Thread: Dana 300 breakage
    Dana 300 breakage
    Anyone else here ever break their d300? What have you broke and what was the circumstance or root cause?
    I have a few spare d300s and am debating the value or need of HD outputs.
    So far I have cracked one cast iron case and broke a front output shaft at the splines. Both of those breakages have been caused by driveshaft issues.
    The case was cracked due do a front shaft the was a bit too long and was forced into the case and prying it off the tranny.
    The front output was the front yoke binding up while too much travel.
    Sent from my iPhone, excuse the autocorrect.
    Sep 2011
    East of Toronto
    Time Online: 3 Days 11 Hrs 40 Mins 13 Secs
    Avg. Time Online: 17 Secs
    I've seen one rear output break but that was also due to driveshaft bind (because of axle wrap...)
    Ya, I still can't justify an HD output shaft upgrade because I can't find any breakage due to simply being a weak shaft. Every break I've found has another cause that in turn broke the output. IF you keep the driveshaft from binding, bottoming out or getting hit the outputs can take some serious abuse.
    Jul 2005
    Orono, Ontario
    Time Online: 1 Mth 2 Days 18 Hrs 52 Mins 58 Secs
    Avg. Time Online: 2 Mins 41 Secs
    Broke 5 total, 3 in one weekend. All more or less power related.
    If you wheel you junk hard, go here!
    http://throttlehappy.invisionzone.com/
    Jun 2003
    Bowmanville
    Dead
    Time Online: 2 Wks 12 Hrs 45 Mins 27 Secs
    Quote Originally Posted by k5 View Post
    The output mainly broke because I said, "one more try". the way I fixed that was to build a torque arm.
    Wounds heal... Chicks dig scars...
    1984 CJ-8 Scrambler (Rust Free California Edition)
    2005 TJ Unlimited
    1946 Willys CJ-2a "Pa2niA" Featured in JPFreek (click me)
