Results 1 to 11 of 11
Thread: Need tech help on 8.25 rear axles....
    Mar 2010
    Kingston, ON
    Time Online: 2 Days 2 Hrs 55 Mins 2 Secs
    Avg. Time Online: 10 Secs
    Hey guys, I'm wondering.... I have a rear 8.25 rear axle from a 96 2.5 xj with an open diff and 4.10's. I now have a 98 xj sport with an 8.25 rear axle and limited slip and 3.07's.
    I already know that the 96 likely has 27 spline axles and the 98 has 29 splines.... My idea is to take the limited slip and the axle shafts out of the 98 and swap them into the 96 so I can use the 4.10's.
    The 98 has 33's on 6 inches of lift with plans for 35's. the 98 axles are geared at 3.07 right now and the tire/gear calculators say I should have 3.61's on 33" tires. With plans for 35's in the near future I'd like the 4.10's instead of the 3.07's.
    My question is what do I need to change in the 96 housing to accept the limited slip and 29 spline axles from the 98? Is that even possible?
    OF4WD member # 6000
    Mar 2010
    Kingston, ON
    Its ok, I figured it out.... I need to change the carrier. Then I can have my cake and eat it too....
    Time Online: 3 Mths 2 Days 4 Hrs 14 Mins 38 Secs
    when you put it like that, you need to find out where the carier break is, its usually around 355-373 that use 2 different size carriers... rick im not sure its gonna be doable....
    ---------- Post added at 09:42 PM ---------- Previous post was at 08:35 PM ----------
    carrier is the same and the shafts should be too
    http://www.quadratec.com/jeep-replac...-8.25-rear.php
    Mar 2010
    Kingston, ON
    Huh? what do you mean, carrier break? Whats that?
    This is what I'm looking at....
    Rear Axle
    1984–1989: Dana 35, non c-clip, with anti-lock braking system (ABS) or non-ABS.
    1990–1996: Dana 35, c-clip, ABS or non-ABS.
    1997–2001: Dana 35, c-clip, ABS.
    1991–1996: Chrysler 8.25", c-clip, non-ABS, 27-spline axleshafts.
    Late 1996–2001: Chrysler 8.25", c-clip, non-ABS, 29-spline axleshafts.
    1987–1990: Dana 44, non-abs, 30-spline axleshafts.
    ---------- Post added at 10:42 PM ---------- Previous post was at 10:38 PM ----------
    Looks 50-50 to me.... The way my luck goes though, I'll owe you a steak!
    carrier break is where they usually have 2 carriers, one that goes from low to mid and then from mid to high...
    ian needed a different carrier for the new gears in the front of his truck then the stock one cause he was going from one end of the scale to the other... im not seeing anything that is showing that on yours
    the nuclear waste depository
    Time Online: 1 Wk 1 Day 13 Hrs 17 Mins 56 Secs
    I'm not 100% but I dont think the 8.25 has a carrier break
    11 F150 tow rig/ DD
    87 Sami buggy
    99 XJ RIP
    91 XJ RIP
    86 CJ5 RIP
    Time Online: 2 Wks 3 Hrs 23 Mins 55 Secs
    Avg. Time Online: 1 Min 9 Secs
    completeoffroad.com shows carrier break 2.45 / 2.56 & up
    yuccaman.com states that the carrier break on Chrysler 8.25" is
    2.45 & down / 2.56 & up
    (and) since the highest XJ gear is the 3.07 included with most manual-shift Cherokees, the numerically lower 8.25" carrier isn't seen in our applications
    So there is a carrier break for the 8.25, but not for Cherokee differentials
    "Know it all googler"
    Helping keep the XJ legend alive
    88 XJ 2.5L AMC - crushed but not forgotten
    Jun 2008
    Ottawa
    Time Online: 1 Mth 1 Wk 1 Day 12 Hrs 19 Mins 53 Secs
    Avg. Time Online: 3 Mins 10 Secs
    as steve said theres no break with the 8.25, you can swap shafts too as long as you change the spiders or lunchbox, whatever you have. just has to match up. Love this axle.
    rockwood
    Time Online: 3 Wks 6 Hrs 1 Min 57 Secs
    Avg. Time Online: 1 Min 45 Secs
    the carier has to be changed if you use 29 spline axles they don't fit through a 27 spline carrier i tried!
    Jun 2008
    Ottawa
    Quote Originally Posted by DoctorPhate View Post
    Quote Originally Posted by giezy View Post
    My bad, I meant to write Spiders & carrier, or lunchbox. good catch. lol
    hes using the 29 carrier and shafts, just the gears out of the 27 cause they are 4.10
