guessing it was only 3" thick. as for drive shaft a 16" drive shaft is common in tj's as long as you have the appropriate travel and a good SYE you should be fine, assuming your not lifting it to the sky. as for the tcase is ther any way you can clock it? i have no idea what your using, but i think DVS use to sell clocking rings for the 300 if not him im sure TMR should be.
    KUSS
    Stupid Fukin Nature
    OF4WD# 2660
    Georgetown
    Opps, wasn't looking at the pics closely enough.
    I didn't know you were using the complete cj driveline.
    You're driveshaft won't be too short as stated above if you're not going with a huge lift.
    Clocking up the transfer case and running a flat skid plate is a great idea.
    I'm assuming you have a t176 transmission???
    port lambton ont
    i have a t-5 and a t-150 with a dana 300 on both. the t-5 has a input shaft of 1 1/8" wide and 10 spline the t-150 is 10 spline 1 1/8" wide. how hard would it be to swap the t-150 to my bellhousing?
    Georgetown
    Could you double check the transfer cases? I didn't think a t150 bolted to a dana 300. Are you sure it's not the t150/dana 20 combo???
    Port Elgin
    dana 18 only wont fit a 300 t150
    Georgetown
    so it must be a dana 18 or dana 20 attached to the t150
    But remember, the dana 300 is a better transfer case
    port lambton ont
    yea its a dana 20. so im sticking with the t-5 dana 300 combo. spot welded the engine to the frame rails. have to take it to the local welder to burn it in place. next up is making a skid plate. not sure if i have the space to clock the transfer case. its about 10-12" shorter than the ax5 np231 length. so its inbetween the foot wells. not sure what to do about that.
    Apr 2006
    Dresden Ontario
    What's your intended use, tire size etc. The T5 won't live behind the 6 let alone a v8 in offroad use and larger tires. Upgrade to a stronger tranny now to save yourself a lot of time and money. Just because these are what you have doesn't make them the right choice. If you give me some details I could help you with what might be some stronger budget friendly options. By the way the Dana 300 is a better choice for low range gearing for sure. The dana 20 is fine for strength it just doesn't have as low a gear. The T150 is much stronger than the T5 but again gearing is poorer.
    1985 CJ7 Aluminum tub, 31's
    1985 CJ7 All steel
    Port Elgin
    you will need to cut out a bit of floor to clock it flat. a bit of a body lift will lessen the amount of floor you need to remove.
    port lambton ont
    going with a 360 possibly 401 if i can find one. i knew the t-5 was weak. was why i was looking into the t-150. what are better trannys that will bolt up and still use the dana 300? i currently have 27.5" of rear drive shaft. still need a pair of waggy dana 44s. tires will probably be around 35". 4" of lift plus some trimming of the sheet metal. was trying to stay away from body lifts.
    do you need insurance if your flat towing with a tow bar?
    Georgetown
    a t176 four speed may be the best bet price/easiness wise. What engine is that you're using for a mock up???
    port lambton ont
    304 v8
    Aug 2009
    smithville
    Innocent
    Time Online: 1 Day 21 Hrs 18 Mins 15 Secs
    Avg. Time Online: 9 Secs
    i have the axles u want let me know if u want to come look at them
    port lambton ont
    what are you asking for them?
