Page 6 of 16 FirstFirst 12345678910111213141516 LastLast
Results 101 to 120 of 318
  1. #101
    Osgoode area
    Ya spend hours setting up the blocks and jacks and what not to get it all up off the ground and then this shiat happens... Been there done that. For me it was with the tranny/TC setup.. Fakkkk it was a pisser to get that far and have that kind of setback occur.
    Because of this and nothing else, all mechanically inclined men should by default have 12' ceilings in their garages and a lift. lol!
  2. #102
    Sep 2002
    Redacted
    Time Online: 4 Wks 1 Day 7 Hrs 26 Mins 43 Secs
    I'm just pissed that $50 of welding gas has run out a month after getting it.
    I shouldn't have to turn the gas off at the bottle if the welder is off.....so now it makes me wonder if there is a problem with the welder itself leaking gas or if it is just the fact that my garage isn't heated and it's expansion/contraction causing the leak.
    Regardless I will be turning the bottle off from now on and when I get the gas refilled tomorrow I'll ask the guys at the welding supply shop their opinion.
    Picking up all my johnnies and tube adapters tomorrow night as well. Hopefully...and I say hopefully I can have the rear end at least mocked up by the time I go back in for shift on Wednesday.
    Finger crossed....fingers crossed.....
    PAX ARMIS ACQUIRITUR
    Project Sandstorm Remix
  3. #103
    Turn your gas off buddy
  4. #104
    Old Chinese dude once said something like " He who leaves bottle valve open,buys new gas often"
    or something like that
    Oxy acetylene can do the same from my experience, did with my older setup anyway.
    I like the piece of mind that Sunday morning when I want to cut or weld I'll have gas, so I always shut them off
  5. #105
    Sep 2002
    Redacted
    For sure from now on lol. Stupid mistake.
  6. #106
    Sep 2002
    Redacted
    Got much more done tonight! Hit it hard today....Curt's speed is making me jealous!
    1/4" wall D.O.M for the lower links and some johnnies posing!
    Lower control arm 10degree mounts burned tacked in place.
    Cutting D.O.M to make some links!
    LINKS SON!
    TMR lower spring buckets built and welded like a boss!
    Buckets and link mounts tacked in place....god I hope my measurements are right....
    Ready to roll under and check the fit!
  7. #107
    Sep 2002
    Redacted
    TMR diff cover personalized a little bit!
    Close up of a weld I am proud of! Buckets went together mint! These things are 1.4" beef!
    I'm loving the TMR skulls! I think they are going to be the theme for my build....everywhere I can fit them! Give it that "punisher" touch.
    Going to get on the upper links...1/8" wall D.O.M tomorrow....get the tabs tacked on the top of the truss....gotta head up to TMR to get my "custom" upper 20degree angled spring buckets made up!
  8. #108
    Nice progress buddy! Keep it coming
  9. #109
    Sep 2002
    Redacted
    Unfortunately quite literally no progress today.
    Spent four hours realizing my brackets for the coils were from a bad measurement off the factory axle. Had to get it all under there to figure that out....knocked them off and re measured everything...hopefully got it right.
    Too much frustration today.
    Measuring gets me...no matter how many times I measure I never seem to get it right...I enjoy welding and I enjoy making things but the measuring kills me! Nothing like taking a whole day to realize you measure wrong, re-measure it, knock off your tacks, re-measure 10x to make sure it's right, re-tack, look at it and have it still look off!!!!
  10. #110
    Sep 2002
    Redacted
    Well after a lengthy conversation with TMR it seems they have solved my measurement issue. It was, obviously, a measuring error on my part by 1/4" on one of my spring buckets. So basically one is correct and one is 1/4" too close to the diff housing. Unfortunately I go back to work tomorrow and can't work on it until next week!
    So on the agenda for next week is getting that one bucket off (breaking the tacks shouldn't be an issue) and re measuring and getting it on in the right spot. Then I can finally mock up the upper links and tack the upper mounts onto the top of the truss. Once that is, hopefully, done I can cycle the axle and check to see that everything works. Once that is done I can burn everything in!
    Fingers crossed.
  11. #111
    Ottawa Valley
    Time Online: 2 Mths 4 Wks 21 Hrs 47 Mins 3 Secs
    Avg. Time Online: 7 Mins 20 Secs
    Get this pile done! It should be on it's wheels by now!
    The OG HOISTWAGON
  12. #112
    Toxic River?
    Time Online: 4 Mths 2 Wks 14 Hrs 50 Mins 32 Secs
    Measuring sucks! At least you only have them tacked on and not fully welded in.
    Nice welds... jealous!
  13. #113
    Sep 2002
    Redacted
    Quote Originally Posted by Impact View Post
    If you are ever in the GTA and want to come learn I don't mind...coffee required!
    ---------- Post added at 09:12 PM ---------- Previous post was at 09:10 PM ----------
    Quote Originally Posted by MattK View Post
    What bank do you think I've robbed?
  14. #114
    Quote Originally Posted by Punisher-One View Post
    Pick one... or three.
  15. #115
    Sep 2002
    Redacted
    Progressed well today.
    Took off the spring buckets and re-measured everything. Got them sitting exactly where I need them to be now.
    Threw the axle back under the truck and connected up the rear arms. Will need to buy more tube and re-do the arms (adding about 2" per arm in length). Lesson learned...PVC pipe to mock links up is your bestest friend! Take a tip from me!
    Measured the angle for the upper mounts and got them on as well.
    Ordered up my ford shock towers for outboarding my rear shocks. Should be in tomorrow.
    Pics!
    Upper control arm mounts all burned on:
    Spring buckets and lower control arm mounts burned on:
    Me at work:
    So tomorrow I'll cut my uppers to length and tack the tube adapters in. I am hoping to get my frame-side coil buckets done tomorrow as well and get them tacked on as well. I'll also hit the Ford dealer to pick up my shock mounts and see what needs to be finessed there.
  16. #116
    Sep 2002
    Redacted
    Uppers cut, tacked, and johnnied up!
    Rear all in and sitting at pretty much full bump if not a little higher.
    As you can see this is as high as the diff can go before the uppers touch the tub...
    A few pics of how the upper arms run...
    Last but not least....picked up the Ford towers for my rear outboard shocks....$20/ea at the dealer!
    I will be trimming the bottoms off and frenching them into the frame so that little piece of the tub will be going away. Now I just need to figure out how to measure (yay...not) what size shocks I will need.
    So I am waiting on my upper TMR coil buckets to get done....missed out on the stock they had left after KOH. Also going to grab some square tube from TMR to make the axle-end of my shock mounts.
  17. #117
    Toxic River?
    Good progress!
    Referencing those pictures with the axle shoved up as high into the tub as possible can you please take a side shot of the lower control arm and measuring tape showing how much till they contact the frame?
  18. #118
    Sep 2002
    Redacted
    Sure thing. They are just as close I think.
  19. #119
    Time Online: 11 Hrs 45 Mins 48 Secs
    Looking good man. Like I said I will try to make it out there next block off and we can start digging into the front end. The ass end better be on tires by the time I get there
  20. #120
    Sep 2002
    Redacted
    Quote Originally Posted by TwE@k View Post
    If all goes well today it should be on it's own weight tonight....on jack stands but on it's own weight.
    Tires are a ways off....my rims are still on someone elses truck!
