Results 1 to 20 of 27
Thread: OBA anyone?
    OBA anyone?
    Many thanks to Eric and Billy at Staang's Fab for the development/fabrication of the York Compressor Mount. This is something I have been piecing together for about a year now and the bracket and installation of the compressor is a major step in getting this system up and running.
    This adds the York and runs it off the serpentine belt drive with all the other engine driven accessories, no need for a second belt. It does need a longer belt and relocates the alternator down lower (below the York), but does not eliminate anything (eg. stock a/c system).
    This bracket will work on 2000 - 2006 TJ/LJ with 4.0L with or without A/C.
    Staang's has this available as a bracket kit for $225. Includes the bracket, hardware, and belt. Add your compressor, tank, fittings, and lines.
    I will update this thread with more pics and feedback once I have the full system up and running and have given it a full workout.
    Apr 2004
    Grimsby, Ont.
    Avg. Time Online: 9 Mins 21 Secs
    very cool!
    #20OF4WD#3476
    "Will roll over for treats"
    Feb 2006
    caledonia
    nice
    As a side note...this bracket works with large case 160 amp alternator upgrade, in case you have already done that swap or want to do it in the future.
    hamilton/norfolk
    Time Online: 4 Mths 1 Wk 4 Days 17 Hrs 32 Mins 32 Secs
    Avg. Time Online: 10 Mins 51 Secs
    very nice set up, cant wait to see it all put togeter
    Quote Originally Posted by Mayheminc View Post
    Life is good in the republic of bacon
    RETREAD #9
    Better pictures are required Jeff. But nice upgrade.
    Milton
    Avg. Time Online: 4 Mins 45 Secs
    Looks good Jeff.... another great job by the boys at Staang's Fab.
    Any of your pulleys have less belt wrap?
    OF4WD Member # 5887
    For Sale:
    Coming Soon:
    Quote Originally Posted by EngineerJoe View Post
    Not at all...it is too tight in there to get really good pics to show the belt wrap, but next time you see the Jeep you can have a look...
    Will get some better pics up here as soon as I have a chance...
    Time Online: 2 Yrs 1 Mth 3 Wks 3 Days 21 Hrs 34 Mins 42 Secs
    Avg. Time Online: 1 Hr 4 Mins 44 Secs
    right on jeff
    Okay...you guys twisted my arm...here is a few more pics...
    Below is a shot looking straight down between the compressor/bracket and the stock (and completely unmodified) airbox...the nice shiney new bolts/nuts you see further down are the adjustment bolts as the York is now the belt tensioner and the OEM spring loaded tensioner (that is prone to failure) is eliminated, the pulley itself from the OEM tensioner is reused as an idler for belt routing purposes...the crusty old bolts you see up top were original York mounting bolts that came with the compressor when it was pulled from the donor vehicle (1978 T-bird) and will be removed as they are not needed...there is approx 1/4" clearance between the adjustment bolts and the airbox...plenty of clearance...
    This one is for Joe, so he can see the belt wrap...the only changes to belt routing are shown in this picture...
    Here is a few pics to show the bracket and how it mounts...it completely replaces the factory alternator mount...the OEM mount gets unbolted from the block and the original mounting holes are reused to mount the Staang's Fab bracket...
    In that last pic you can see the alternator tucked under the bracket...
    Neither myself nor Eric thought to get any pics of the bracket prior to install, but Eric has said he will put a 3D CAD rendering of the bracket up in this thread...being a part of the whole experience from thought, through design, to finished product was very interesting...the amount of time that goes into the initial stages of development with the amount of measurements that need to be taken and quick sketch diagrams, then onto plugging it all into the computer, seeing the renderings, having it sent for laser cutting/bending/etc., and finally the install...top notch work from a couple great guys...
    I am very pleased with the end result...I will give it a bit of a test this weekend, then it will be time to pick up a few more items for the system, run some lines and install the tanks...
    The plan is to run hard lines from the compressor to two separate tanks...a smaller (approx. 2 gallon tank) mounted under the body to remain in the Jeep all the time and a second larger (10 - 12 gallon) tank that will be removable so it can be quickly installed for wheeling weekends when the potential for more air volume will be required, but removed for daily driving...this second tank will be mounted up top where it will be easily accessible...There will be two quick disconnects, one under the hood and a second inside the back corner of the tub, this quick disconnect will be where the secondary tank connects to the system and the tank itself will have a quick disconnect for hooking up whatever tools may be required...
    ---------- Post added at 08:20 PM ---------- Previous post was at 08:09 PM ----------
    As I said, the compressor came from a 78 T-bird, the serpentine clutch came from an International rig and was picked up from Freelton Truck Parts along with the larger tank (these guys had a huge pile of air tanks of varying sizes to choose from), the smaller tank was salvaged from a small jobsite compressor that had a smoked pump...fittings and miscellaneous parts were purchased from the pneumatic and hydraulic sections at Princess Auto...the plan is to have this system run at 145 psi max (pressure switch will be on at 110, off at 145)...all in, once it is up and running 100% I will be into this for approx $600, less than half what Kilby wants for their full system and I will have 10 times the air volume and don't have to deal with the cross border shipping as they do not have a network of dealers (buy direct only)...
