Results 1 to 18 of 18
Thread: Project: Cheap Jeep
    Aug 2013
    Stayner
    Time Online: 2 Days 20 Hrs 52 Mins 2 Secs
    Avg. Time Online: 14 Secs
    Project: Cheap Jeep
    ok, I bought a 1990 Jeep YJ about a month ago, this is my third YJ and my first 4.2L. before i bought the jeep it had quite a life, and alot of upgrades threw the years. any way this is wht i know i have
    4" suspension lift
    Teraflex revolving shackles on the front
    the front diff gears were welded and have a cable to engage (i need to adjust cable because im not fully disengaging it)
    theres a locker in the back
    it has a full roll cage
    the front bumper has a bracket on it to hold a winch
    the rear bumper is custom built, heavy duty, with a swinging tire holder.
    1 3/4 inch body lift
    PICTURES ARE AT http://www.jeepkings.ca/forums/album.php?albumid=1304, I will keep posting pictures as I go
    now what i need to do to safety it is replace the windshield, and install a parking brake, but due to the cage theres not enough room to use a factory style one so im looking for ideas here
    the engine needs a tune up and ive never done any carb work on a car or truck so thats going to be fun
    the brakes all seem to be fine, i might put pads and shoes on just for peice of mind
    now for the fun part.... my engine dosnt leak oil, but everything else in the drive train does, and i mean EVERYTHING!!!!!!!! any tips on resealing axles, transfer case, and trans would be greatly appreaciated, i am looking for a spare tranny transfer case ect,
    the tires on it now are 215/75r15, i will be looking next week for a set of 33's or 35's on rims, cheap ($300-$350)
    i am looking for some checker plate to go along the bottom of the jeep
    i also need fender flares, mine are weather cracked and bent out of shape
    i need leaf spring plates for the front, where my sway bar hooks up the eyes are bent back and down out of shape
    what else should i be looking for? im hopeing to have it ready for the etest in a couple weeks, after i tune the engine up
    i need to find a used car dealer that is willing to come to the jeep to appraise it so i can get my temp plates and test it on the trail
    oh and one last thing, i need to adjust my brake light switch, it only works when the peddle is all the way down, any ideas on how to fix this???
    Aug 2013
    Stayner
    I have picked up my tires, I found a set of 33 12.5 15 TSL thorn bird on rims, this added a new thing to my project, I now need to build fender flares, about 8 inches wide.
    I still need to get my hands on a windshield!!!
    Aug 2013
    Wasaga Beach
    Time Online: 1 Wk 3 Days 52 Mins 1 Sec
    Avg. Time Online: 49 Secs
    looking forward to getting out for a run with you so that you can test that yj out.
    Aug 2013
    Stayner
    Got the tires put on it yesterday, the spacer lugnuts were to small for the yj so had to make a trip to crappy, tires makes this thing look mean
    I still need to get my hands on a windshield and a trans / transfer case just to make this thing drive and shift nicely, also looking for a set of decent cheap doors, mine are messed up a bit, going to cut them down to make custom half doors when I find a new set
    Aug 2013
    Stayner
    Here's a pic, covered up for our lovely long weekend of rain
    Aug 2013
    Stayner
    I still need to figure out my brake light switch, if I put the peddle all the way down the lights come on for a sec then go off again, has anyone had this issue before?
    Does anyone have a vacuum hose schematic for a 4.2? I have to start from scratch there are no hoses hooked up to my air cleaner anymore
    edmonton alberta
    Time Online: 5 Mths 6 Days 18 Mins 19 Secs
    Avg. Time Online: 12 Mins 49 Secs
    Quote Originally Posted by 90YJWRANGLERLIFTED View Post
    I have 35/12.5/15s on my yj and i have tj flares for more clearance
    Also look for a mc2100 carb and a gm hei distributor if you want it to run well
    And for that tire size you should run 4:10 gears if it's not already
    I thought life handed you lemons..... who the phuk is throwing them at my head !!!
    Aug 2013
    Stayner
    Its running 3.73's right now
    Time Online: 3 Mths 2 Days 12 Hrs 58 Mins 7 Secs
    if you want those parts i can sell you Lemons parts, he ain't got a use for them....... 4.10 gears, i will even pull his windshield and frame for you.....
    Time Online: 4 Mths 3 Days 6 Hrs 48 Mins 22 Secs
    Avg. Time Online: 10 Mins 8 Secs
    What trans you want/have now? ive got a ba10 on the bench you can have for free...come get it and a few other things if you want....and im only in Midland....ill pm you my name and number.
    edmonton alberta
    Quote Originally Posted by cheezballz12 View Post
    lol
    Feb 2013
    Hespeler
    Time Online: 3 Wks 1 Day 9 Hrs 44 Mins
    Avg. Time Online: 1 Min 50 Secs
    I'll be putting tons in mine this winter...My 90 has 4:10's but they're not for sale for a few months if you can wait
    '90 YJ Wrangler with the mighty 2.5L , 2.5" lift, and about 250K miles on her
    '10 F-150 Supercrew, 2003 TJ 4.0 (FOR SALE!!!)
    Started the 1 ton/3 fitty build, 3more lugs are good right??
    I like soup....... and beavers
    Aug 2013
    Stayner
    Got under the jeep today to see what transfer case is on it, is a 231J
    Found a place to get 8' x 2' checker plate for $40 a sheet, going to get 2 of them and cover the sides with it and build some rock sliders/steps for the wife to get in
    edmonton alberta
    No need to build anything...high heels dude 1" of heel for every 1" of lift
    Brantford ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 26 Mins 32 Secs
    Avg. Time Online: 16 Mins 9 Secs
    Quote Originally Posted by lemon View Post
    And with that 1 inch less of skirt and 1 inch less of shirt, next thing you know, you'll have Daisy Duke in the passenger seat
    IT'S TWEETER B!TCHEZ
    Quote Originally Posted by Pav1 View Post
    "PIPPI APPROVED"
    Attachment 91983
    2004 Subaru forester 2.5 turbo AWD "The General"
    1997 TJ sport Rollin' on 33's "Woah Black Betty"
    Aug 2013
    Stayner
    I dunno, a size 5.5 on a angle like that....I'll find her a pair of platform shoes 5 3/4" high
    I needed her to hold the brake when I put the spacers on and she needed to climb up on a tire to get in, I should have got a video
    edmonton alberta
    Yes
    Re: Project: Cheap Jeep
    I picked up a $7 folding step stool with and tied a string to it for my wife. Works great.
