Thread: Fire proofing the tranny lines!
    Dec 2002
    CANADA EH!
    Time Online: 1 Day 21 Hrs 59 Mins 50 Secs
    Avg. Time Online: 9 Secs
    Well I learned something new over this past winter.
    I came out to the garage one day and noticed my JEEP had been bleeding. I took a closer look to find that my tranny flex lines between the frame and tranny ports were all cracked and dried up (only 2 years old).
    So at that moment I realized that high pressure fuel injection rubber hose will not stand up to the ATF (transmission fluid).
    So I once again turned to the -6 AN fittings and stainless braided rubber hose. After using it for my fuel lines I figured it was the only way to do it right and fire proof it as best as I can.
    This stuff is not cheap but you use this stuff and then never need to look at it again.
    So this is what I picked up for the job.
    Attached Thumbnails Attached Thumbnails IMG_0442.jpg   IMG_0444.jpg   IMG_0448.jpg   IMG_0451.jpg   IMG_0455.jpg
    Work hard but play harder!
    Dec 2002
    CANADA EH!
    In the first pic you can see the -6 AN fittings for the tranny ports. The second pic is of all the necessary fittings, hose and as well as the hose ends.
    Part #s keep in mind I'm using a 4L60 for a tranny.
    2 x tranny fittings to -6 to adapt to the hose ends. No part# just found them on ebay.
    10' of -6 AN hose Part#632070
    2 x 45 degree -6 hose end. Part #610090 (To attch to the Rad inner cooler)
    2 x straight -6 hose end. Part #610020 (To attach to the tranny ports)
    2 x adapter -6 fliare x 1/4" NPT. Part# 660440 (These fit into the rad ports to the inner cooler)
    One more thing off the list! CHECK
    Time Online: 10 Mths 3 Wks 5 Days 14 Hrs 2 Mins 22 Secs
    While I believe AN'ing tranny cooler lines is always a good idea, it doesn't really have anything to do with fire proofing or resistance? If exposed to high heat and/or open flames, the steel breaided line will also fail. You can add some fire sleeve to greatly increase the heat and flame resistance of it. I run some fire sleeve on AN lines that run close to certain high heat areas.
    Dec 2002
    CANADA EH!
    Thanks CTD Nut for clearing things up. Not much is fire proof but its fire proof compared to fuel injection hose and hose clamps. The hose ends and AN fittings will not leak and it will take a lot of heat before anything bad happens.
    Time Online: 11 Mths 3 Wks 1 Day 7 Hrs 31 Mins 48 Secs
    Avg. Time Online: 28 Mins 54 Secs
    Looks good, I remember your fuel line thread from last year and this is a nice addition to that...I suspect that any and every line on your rig will slowly be replaced by steel braid with AN fittings...LOL...
    Dec 2002
    CANADA EH!
    Thasnks igotafrigginjeep,
    Ya its the only way to go when its time to replace any lines for sure.
