Results 1 to 14 of 14
Thread: My cheveep
    rockwood, ontario
    Time Online: 1 Wk 6 Days 20 Hrs 10 Mins 45 Secs
    My cheveep
    I am building a 88 yj with full chevy driveline from an fullsize 1990 gmc jimmy. Which mean this is only an off road toy. so it got 38.5 super swappers on 10 inch wide rims with 4.5 inches off backspace. as for axles just picked for built chevy axles 10 bolt in front with high steer arb locker warn manual hubs and 488 with yukon shafts for the rear 12 bolt with detriot lock with 488 and yokon shafts. suspension and 3.5 inch lift yj leaf spring with 4 inch blocks. i put 2 inch body blocks just to make room for the trans mount and 350 just to be safe, and it makes it so much easier to work on! i had to make a custom trans mount to have front driveshaft clearance. its got an tbi 350 3 speed trans and chevy 242 transfer case. headers on the way other than that stock for now as i want to complete before getting insane! steering is the jeep steering column with jeep shaft and believe it or not bolts right up to chevy steering box. just putting on the frame now.
ID:	71877Click image for larger version.
ID:	71878Click image for larger version.
ID:	71879Click image for larger version.
ID:	71880Click image for larger version.
ID:	71881Click image for larger version.
ID:	71882Click image for larger version.
ID:	71883Click image for larger version.
    other than that i will post as i contiune on my way
    Sep 2009
    Time Online: 2 Mths 3 Wks 1 Day 6 Hrs 9 Mins 6 Secs
    Avg. Time Online: 6 Mins 47 Secs
    Might just be the way it looks in the photo but do you have some type of bushing for trans mount or is it connected directly to the cross-member?
    rockwood, ontario
    no mount i went with solid mounted everything trying it as an experiment i just wanted it to be all solid
    Time Online: 3 Mths 1 Wk 3 Days 13 Hrs 42 Mins 45 Secs
    i know its a off road only truck, but lift blocks in the front is really a no-no. the truck is probably going to be tall enough without them.
    rockwood, ontario
    ya i know they are an problem put i am going to build trac bar front and rear to stop axle wrap and if then they are to bad i will take them out nothing is final. i just when with stuff i had lying around to keep cost down
    Sep 2009
    Hopefully you don't crack the housing
    rockwood, ontario
    i always have and up side to things if that happens i get to upgrade and beside it on the steel adpater between to trans and tranfer case
    rockwood, ontario
    update took everyone advie cause it scared me and took front blocks out and putting in extra leafs. also change axles to 10 bolt front and 12 rear both built arb locker in front with manual hub and detriot lock in rear with 488 and crome moly shafts. and also add high steer with hydro steering asist
    May 2005
    Up the Hill from "Shrek's Swamp" and down the road from "Cultural Hub of the universe"
    Time Online: 1 Wk 6 Days 9 Hrs 14 Mins 15 Secs
    Avg. Time Online: 1 Min 6 Secs
    Why so high............looking to fall over?
    I have waggy springs SOA with a body lift and clearing 42's
    Might wanna rethink the rear axle position, and run a shorter t-case too. You got a bad angle there.
    86 CJ Juggy
    67 Chevy Step side
    79 C20
    rockwood, ontario
    all diff angle have been taking care of they were just set in place in the pics
    Jul 2009
    HAMILTON
    Time Online: 1 Wk 3 Days 20 Hrs 26 Mins 47 Secs
    Avg. Time Online: 53 Secs
    get rid of the solid mounts! wtf? 35o trans are prone to cracking in the bellhousing area if you make any good power.
    get some real motor mounts/trans mounts. bubb
    somewhere
    Avg. Time Online: 15 Mins 1 Sec
    Wow.... uhm.... wow....
    I hope you like changing transmissions. Solid mounting a drivetrain like that is only done in full tube chassis buggies and racers. Your way-too-high YJ has a flexible frame and will break the tranny tail housing the first weekend out. I've done it and I had tranny mounts, 2 to be exact. Even having to two mounts was too stiff and the tail housing snapped off.
    Sent from iThingy
    rockwood, ontario
    ya i know i have change it i just havn't had the time to update thread
