Page 11 of 11 FirstFirst 1234567891011
Results 201 to 213 of 213
Thread: Now it's Pipi's Black Betty Build
  1. #201
    Nov 2011
    St. Thomas
    Avg. Time Online: 33 Mins 26 Secs
    I'm also curious if my whole CJ ownership plan falls through so............
    I'm doing the same so let me know if you find a safety/appraisal. Lol.
  2. #202
    I know a lady that's into that sort of thing that can help out
  3. #203
    Whitby, Ont
    Time Online: 8 Mths 3 Days 23 Hrs 10 Mins 32 Secs
    Quote Originally Posted by OverKill View Post
    I'm an adult?
    Sent from my SM-T810 using Tapatalk
    That is up for debate!
    ᄅ# pɐǝɹʇǝɹ
  4. #204
    Dec 2008
    Just North of Sudbury
    Relaxed
    Avg. Time Online: 20 Mins 30 Secs
    http://bbsimg.ngfiles.com/1/22088000...b30c1d789e.jpg
    Bet it has an engine swap...lol
    "Bite my Shiny Metal ass!"
    Retread #19
  5. #205
    Time Online: 3 Mths 2 Days 12 Hrs 58 Mins 7 Secs
    when I got BBD's done last yr which is a 95, with a 350 in it, it was nothing more than a sniff test.
  6. #206
    Beamsville
    Time Online: 3 Mths 4 Days 14 Hrs 20 Mins 13 Secs
    My 97 Tj with V8 swap was 2 speed tested via the tail pipe sniffer to 97 emissions standards this year.
    Professional lunatic
  7. #207
    May 2012
    Brantford ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 26 Mins 32 Secs
    Avg. Time Online: 16 Mins 9 Secs
    Holly Fawwk! when the poster is away the thread whores come to play! well, cheers mates
    anyways back to topic. yes lucky being an 97 it is only a sniffer test and had inquired before hand at the place i get my etests done and they said i'd be good to go. cool.
    so that being said, I am debating keeping the current '93 (OBD1?) PCM set up since its just the sniff test BUT I am not sure if after splicing the harnes's together, if the PCM will relay to my OBDII gauge cluster ? caugh caugh Cheyne lol.
    IT'S TWEETER B!TCHEZ
    "PIPPI APPROVED"
    Attachment 91983
  8. #208
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 28 Mins 55 Secs
    Quote Originally Posted by Tweeter View Post
    I' am not familiar enough with the finer points of operation of a 97 TJ gauge cluster to give an informed opinion. I would say that it is unlikely to get OBD1 and II protocols to communicate with each other since they have little in common. But I also doubt the 97 gauge cluster requires little more than a series of inputs with the correct resistance. I don't *think there is much interfacing going on in 97. I'm fairly sure CANBUS was not yet implemented so there would not be anything technically complex with gauge cluster communications in 97.
    However, from an ownership point of view, I would want the OBDII PCM for the sake of diagnostics.
    I can tell you that it will not matter what engine, wiring harness or computer you use for the swap - the same emissions rules will apply and you cannot change that. A 97 Jeep will get the tail pipe test no matter what.
  9. #209
    May 2012
    Brantford ON
    Quote Originally Posted by Pippilongstocking View Post
    I had seen a spreadsheet someone on the old interweb that had the specs of CANBUS and years. So exactly that, my thought would be that the proper splices being made would make the cluster work. Either way it would be nice to use the original cluster but we will see..
    I agree with you however on keeping it all OBDII because the diagnostics. I mean, at the end of the day it's just easier for me to find a latter OBDII PCM and be done with it. But finding one without the security chip key is the question now, if not I'll have to have it reprogrammed.
  10. #210
    OBDII started in 96. I would be skeptical that a 96 Dodge Ram would have a chip key. My loaded 99 3500 Laramie didn't. Don't quote me but I don't think those keys were available in Rams until the 3rd gens which began in 02.
  11. #211
    May 2012
    Brantford ON
    Now that's awesome news. I'll have to look into that than because if so than shytes mint!
  12. #212
    Nov 2011
    St. Thomas
    I know with the Dodge Durangos that first year for the chip key was 2001. 2000 was the last year for the 5.2 in them as well as the last year for no security key. But that's a Durango...
  13. #213
    Windsor, ON
    1997 Jeep cluster uses a CCD bus system, same as the Ram of that era. Neither used chip keys in those years.
