Results 1 to 15 of 15
Thread: Pic and Info on my 89 YJ Project
    Jul 2011
    Northern Ontario
    Time Online: 2 Days 9 Hrs 13 Mins 39 Secs
    Avg. Time Online: 11 Secs
    Hi to all, just thought I would start a small build thread. My Jeep is comming along quite well and am glad I have it mostly torn down and am starting to put it back together. I am just goin to start with some pics and will give some info along the way. Comments and suggestions are encouraged.
    Attached Thumbnails Attached Thumbnails DSCF0795.jpg   DSCF0797.jpg   DSCF0810.jpg   DSCF0806.jpg   DSCF0805.jpg
    Jul 2011
    Northern Ontario
    The next jobs are to remove my transfer case, rear springs, and put the gears in the rear diff, and I will also be pulling the cover of the front diff. Once the transfer case is out I will be splitting it open so I can install my slip yoke eliminator kit. The rear springs are shot and will be putting in a different set, up front when I changed them it brought the front end up almost 4" they were very badly bent. I will have a new learning experience as this will be the first time doing gears. When checking the front U-Joint I noticed that there was to much play in the shaft so I would guess that the bearing on the output shaft is in need of replacement.
    I also included a pic of my daily driver 02 Corolla.
    Later,
    CY
    Attached Thumbnails Attached Thumbnails 1107241105000.jpg   1107031648000.jpg   1105070837000.jpg
    Jul 2011
    Northern Ontario
    Do you need the front and rear track bar? I the one pic you can see I found a crack in the frame. I have to cut the braket off for the rear also noticed on the front track bar the bolt was snapped in half so I am just going to remove it. Do I have to replace them before it is ok to drive?
    Cant wait to pick up and get my new mud treads on!
    Attached Thumbnails Attached Thumbnails 1107301927000.jpg   1107282106000.jpg   1107311125000.jpg
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 1 Hr 42 Mins 37 Secs
    what r u planning to do about the crack in the frame? Looks bad... This would be top priority. IMO
    Time Online: 1 Wk 3 Days 13 Hrs 4 Mins 46 Secs
    Avg. Time Online: 52 Secs
    Shawn was thinking the same thing , dont worry about shoes
    Jul 2011
    Northern Ontario
    As soon as I saw the crack that was number one proirity. I made arrangements for someone to come over and weld it. I had to remove the rear track bar to get the back side of the frame fixed. There is a whole spider web of cracks. I am having a new metal box welded to support the frame there. I have removed the shock and exhaust today to give as much room as possible to get a solid weld in there. That is why I am asking about the rear track bar Do I need to weld it back to my new "frame"? I cant put of the shoes because this project needs to be completed ASAP. Hoping the weld gets done tomorrow and I can put the last new spring in and start checking off the completed things instead of adding to the list. Going to do a search on a couple of things like frame repair and track bar.
    Thanks for making sure that The frame was being looked after,
    CY
    Newmarket, ON
    Time Online: 2 Wks 2 Days 7 Hrs 38 Mins 21 Secs
    I just recently cut both my track bars in half and disconnected my anti sway bars and have been driving for a few weeks like that now. I like it better. From what I've read, the leafs do a fine job of locating the axle and so the trac bars are not needed. The anti-sway bars should be connected however. I'm going to connect mine as soon as I'm done this beer. Or maybe after the next one.
    A minute passed then another. Then another minute. Then - another minute passed. Then another minute passed and another. A further minute passed quickly followed by another minute when suddenly -a different minute passed followed by another different minute and another and yet another further different minute, passed.
    Jul 2011
    Northern Ontario
    That is what I have read as well. Yesterday I removed the anti sway bar and have thrown it in the pile "to be determined later". Thought about getting quick discontects but figured I would never hook them up anyways. I am using it as a toy and will likely only drive it on the hwy if going to a trail. I just noticed I dont have much info about the suspension here. I have a Spring over and a 2" body lift. I am going to be putting on some 33" Boggers. In the pics it has 31" BFG All Terains. Thinking for the exhaust I will just put on a cheap cherry bomb.
    Jul 2011
    Northern Ontario
    Thought I would just put a quick update on here so I could read it later.lol
    I have scrapped the cherry bomb idea and decided I will deal with exhaust next year and just get a header and flowmaster. Have had a few welders come by and think I have found the guy I want to weld it up. (the last guy became a little to busy and just ended up not working for us). I have the complete inside tub painted with paintable undercaoting. I did use 2 coats of primer, 2 of undercaoting and a layer of paint which I didnt like so 2 more of undercoat. Looking for a bench seat to put in it, and an aftermarket carb.
    I have the rear diff rebuilt and just put new u joints in the old shafts to take it for a drive for the break in time for the gears, then will get the transfer case and SYE in.
    Here are some pics
    Attached Thumbnails Attached Thumbnails 1108071153000.jpg   1108081811000.jpg   1108081759000.jpg   1108081805000.jpg
    Aug 2011
    Mono,ON
    Relaxed
    Time Online: 1 Day 5 Hrs 16 Mins 6 Secs
    Nice build , good job !! I also just bought a 89 YJ , and its alittle rough , your build is very inspireing . I need to do alot of the same stuff ...lol...must be a YJ thing.
    Jul 2011
    Northern Ontario
    Just some pics. Looks like I might even get to drive the jeep soon!
    Attached Thumbnails Attached Thumbnails 1108201337000.jpg   1108201556000.jpg   1108201135000.jpg
    Jul 2011
    Northern Ontario
    Thought I would do a little update. I have taken a week off from the build to spend time with the kid. Completed all the paper work and few more hours of work and it will be a drivable project.
    Attached Thumbnails Attached Thumbnails 1108281840000.jpg   1108281841000.jpg   Copy of 1108282011000.jpg
    May 2011
    Smiths Falls on
    Time Online: 1 Day 15 Hrs 51 Mins 4 Secs
    Avg. Time Online: 8 Secs
    good looking yj. it looked like hell though until you did the most important mod... the national 4 wheel drive stickers
    Jul 2011
    Northern Ontario
    So round two here, after driving it around for a little bit I have decided to tear it down and make a few changes. I have changed the timing cleaned the carb and set it a bit as I found out it had a stalling problem. Threw another rear drive shaft and still had yet to put the SYE kit on. Today was a producive day, I took out the transfer case and because I had to drain the tranny (nice clean fluid and filter was alright to) finaly something I didnt have to fix. I cleaned it up and put a new tranny filter on. Have the transfer case ready to split in 2 but didnt have a 12 point 10mm. I put it hand tight and am going to take the transfer case to the car wash.
    Jul 2011
    Northern Ontario
ID:	95618Click image for larger version.
ID:	95617Click image for larger version.
ID:	95619Click image for larger version.
    Long lost thread some updated pics of my never ending YJ build
