Results 1 to 4 of 4
Thread: 4.0l high output 6 cylinder to high of idle?
    Oct 2011
    petrolia
    Time Online: 12 Hrs 11 Mins 18 Secs
    i recently bought a 1990 jeep yj and the original carbonated engine that was in it got switched out for this 4.0l high output engine but it idles around 900 rpm's and will get a little jumpy when i put it in drive. Is this normal for this engine? I was just concerned cause know most all vehicles idle around 500rpm.
    Sep 2006
    Acton / Mississauga
    Time Online: 1 Mth 2 Wks 1 Day 3 Mins 52 Secs
    your tps may be acting up. ow does it run otherwise
    Halton Hills
    Time Online: 3 Wks 1 Day 17 Hrs 50 Mins 22 Secs
    Avg. Time Online: 1 Min 51 Secs
    are you sure it is the HO or is it the RENIX? those renix engines are known to idle a little higher
    couple jeeps
    Avg. Time Online: 2 Mins 6 Secs
    My old Renix would rev high when i started it sometimes, and some times just whenever. I would just open the hood and unplug the TPS for a second, or two on the throttle body while it was running, and it would calm down. Never did persue a real fix for it myself. Never had the same problem with my HO.
    1991 Xj Gone to a new home.
    OF4WD #6069
