Results 1 to 12 of 12
Thread: 83 nighthawk 650
    Jul 2011
    Orangeville, ON
    Time Online: 6 Days 16 Hrs 14 Mins 31 Secs
    Avg. Time Online: 32 Secs
    83 nighthawk 650
    So I'm about to pick up this bike off a teacher at my school, just wondering if anyone else has had experience with this particular bike. It has sat for 13 years but just rebuilts carbs and she fires right up. Needs new tires battery and fork seals for sure, is thier anything else I should look out for? Only has 26xxx kms. Cosmetically this bike is in great shape tell me what yas think!...and yes I am a newb to the bike world.
    Apr 2011
    Etobicoke
    Time Online: 1 Mth 22 Hrs 49 Mins 48 Secs
    Avg. Time Online: 2 Mins 32 Secs
    I'm not a bike guy, but I had two of them...83 and 84. never had a problem with either one.
    The four carb set-up likes the gas more than other bilkes that size, but who cares when you go 500km on $8?
    The 83 was my first motorcycle when I was 16, and it was easy to ride.
    Wave Killen' 4dr
    OF4WD Member # 6449
    Jul 2011
    Orangeville, ON
    I'm seventeen, looking to pick it up to commute between orangeville and Ottawa 2-5 times a month for the summer gettin a steal of a deal but it's sat for 13 years so it's needin some tlc, just tryinto figure what I'm gettin myself into
    mugsy's Avatar
    mugsy is offline Mugsy the Animal Steel-Moderator
    May 2005
    hamilton
    Time Online: 4 Mths 1 Wk 6 Days 8 Hrs 4 Mins 49 Secs
    Avg. Time Online: 10 Mins 57 Secs
    check, all fluids before firing it up, cables, shocks, brakes.....and tire pressure before u ride it....also every time u ride it check throttle return, brakes and tires...Ya I know i said everytime but its a good habit, more riders go down because of those 3 things.
    my wife (RIP) hated my jeep too so i ran her over with it and now we are both happier (me and the jeep)
    RETREAD #13
    04 Wrangler, 4" lift and 33's
    edmonton alberta
    because it sat for so long just start it up and let it get to full temp shut it down and full cool ,do this for a few days and see if any seals start cracking and if you plan on riding it, short tips for a bit untill your sure that it's safe and reliable. you don't want to end up on your head at 80km cause the motor or tranny locked up ..
    Etobicoke
    Time Online: 5 Mths 1 Wk 2 Days 19 Hrs 18 Mins 26 Secs
    Avg. Time Online: 13 Mins 8 Secs
    Lubricate your cables too, drain and bleed your hydraulic clutch/ brake system and check that the calipers move freely and the lines are in good shape.
    check out this website lots of good info,links,pdf manual
    http://www.hondanighthawks.net/650Article.htm
    Jul 2011
    Orangeville, ON
    I've personally flushed/ changed any fluids on it except the highbeam fluid...hehe... I know it needs new tires and rear shocks, engine is sound, gonna change all fluids again in 500 km just cause I know the tranny is kinda sticky, only thing else I can think of is bushings might be going and a friend said the chain driven crank balancer tends to slacken off? Anyway thanks for the replies will let yas know how it goes when I get er home
    beamsville
    Here is the the 1982 big brother i found last summer 5200K ,cleaned the carbs and it runs,The last time it was plated was in 1989
    Nov 2011
    Brantford Area
    Time Online: 2 Wks 2 Days 4 Hrs 30 Mins 41 Secs
    Avg. Time Online: 1 Min 19 Secs
    The CB series of Hondas are pretty good bikes. Iv had a few myself, CB400T, CB550, CB750, and the ultimate in the CB Series... 1979 CBX SS in Candy Red. Nothing like an 1100 cc inline 6 cyl motorcycle. Now I ride a 2009 HD Rocker. So.. Im biased.
    My Wife, By Boy
    My Bike, My Jeep, and My VW
    All the loves of my life.
    binbrook ont.
    Time Online: 3 Days 21 Hrs 13 Mins 36 Secs
    Avg. Time Online: 19 Secs
    there was a top ten bike list on a bike show and a cb 750 was number two the reason it was not number one is that it ran too smooth. there test bike needed a battery and fluid change. it sat for 25 years! not bad 2nd place for a bike that sat that long. change your brake fluids ,and make sure your calipers dont stick!!{had a front brake seize up at 50 not fun} good luck and happy riding.
    Bryn; 86 chev k5 blazer
    Aug 2007
    ElliotLake, Ontario home of the bugs
    Time Online: 1 Mth 1 Wk 6 Days 19 Hrs 52 Mins 46 Secs
    Avg. Time Online: 3 Mins 36 Secs
    was my first bike.....awesome to ride smooth as silk..save the shaft bounce......used to be able to get the front up and ride for ever....but don't do that
    97 tj 4" lift rollin on 33"trXus m/t
    YOUR AN APPLE ( annoyingorange.com)
    "the purpose of life is to end" (agent smith)
    "to crush your enemies, see them driven before you and to hear the lamentation of their women" (Conan the barbarian)
    Jul 2011
    Orangeville, ON
    well here's a pic of er
