Results 1 to 13 of 13
Thread: New alternator = FM frequency static. Why and how do I fix it?
    Oakville
    Time Online: 3 Wks 5 Days 5 Hrs 32 Mins 12 Secs
    Avg. Time Online: 2 Mins 9 Secs
    Car is a 2001 VW new beetle.
    Replaced the alternator in hopes to fix an unrelated charging issue. Radio was fine before the swap. Now there is a lot of static on most of the FM stations. It doesn't do it in sync with a rev or anything like that, its just in and out as you're driving along.
    Alternator is a re manufactured Valeo brand from a local alternator and starter shop.
    There is no specific ground off the alternator and the battery terminals are clean. No CELs on the dash and the electronics seem to be working as normal.
    It does have an aftermarket HU installed, but has been there the past 5 years without issue.
    Any ideas would be much appreciated.
    Thanks everyone.
    EDIT: RETARDED BRAIN FART...was thinking of different vehicle with my previous comments...new comments in my next post...
    Nov 2011
    St. Thomas
    Avg. Time Online: 33 Mins 32 Secs
    How is the reception with the engine off?
    "New" Beetles required a "powered antenna adapter" to convert from the European style antenna plug to the typical Motorola style used on aftermarket stereos in North America...
    Prior to this issue with reception, did you have any AM reception? If so, do you have any AM reception now?
    I ask this because the AM reception was greatly affected by using a non amplified antenna adapter, so much so, that you wouldn't even get static, it just sounded like dead air. If you had AM reception before and not now, then it is likely that the powered antenna adapter has crapped out...
    If you did not have AM reception prior to this issue, then it is possible they didn't use a powered antenna adapter when the radio was installed...in that case, it is possible the antenna adapter has come loose or is damaged in some way.
    Either way, the radio would have to come out to check/change the part.
    Oakville
    Thanks for the ideas fellas. I will check the above items and report back.
    beamsville
    Avg. Time Online: 5 Mins
    Do you have a bad spark plug wire? used to use a radio static condenser,when you ran solid copper plug wires was a old fix
    Oct 2012
    Windsor,On
    Avg. Time Online: 24 Mins 51 Secs
    maybe bad alternator have it checked for ac singnal from alternator. if its ok or no one will help go get a noise suppressor from a stereo shop
    Aug 2011
    Hamilton, Ontario
    Daring
    Time Online: 1 Mth 1 Wk 4 Days 12 Hrs 43 Mins 22 Secs
    Avg. Time Online: 3 Mins 25 Secs
    This might help...found it on the internets.
    You most likely have a ground problem or lack thereof.
    http://www.caraudio.com/forums/wirin...tor-whine.html
    93 YJ - Stock 2.5L inline 4, 4" Rough Country Lift, 1.5" Shackles, 33" BFG's, SYE yet to be installed, Raptor Liner Sprayed, CB, Stereo that goes BooM, Aussie locker front, XJ solid shafts, tube fenders by Tubular Metalworx, 8500lb winch, Garvin swing away tire carrier and clearly far too much time on my hands. No roof, no doors and two screaming kids in the back.
    Time Online: 10 Mths 3 Wks 5 Days 33 Mins 39 Secs
    Hopefully, the OP got this fixed up since he posted.........in January. :rolleyes:
    Dec 2009
    burlington
    Devilish
    Time Online: 1 Wk 3 Days 12 Hrs 36 Mins 41 Secs
    Avg. Time Online: 52 Secs
    it's a Beetle nothing moves fast not even replies move fast!
    Birdman
    ditch the bitch! let's go muddin'
    Oakville
    Just to add closure to this thread.
    Ended up replacing the aftermarket HU with the factory unit last winter. Signal interference on FM was gone. I'm assuming something in the aftermarket HU was f-ed up due to the faulty alternator.. I didn't feel like messing with it in -20 degree weather and since I don't drive it, the fiancee seemed fine with the stock radio.
    thats Two threads that Jeeper52 has bumped up almost a year stale in the last month. LMAO....
    Odessa
    Time Online: 3 Mths 2 Days 4 Hrs 14 Mins 38 Secs
    i noticed this aswell....
