Results 1 to 20 of 23
Thread: T-case mounting thoughts?
    Rebuilt my doubler and t-case and want to clean up the mounting crossmember.
    350sbc - TH350 - advanced adapter -231/d300 doubler
    So far I'm using polly oem style motor mounts and a single leaf spring bushing mount on the back of the D300 with a TMR kit and solid crossmember. Should I also use the AA mounting pad with a solid crossmember and spring bushing?
    Is a second tranny mount too many capture points and is the 3 bolts on the d300 tail housing enough for a single mount?
    Sent from my iPhone, excuse the autocorrect.
    May 2004
    Windsor On.
    Time Online: 1 Mth 2 Wks 6 Days 2 Hrs 24 Mins 32 Secs
    I don't think you need more mounts, The cases should let you know via leakage if its stressed. I had a similar setup in my XJ AW4-231-D300 and only used the OE mount and is seemed adequate. I personally didnt care for the D300 tailshaft mount, I had tried one,homemade not TMR and it was a hassle to keep the output housing fasteners tight. On the other hand it might be nice to have options to remove one tranny mount or the other for servicablitiy ie remove D300 without letting down rest of driveline. I am a huge fan of "tight" motor and trans mounts as I like to feel the NVH!
    The brave man may not live long but the cautious man never lives at all.
    I had a leakage problem and loose bolts when I had the mount on the AA adapter. I had to tighten the adapter to the tranny after every run. Maybe I just need more locktite? And the crossmember got in the way of the front driveshaft and made it to flexible.
    Aug 2004
    Woodstock
    Time Online: 6 Days 13 Hrs 14 Mins 3 Secs
    Avg. Time Online: 32 Secs
    fixed
    fixed
    Half the fire wall/part of the hood & front grill its all CJ
    Oct 2012
    Windsor,On
    Avg. Time Online: 24 Mins 50 Secs
    Yah about locktite you gotta make sure there is NO oil residue on any threads inside or the bolts. carb cleaner then brakeclean
    Oct 2012
    Windsor,On
    send pics . I have a 241c in my rig Im building. I wanted to keep the crossmember away from the f drive shaft. so what I did was hard mount the tc to a piece of 2x2 and welded a polly bushing on the pass side and had a big U bent up to go OVER the front tc flange and then a piece of 2x2 and another polly bushing. This way the drive shaft can drop all it wants without hittin the cross member The U I used is 1/2 thick x3'wide with 7' dia.If i can get a pic to load Ill post it up
    whats with the pics? they are from my flip kit build. LOL
    Quote Originally Posted by ditchpig View Post
    Tranny & Tcase mount.
    I don't know what's funnier...
    That your pics got jacked on the very forum they were originally posted on, or the fact that they are posted as being a tranny and tcase mount when they are actually a flip shifter housing.
    ROTFFLMMFAO
    Oct 2012
    Windsor,On
    which pics are you refering to the originals or my upside down U cross member? as far as Im aware of the "u" is my idea.
    ^LMAO.... read my post.... then look at the pictures....
    You added pictures after I posted my question....
    you may find your answer.
    and BTW.... I highly doubt that the upside down "U" was initially your idea.
    Oct 2012
    Windsor,On
    well I dont need patent rights or anything. I just came up with it one night while working with my son. I used to hang out on greatlakes4x4 and no one there suggested the setup when I didnt know what to build. I still dont get what your talking about,but Im not one to start shiy if its going in that direction I dont know you
    He is not trying to start shit.
    As for the pics thing...He is trying to say that post number 4 posted by ditchpig is using pics from Jak Flash's Dana300 flip kit build up thread.
    I find it amusing that they are posted with no reference of where they came from. Can be mistaken as being ditchpig's pics if you don't know where they are from.
    I find it even more amusing that they are passed off as being a trans and tcase mount when they are actually a shifter housing and shifter bushings for a flipped Dana300. Both pics show parts that were 100% fabricated by Jak Flash. He didn't come up with the idea, but he did make the parts.
    As for the U. What he is saying is that it has been done before. It works well. I have something similar under mine.
    Oct 2012
    Windsor,On
    thanks for taking the time to sort things out
    He's got it there. I'm just busting balls.... Just ask thing aka timmay. I bust his balls too...
    Jeff...
    Those are two pics that went missing in my flip kit thread a year ago. Wtf is going on with the pictures around here?
    Also wanted to mention that this thread is almost a year with no posts. That's funny shit.
    No problem...just a heads up...
    this is ball busting/grinding the gears/good natured ribbing/etc.
    this means somebody is not so happy
    There is a difference
    Jeff...
    OH FAWK...LOL...now I feel bad for calling out ditchpig...sorry ditchpig...I forgot about the pics going all retarded when the site crashed last year...it is very likely that you had posted other pics and for some reason (we still aren't sure exactly what happened) they got hooped and replaced with other pics...in this case they would have been replaced with the pics seen above (Jak Flash's pics)...
    Want some good entertainment with fawked pics...spend a few days browsing Curt's thread...all hardcore building, and a guy in a canoe...LMAO...
    Aug 2004
    Woodstock
    Dont know what happened to the original pics I posted but deleted the wrong ones and attached the right ones.
    Found pics have changed again this morning after putting in the right ones last night.???
    Oct 2012
    Windsor,On
    Im new here so I dont know all the peoples characters yet LOL
    Time Online: 10 Mths 3 Wks 5 Days 38 Mins 51 Secs
    All the interesting people here are assholes. I think that covers it.
    Edit your post to eliminate the pics. Then change the name of the file, re-upload, and edit your post to link them in again.
    hat is what was found to work for Jak Flash a while back to get his pics back in to his thread.
    I would agree...as long as you can take some punches you will do okay...you are welcome to throw some jabs too...for the most part, there is no harm meant.
    Fukc you!
