Results 1 to 18 of 18
Thread: WJ 4.7 issues...
    Cambridge
    Flirty
    Time Online: 3 Wks 4 Days 18 Hrs 55 Mins 45 Secs
    Avg. Time Online: 2 Mins 7 Secs
    WJ 4.7 issues...
    hey everyone,
    i have a 99 WJ that feels like is is running on 2 cylinders... coil packs all test good for continuity and plugs all have power to them but looks like some plugs are not firing (all 8 are brand new)
    heads are good, gaskets are good, new rod and main bearings just put in...
    any ideas as to why it is all of a sudden running like crap??
    any help would be GREATLY appreciated!!
    thanks
    Time Online: 2 Mths 4 Days 13 Hrs 41 Mins 27 Secs
    Avg. Time Online: 5 Mins 19 Secs
    Did you do a Compression Check...
    Cambridge
    Flirty
    heading out to do that now...
    Oct 2009
    Kitchener, ON, Canada
    Time Online: 2 Days 7 Hrs 19 Secs
    Avg. Time Online: 11 Secs
    Could also be a crank position sensor as it would possibly not tell the computer proper times to fire the plugs. i know mine was starting and running kinda crappy until I changed it and runs great now. This is assuming it is mechanically good to go.
    Courtice
    Time Online: 1 Wk 2 Days 12 Hrs 38 Mins 53 Secs
    Avg. Time Online: 47 Secs
    Swap the coils. From the ones that are firing with one that isnt.
    Quick easy test to do.
    4.7s and 3.87s eat coils for breakfast.
    Cambridge
    Flirty
    just did a compression test... who wants to come help me push thing into the lake out back??
    just plained the heads to make sure they were not warped since when i bought it, it had a blown gasket. full top end gasket kit put in...
    not sure i have the patience or time for tearing this thing down to find out the issue
    Feb 2007
    oshawa
    Time Online: 3 Wks 1 Day 8 Hrs 13 Mins 17 Secs
    Avg. Time Online: 1 Min 50 Secs
    so whats the result of the comp test
    rockin the 95 xj custom 4inch lift and 285/75/16 bfg mud terrain km2 and bds discos R.I.P
    98 xj 4.0L 5spd 4.5" zone lift and m/t sidebiters looking for 33s
    Cambridge
    Flirty
    was between 125 and 140.... except for the second cylinder back on the passenger side.
    Feb 2007
    oshawa
    is there any tracing or coolent on the plug for that cylender
    Cambridge
    Flirty
    just black from not firing it looks like.
    Feb 2007
    oshawa
    what was the comp of that cylander
    Cambridge
    Flirty
    a big fat ZERO :-/
    Feb 2007
    oshawa
    thats wierd there should be at lest somthing
    i would pull the head
    Cambridge
    Flirty
    took the valve cover off today... busted valve spring... FACK!!
    anyone have any luck removing the springs without removing the head?
    anyone want a case of beer to fix it while i stand behind/drink a beer and cheer you on?? lol
    Feb 2007
    oshawa
    make sur the valves are close fill the cylander with air pressure and get an oncar valve spring installer
    like this http://shop.advanceautoparts.com/web...21-177716954-2
    Cambridge
    Flirty
    thanks for the info blown85xj! no bite on the install for beer though, eh?? haha
    rockwood
    Time Online: 3 Wks 6 Hrs 1 Min 57 Secs
    Avg. Time Online: 1 Min 45 Secs
    4.7 are a finniky motor! had one started to trow timming codes then it blew a gasket found a used on and it whent 3 moths! sold it and bought a 99 with a 4.0 in it year and a half ago the motor is now got a bad rod knock.... stroker time!
    Cambridge
    Flirty
    Well, fixed the valve spring. Up and running again!
    Has a rough idle but no codes... Any ideas??
