Results 1 to 20 of 34
Thread: Hec's 99 2dr Jimmy Build
    Sep 2006
    London ON
    Time Online: 1 Day 16 Hrs 2 Mins 19 Secs
    Avg. Time Online: 8 Secs
    i know its not a jeep but no reason we all cant get along right? lol
    i bought it about 2 weeks ago pretty much stock except for a rearend from a 2005 with a gu6 eaton g80 locker and a magnaflow muffler
    got her in the garage and it started to piss out gas right above the gas tank as soon as i was lining it up on the hoist
    i knida like the stitches... after a few beers in the shop some friends and i call her Frankenstein lol
    this is more of a fixing thread right now as im getting it ready for safety/etest but good stuff will come trust me lol
    so far replaced rear calipers with rebuilt ones, rear pads/rotors, front pads, ALL brake lines, couple gas line patches and still need to get front upper/lower ball joints, sway bar links and maybe front flex hoses
    my 2" rear shackles arrived last week, fronts getting the T-bar cranked and upper BJs flipped
    i love these trucks,just tear the ifs out and throw in a solid axle. you will be much happier!
    Sep 2006
    London ON
    might be something to do in the future but right now i need it ready for the winter so my other car can be parked for the winter and i can get my lowering suspension in it :P
    not the best summer car but it will do for now lol
    picked up a Lincoln 140 today which should help with some future projects
    and also got some rims/tires from a fellow jeep king member today, thanks again Dean
    Sep 2006
    London ON
    so its been a slow process but the trucks finally out of the shop and hopefully going for safety/estest this week!
    i got around to testing fitting the new rims/tires
    and horrible news, i didnt double check my sources for bolt patterns and these wont work so if anyone wants some 15x8 5x4.5 3.75" backspacing pro comp d window rims let me know
    i ended up grabbing some irocs this weekend to mount my 31s on to
    new push bar and lights
    and a shot with my 2 babies
    Irocs are getting refinished in either black/polished or gunmetal/polished oh and 2" body lift got ordered this weekend!
    Nov 2011
    St. Thomas
    Avg. Time Online: 33 Mins 22 Secs
    HeC, why do we always seem to end up on the same forums? LOL. Good little thread ya got going, I'll have to keep an eye on it!
    Sep 2006
    London ON
    lol you must be following me, ive been on here for awhile
    well all the toys are finally here for the truck, i think i wanna get it safetied before i put the lift in though
    thought the warning was kinda funny
    gas lines were the only thing keeping me from driving the truck, after alot of swearing and cut knuckles trying to get the "quick" disconnects off under the truck i just decided to drop the tank and figured might aswell undercoat it and the rest of the underbody
    still needs to be lifted and tires put on but feels good to drive after all the hrs i put into her
    Sep 2006
    London ON
    body lift should be done tomorrow!
    Nov 2011
    St. Thomas
    IF you get that last bolt out lol. Then you have to check for everything reaching where its supposed to...
    Sep 2006
    London ON
    so ****ing mad right now! trucks in pieces and every body mount except 1 is loose, i have a stripped bolt and CT,PA, facca all dont sell a 15mm bolt extractor for some odd reason all the kits jump from 14-16mm and its in a tight spot so i dont think i can use the drill extractor type
    im not sure what to do so i might cut a hole in the floor and hope i can cut/grind the bolt out and then figure out a way to fix it later lol i have a MIG to patch it back up afterwards... i really dont wanna put the truck back together with no body lift in
    Nov 2011
    St. Thomas
    Is it that bolt head you are having troubles with? If so have you thought about drilling it out and using a male easy out? probably not enough torque though. Also what about welding something to it to turn it?
    Sep 2006
    London ON
    no space to drill IMO unless i dropped the axle
    BFH, 9/16ths socket and 2.5' breaker bar
    Sep 2006
    London ON
    i can fit my head in the wheel wells now lol
    what a bitch to tape
    lookin good. good to see you didn't give up on that bolt.
    Sep 2006
    London ON
    thanks, and i was pretty damn close to putting the truck back together and selling the bodylift... glad i didnt lol
    i love how they turned out, to bad i cant mount them cause the idiot that installed/balanced the tires for me lastweek just stuck the sticky weights ontop of dirt and 1 just fell off from sitting in the cold in the garage and another feels loose
    Nov 2011
    St. Thomas
    Like I said on facebook... Remind me to never go there! They look good though! Should look real good on the Jimmy!
    Sep 2006
    London ON
    tireshop redid 2 rims for me today so i finally got them on
    Nov 2011
    St. Thomas
    That's it? That's the only pic? WTF!
    Sep 2006
    London ON
    lol only had this one and the one you saw on BBM and that wasnt even a full shot of the truck so didnt bother with it
    definitely need to order some spacers for the rear and put my center caps on
    everyone said 31x10.5s would clear with a 2" body lift..... dont believe everything u read on the net! lol BFH fixed this issue
    Nov 2011
    St. Thomas
    Excuse me sir, your frame is showing. LOL
    Is that with the wheel turned or straight on?
    Sep 2006
    London ON
    atleast most of the frame/underbody is undercoated black lol
    and thats with the wheel turned but not fully, BFH seemed to fix it for driving except in reverse and it was only the passenger side that rubbed :S
    also i noticed my front bumper looked saggy on the driver side and sure enough its cracked lol looks like its gonna look like the passenger side now with the stitches and i think there might be a custom bumper build in the future
