Page 8 of 16 FirstFirst 12345678910111213141516 LastLast
Results 141 to 160 of 318
  1. #141
    Sep 2002
    Redacted
    Time Online: 4 Wks 1 Day 7 Hrs 29 Mins 15 Secs
    So this week off I got the GenRight tank mounted and in there.....since it was for an '03 and not for my '99 a little trimming of the tub was required.
    Welded up my custom TMR gussets for my spring buckets....really happy with how the boys made these!
    Then I stripped off the factory coil buckets in preparation for the TMR Customs coil-over towers and FOA coil overs.
    PAX ARMIS ACQUIRITUR
    Project Sandstorm Remix
  2. #142
    Coilovers? You cheater! Lol. Might have some lights in next week buddy.
  3. #143
    Sep 2002
    Redacted
    For the price I got them for....it's not worth the hassle of trying to jam a coil, a shock, a control arm mount, and a sway-bar mount on the short side of that 60. Just makes everything cleaner/easier for me.
    Sweet....not that the jeep is going anywhere that it needs lights
  4. #144
    Time Online: 11 Hrs 45 Mins 48 Secs
    The pic of the gussets frames my junk nicely.......good job V
  5. #145
    Sep 2002
    Redacted
    So more done this days off. Lots of painting done....some other minor work....waiting for parts on the front end at this point.
    Gave the 14bolt a nice shave....not a kit but it only cost me 1 sawzall blade 1 grinding disc and a cutoff wheel!
    I took it right down to the lowest bolt on the cover.
    Gained quite a bit of clearance and smoothed it all out!
    Painted the cover....desert camo and OD green!
    Painted the whole assembly and hubs
  6. #146
    Sep 2002
    Redacted
    Painted the pinion guard:
    Cleaned out the 33 year old pumpkin with a wire wheel:
    Finally I mocked and tacked the front TMR Customs 3 link mounts. The 2 links are on the drivers side.
    Big thanks to Tim and Mike at TMR Customs. Those are their stock 3-link brackets but the "c" portion is custom for my build. Due to the new frame sections my frame in those areas is a little taller and a little wider than normal. I had to grind and weld some extensions on to the rear brackets....Tim and Mike made these ones up special and they fit like a glove first time!
  7. #147
    Sep 2002
    Redacted
    So some photos of the recent progress are due.....I fully rebuilt the hubs on the 14bolt. All I need is to get the gears/locker installed and that puppy is ready to be under the rear end for good! Rebuilding them wasn't too much of a PITA really....actually....went a whole lot easier and smoother than I though...
    Apart:
    Two fully rebuilt 30 year old hubs:
    Pressed in the new studs with the new rotors...looking pretty shiny!!
    For fun I threw a set of light/mirror brackets onto the windshield.....I couldn't believe that all of those bolts came out without a fuss....I'm serious too...no problem at all...so odd....
    Then I squared up the front TMR 60 truss and tacked it on....
    ---------- Post added at 01:51 AM ---------- Previous post was at 01:49 AM ----------
    Forgot to add....I cleaned up the inside of the 14bolt's pumpkin with a wire wheel...did a pretty good job of getting the rust out.
    Until next time.....
  8. #148
    Looking good man. I will come by either this weekend or on Monday to help you out. It's that time of the year dude, we need to get this project rolling so you can show me where the hell I am supposed to take my truck. I have been kindly told that planter boxes are "not an appropriate place" to test out my disco button
  9. #149
    Sep 2002
    Redacted
    I'M BACK BABY!
  10. #150
  11. #151
Name:	300650d1332176841-ban-forum-member-who-posted-above-you-yo-dawg-i-head-you-got-banned-lol.jpg
  12. #152
    Sep 2002
    Redacted
    Back from the dead with many updates!!!!
    Since I got the BAN HAMMER for a month I did a lot of work....not on the road but still...progress has been made!!!
    Got my preciouses:
    Built my TMR front coilover mounts:
    Burned them on!
    Did up a cross brace:
    Made it removable with TMR flanges:
  13. #153
    Sep 2002
    Redacted
    Burned the trac-bar mount home....holy crap was it ever a PITA....front TJ frame is curved and fitting it takes a lot of grinding and fitting times 10.....buuuut I did it!
    Coilovers sitting pretty:
    Axle side coilover mounts:
    Burned the truss home:
    Burned the axle side trac-bar mount home:
  14. #154
    Sep 2002
    Redacted
    Control arm mounts in.....welds don't look pretty....bad angle to get in there on the drivers side...late model 60s tight....but I'm not worried about them....
    Upper on top of truss locked down:
    Frame side control arm mounts in:
  15. #155
    Sep 2002
    Redacted
    TMR tube adapters in:
    Trac-bar johnny welded up:
    Old transfercase kicked to the curb and new transmission seal!
    Switches wired:
  16. #156
    Sep 2002
    Redacted
    14bolt 5.38s and spool in:
    Brake lines bent up for the 14bolt:
    TMR trick-tabs to hold the lines down and out of the way:
    Caliper brackets painted and mounted....mounted a caliper up just for show!
    That's where I'm at!
    Waiting for my steering...got it ordered from West Texas Offroad....they were incredibly helpful on the phone too!
    Waiting on my front 60 gears...Ski at CTMotorsports is doing those like he did the 14bolt! Great work!
    Going to hopefully get the rear under this thing this set of days off.....fingers crossed!
  17. #157
    Toxic River?
    Time Online: 4 Mths 2 Wks 14 Hrs 50 Mins 32 Secs
    Thank god for an update... I had given up hope!
    Is this TMR's TJ?
    Did you cycle the suspension with the coilovers in before burning the mounts on?
    Did your 14B truss link mounts come with the dimple connector pieces?\
    What's the transfercase of choice?
  18. #158
    Ottawa Valley
    Time Online: 2 Mths 4 Wks 21 Hrs 47 Mins 3 Secs
    Avg. Time Online: 7 Mins 20 Secs
    Why isn't it done yet?
    The OG HOISTWAGON
  19. #159
    Sep 2002
    Redacted
    Quote Originally Posted by Impact View Post
    Is this TMR's TJ?
    - Yeah I cycled the front suspension totally with everything tacked in. I had to make a few changes to where the trac bar was mounted but the coilover towers were spot on.
    - If you are referring to the upper link mounts (with the dimpled backing plate) I bought the plates separately but the top mounting tabs did come with the truss.
    - Transfercase is going to be another 231 but I got it for a screaming deal complete with SYE and CV rear shaft.
    - If it was TMRs TJ not only would it be done by now but the welds would be a whole lot better looking....I may start drinking the water up there and see if it helps my welding...something must make Tim such an artist with the MIG.
  20. #160
    Quote Originally Posted by MattK View Post
    he's been spit shining the frame again hoping the rust will go away.
