Thread: toyota body lift
    north york.
    toyota body lift
    i recently did a body lift on my 4runner and took some pics
    http://s141.photobucket.com/albums/r...20body%20lift/
    Guelph, Ontario, Canada
    Time Online: 1 Wk 2 Days 15 Hrs 50 Mins 3 Secs
    Avg. Time Online: 47 Secs
    Looking good. Did you just weld that bar on the front with the hitch?
    '87 4Runner, slightly llifted and lots of fun!!!
    north york.
    It was done before the lift, welded and
    bolted with 4 bolts
    I might just have to borrow that idea from you!
    north york.
    Go get the hitch you want measure the thickness
    then remove 1 bolt from the front that hold these round
    things there, so you can get the right thread, buy longer
    bolts, cut off the ends of the hitch , measure and drill holes
    that line up to exhausting threaded parts, bolt on and weld
    Easy as pie, good luck it's a good project
    I will give it a try, it is now on the list. I already have a spare hitch I can use. Thanks.
