Page 12 of 16 FirstFirst 12345678910111213141516 LastLast
Results 221 to 240 of 318
  1. #221
    Sep 2002
    Redacted
    Time Online: 4 Wks 1 Day 8 Hrs 33 Mins 45 Secs
    Not a clue on the output Driz. I have the headlight wiring/relay upgrade and run 80/100 Hella H4 bulbs so I should be okay.
    Countryboy.....the ones I've looked at from hotrod sites state "DOT compliant" so I would assume they will pass safety.
    PAX ARMIS ACQUIRITUR
    Project Sandstorm Remix
  2. #222
    Aurora
    Mellow
    Time Online: 1 Mth 1 Day 7 Hrs 49 Mins 29 Secs
    Avg. Time Online: 2 Mins 34 Secs
    Vince, I had HIDs in mine and you couldn't see the turn signal when the lights were on.
  3. #223
    Sep 2002
    Redacted
    Thanks for the heads up Colin!
    I'm hoping the LED version would have brighter signals/markers. I've only got halogen lights too. I'm not 100% on getting a set yet.
  4. #224
    Sep 2002
    Redacted
    Installed my new RadFlo coilvers and PAC Racing springs that I got from TMR Customs today! With Timberlake's help all went smoothly.
  5. #225
    Ottawa Valley
    Time Online: 2 Mths 4 Wks 21 Hrs 47 Mins 34 Secs
    Avg. Time Online: 7 Mins 18 Secs
    Glad to help brother!
    The OG HOISTWAGON
  6. #226
    Avg. Time Online: 43 Mins 36 Secs
    Re: Project Sandstorm REMIX
    Looks slick
  7. #227
    Mar 2010
    www.jeepcentral.ca
    Time Online: 3 Wks 5 Days 1 Hr 40 Mins 29 Secs
    Avg. Time Online: 2 Mins 8 Secs
  8. #228
    May 2011
    eganville
    looks good any pics proving timberlake worked on it (its hard to belive )
    91 Renagade
  9. #229
    Sep 2002
    Redacted
    Ordered Blue Torch Fab's comp-corners, LED tail lights, and GenRight license plate bracket/lights today.
    Very impressed with the customer service from BTF and GenRight , I would definitely order from them again!
    My TMR Customs stretch rocker guards should be done this week as well!
    Can't wait to get my goodies and install them!
  10. #230
    Sep 2002
    Redacted
    So I installed the BlueTorch fab comp corners. Not too bad an install....some of the holes for their guards are not very well thought-out. 4 from each side required the use of nutserts.....which is fine except that they are not provided in the kit. Two of the holes are right on the seam at the back of the tub which required grinding the seam down on the inside of the tub....right behind the roll bar....which is a pain in the ass. The guards are well made, they fit the body very well and I am very happy with the look of the cut.
    Painted them tan and installed some trick stop/turn/tail/reverse all in one LEDs and GenRight's licence plate bracket with stop light and plate light.
  11. #231
    Sep 2002
    Redacted
    Cut my old tube adapters off the front control arms and installed TMR Customs new hex-head tube adapters so I could get the front axle back an inch.
    Ran it in the CrawlFest competition at Trudeau Park this weekend! Had a blast! Very well run event with volunteers that were fun and friendly. Can't wait to go back next year!
    Of course I had to pose.....should have listened to Timberlake and gone up higher....but whatever....still....nothing hit or smashed so I guess my work to clear everything paid off!
  12. #232
    Looks good man, wish those hex tube adapters had been out when I did my arms... Oh well, another time.
  13. #233
    Sep 2002
    Redacted
    Got it out on Timbers and The Rock this weekend. Had a blast. After all the clearancing issues I did on the front end I was surprised that it stuffed right up into the fender and nothing hit! So happy! The draglink is binding up at full droop but that is to be expected until I get around to having TMR Customs machine my knuckle and bolt on their new high-steer arms for my late model 60. Enough talk pics!
    Flexing like a boss:
    Flashing gang signs lol:
    Concentrating:
  14. #234
    Sep 2002
    Redacted
    Started working on a little project...here are two teasers....we'll get the rest up when it's done and revealed!
    Last but not least....a winter project:
  15. #235
    Ottawa Valley
    About damn time you got some proper fenders^
  16. #236
    Sep 2002
    Redacted
    Finally painted up and installed the fenders!
    Painted the fairlead light mount
    Painted and installed TMR Customs **NEW** stinger front bumper!
  17. #237
    Sep 2002
    Redacted
    Ran Phil Factor 2013 and got some decent pics!
  18. #238
    Sep 2002
    Redacted
    Just a little actual tech to update....had to replace my front hub-nut hardware today. The Dana 60 1997 model era axles have a two-nut and one "hex-lock" washer system to retain the hub onto the spindle. Well when I had originally installed it I broke the nipple off on the the nuts.
    Here is the new nut and you can see the new nipple on the bottom of the nut just left of center:
    On goes the hex-washer lining up the groove AND the hole for the nipple:
    After that you can install the second nut which is there to hold everything tight!
    Also changed my belt.....was it really so bad.....oh....yeah....
    Looking mean with the new TMR Customs bumper on there!
  19. #239
    Aug 2007
    Ingersoll ON
    Quote Originally Posted by Punisher-One View Post
    where did you get dem tail lights??
  20. #240
    Sep 2002
    Redacted
    Some tow-truck website in the states. I've never seen them before so they are pretty unique!