    Eric mentioned today that if somebody wanted to go full out (and not deal with the piecing together of a system on their own) he could supply the whole system (including a brand new compressor) and do the install for you...there was no mention of price for a full system, but if you are interested give the guys a call...
    Looks killer. Alot more belt wrap then I have on my SBC and I still have no problems.
    Looks good Jeff.
    you mentioned that you would be using hard lines ffrom the compressor to the tanks.... are you planning to put a short link of soft lines to allow for engine movement?
    I will be using the soft bendable copper tubing, so not a traditional HARD line...the tubing I will be using is rated for refrigeration and home a/c units, my research shows it is rated for 300+ psi so I am confident I will not have any issues...as for the engine movement versus body/frame non movement, I will be putting loops in (similar to what you would see on brake lines at the master cylinder) to account for that...there will be a loop before the filter/check valve/manifold setup (under the hood) and a second loop under the Jeep where the smaller tank will be mounted as the line will be mounted to the frame and the tank will be bolted to the tub.
    I may replace the fittings at the compressor...the big honkin' silver ones seen in this pic...
    They are not the "proper" fittings for an OBA setup to convert the "oddball" old school compressor fittings to an NPT fitting for air use, but they seem to be doing the job so far (gave it a test run sans tank this morning)...my issue is with how far they stick up...these things are huge...although they are not contacting the actual hood, they are rubbing on the underhood installation (partially because of the size and partially because the insulation is saggy)...didn't really want to drop the $45+shipping/taxes to get the fittings from Kilby (the insert with the o-ring is the PROPER style for the compressor I have) when the fittings I currently have (which have a compression end that so far seems to be sealing well) cost me $10...we will see how that goes in the future...
    I would advise against using any type of hard line for connection from the body to the engine. I will assure you that the line will break maybe not right away but as copper flexes it will harden then eventually fail, even the soft stuff.
    look into high pressure rubber lines to get you between the two. It may add to your cost but it will prevent a 145PSI leak under the hood.
    Remember that brake lines to master cylinder do not see any movement. other than the slight change from the internal pressure.
    ^^ Agreed. A piece of braided steel line 6-12" long would work for years without failure. You could probably grab one from a air compressor supply place. I used the factory line from my Toyota compressor for about 4', then went to 300psi poly. No problems sealing or blowing off, 125psi working pressure.
    Gave the York a good test this weekend...still have it setup with a quick connect at the compressor head, no tank or lines yet...
    Blew a bead up in Ardbeg, just the outer...jacked the axle up to get the tire off the ground, hooked up a locking tire chuck, turned the compressor on, pulled the outer bead up over the valve stem and within a minute the tire was back on the rim and at the pressure...
    At the end of the weekend, aired back up...took all four tires from 6 - 12 psi (gotta love slow leaks) up to 20 psi in under 3 minutes, including screwing around with walking around the jeep to get to each tire...I will have to make an octopus to do all the tires at the same time and then do a real timed test once the tanks are installed...
    I'm using 4' of hydraulic line off the Kilby (worth it) fittings on the compressor to a water separator/pressure regulator. I have a 2 gallon tank and can run a 1/2" impact off it with the idol cranked up a bit. Changing 4 tires and 64 lug nuts is a breeze! 10-12 gallon is a waste and space pig and not needed if you can adjust your idol.
    The only thing I ever have to do with my York is top up the oil every once in a while. But mine sees way more severe abuse than yours ever will with 4 airbags and a twitchy thumb on the controller.
    Any other compressor is a waste of money.
    Courtice, ON
    what other compressor would someone buy to install as OBA?
    insert something witty here
    I've wasted money on Chinese dual head compressors, Viair 450, etc.
    The Chinese thing lasted a month with airbags, the Viair was an exspensive and slow waste of money.
    York 210 is the best thing you can find.
    I've even seen people attempt to do OBA with the $20 Chinbodian Trash special that takes half an hour to inflate a minivan tire...some people just don't get it...
    Chris...I am going to guess the answer will be no, but I have to ask...any issue with the hydraulic lines and air leaks? I had a 'hydraulic expert' tell me that hydraulic hose "breathes" and they would leak air...
    I am thinking the Kilby Tube-O to NPT fittings will be in order...it will just make it cleaner...
    I did notice (read ---> hear) a leak underhood when the compressor was running, obviously the leak got louder as the pressure got higher, but I have not looked further into where and why as it was a quick setup for the weekend and I do not foresee using it for at least a few more weeks, so I have a bit of time to look into it...hopefully I can have it fully plumbed before the next use...
