Results 1 to 19 of 19
Thread: Fresh rebuilt 4.2/4.0L engine with fuel injection for sale.
    Jun 2003
    Bowmanville
    Dead
    Time Online: 2 Wks 12 Hrs 45 Mins 27 Secs
    Selling the engine in my CJ-8. Here are the specs...
    4.2L block:
    Completely rebuilt by Ajax Racing Engines.
    Balanced rotating assembly.
    bored .040" over
    double roller timing chain
    Comp Cam p/n 68-231-4
    Crower "cam saver" lifters p/n 66031x3-12
    approximatly 3,000km on it. 62 hours running time (installed hour meter when installed engine.)
    New oil pump, bearings etc etc etc
    4.0L head. Also fully rebuilt by Ajax Racing Engines with the same mileage and time on it.
    Fuel Injection system is basically the same system used in a 95 YJ H.O.
    Flow matched 19 lb Ford Mustang fuel injectors p/n F45w-A1B (have 2 spare injectors included as well)
    Wiring harness will be included. I will label every wire that needs to be connected. (easy install)
    fuel pump will be included. (E-2000)
    2 starters.
    Almost new Amsoil washable air filter.
    multiple spare sensors and a spare computer.
    Can be heard running since it is still in the Jeep for now. Will take a video before I pull it.
    Have used Amsoil full synthetic since the engine was broken in. It has never been abused only 3 mild trail rides (Camp NL 2011) and just normal street driving.
    What is not included is: Alternator, Power steering pump and York Compressor.
    Located in Bowmanville. pick up only since I dont have a truck to deliver. Will help load onto your truck or trailer.
    $1200 obo.
    Wounds heal... Chicks dig scars...
    1984 CJ-8 Scrambler (Rust Free California Edition)
    2005 TJ Unlimited
    1946 Willys CJ-2a "Pa2niA" Featured in JPFreek (click me)
    Jun 2003
    Bowmanville
    Dead
    forgot this
    Hesco Crank position sensor relocation kit (relocates CPS to harmonic balancer)
    Jun 2003
    Bowmanville
    Dead
    Here are a couple videos of the engine running. (both taken at 5:40 March 7th 2012)
    First video is of cold start up. Engine has not been started since January.
    http://youtu.be/aKf-wY-ujsE
    <iframe width="420" height="315" src="http://www.youtube.com/embed/aKf-wY-ujsE" frameborder="0" allowfullscreen></iframe>
    Second video is of engine at operating temperature.
    http://youtu.be/sJVe6MhvGSA
    <iframe width="420" height="315" src="http://www.youtube.com/embed/sJVe6MhvGSA" frameborder="0" allowfullscreen></iframe>
    feel free to ask any questions.
    Thanks.
    Check engine light is on. here are the codes and what they are and why they are causing the check engine light...
    12 - Battery disconnected within last 50 key one cycles. (battery was disconnected over winter)
    33 - A/C clutch relay circuit open (No A/C hooked up)
    34 - Speed control circuit problems (does not have cruise control)
    41 - generator field not switching properly (not using a stock alternator so computer doesn't see it)
    These check engine light codes do not affect anything on the engine running.
    Jun 2003
    Bowmanville
    Dead
    Bumped!!!
    Aug 2010
    Psychedelic
    Time Online: 2 Wks 14 Hrs 12 Mins 24 Secs
    Will this only fit a CJ? (I know anything can fit anywhere) but I mean could this engine be a "bolt in" for a 97 TJ?
    Jun 2003
    Bowmanville
    Dead
    I honestly dont know. As far as I know the 4.2/4.0L design hasnt really changed. I think the engine would bolt in, its the accessories I dont know about.
    Jun 2003
    Bowmanville
    Dead
    Engine is out of the Jeep and ready to go.
    Jun 2003
    Bowmanville
    Dead
    Engine and harness are ready to go. Harness is ready to install into another Jeep.
    Includes York compressor mount, alternator mount, power steering pump mount. (compressor, alternator and power steering pump not included)
    All wires are labeled for easy hook up;
    Battery +12v
    Igniton +12v
    Start +12v
    Ground
    Fuel Pump +12v
    Tachometer (not required to run)
    Check Engine light (not required to run)
    Parts and spares included.
    New starter (August 2011)
    spare starter with new solenoid
    spare solenoid
    E2000 fuel pump
    5x spare coils
    1x spare brand new, never installed O2 sensor
    2x spare Hesco crank position sensors
    1x spare stock XJ crank position sensor
    2x Hesco speed sensor (1 new and one spare)
    3x spare MAP sensors
    1x spare sensor thingy thats inside the distributor
    1x spare distributor
    spare set of spark plugs
    3x throttle bodys (2 with sensors, 1 stripped ready to be bored out)
    probably forgetting stuff, but it will be added to the box if I find anything.
    Not pictured, I will include a Factory service manual for the engine, along with my notes and diagrams for wiring harness.
    Complete package $1200 OBO.
    Low ballers will be signed up to multiple porn sites.
    This is ready to drop into any CJ/YJ or whatever.
    I'll give ya $5
    Jun 2003
    Bowmanville
    Dead
    Whats your email? Ill send you a reply.
    Sent from my Illudium Q-36 Explosive Space Modulator
    Jun 2003
    Bowmanville
    Dead
    Found these black decals that I had custom made... included!! (no background. Just like the stock decal on a YJ)
    Jun 2003
    Bowmanville
    Dead
    Bump...
    Jun 2003
    Bowmanville
    Dead
    BUMP!!
    Sep 2011
    Pefferlaw, ON
    Time Online: 1 Day 2 Hrs 27 Mins 54 Secs
    how much do you want for the 4.2 motor?
    Jun 2003
    Bowmanville
    Dead
    Quote Originally Posted by lamanna006 View Post
    first post... $1200 obo
    Jun 2012
    Ontario
    Time Online: 53 Mins 33 Secs
    I'm intrested pm me
    Jun 2012
    Ontario
    Quote Originally Posted by Redneck sedan View Post
    I'm intrested pm me
    I don't see anywhere to pm on here but u can call or text me 9053255372
    Jun 2003
    Bowmanville
    Dead
    Bump.
    Jun 2003
    Bowmanville
    Dead
    Sold!!!
