Results 1 to 18 of 18
Thread: Scarlett Build
    Guelph
    Bitchy
    Time Online: 3 Mths 2 Wks 1 Day 4 Hrs 13 Mins 21 Secs
    Avg. Time Online: 8 Mins 37 Secs
    Scarlett Build
    Scarlett - Red and scarred from a minor accident earlier in her life
    How she started:
    1997 Jeep TJ Flame Red
    4.0, 3-spd 32RH
    D30/35 3.07
    Until now ive mostly been taking her apart for minor work and am still currently buying parts for the final build to be ready for this wheelin' season.
    After lifting my ZJ last summer and not getting it quite trail ready (tcase etc) I gave into the urge of finally grabbing a TJ near the end of the season. I sold the ZJ to a good friend (nickyb33) and picked her up from Paul (JPhoenix) who ended up picking up the Cherokee that I was looking at as a parts vehicle lol. Things worked out well in the end for all parties and this is how she sat...
    Guelph coffee meet
    It wasn't long before I started hacking things away
    Got a little wet... cupping your hand over your eyes sure helps for those summer storms lol
    "Don't re-enact scenes from Platoon with Charlie Sheen"
    OF4WD # 6788
    Guelph
    Bitchy
    V1.0 of the suspension started with a 2" Rubicon Express Budget boost with extended shocks and an extra isolater
    Upper shock mounts, nothing a quick hit with the impact couldn't get out
    You always end up breaking something else while working.. new brake line along the way lol
    Guelph
    Bitchy
    A new soft top then followed from Rick (zombie - Thanks!!!)
    Next up was a set of rubicon side rails and some RE quick disconnects that I picked up relatively cheap
    Time passed and I found a pretty complete used lift for sale from Havoc... not long after it came to it's new home
    Tightened and rebuilt some of the arms
    Had to drill and tap a set screw on one of the arms that wouldn't budge with any type of allen head
    Set of Trail Head tube fenders waiting to go on...
    Guelph
    Bitchy
    I was finally ready to start installing the RE 3.5 kit
    When I went ahead to start removing the front track bar, I realized the original nut had been replaced and no matter what size wrench I used I couldn't get one on... The mount had previously been hacked up and I noticed a lump of weld on and below the nut. A little bit of grinding and some hitting with a chisel removed it and I was finally able to pull the axle end of the track bar out.
    The frame end was just cut out to avoid wasting time as the ball stud was just spinning freely
    More parts to go in
    RE adjustable track bar in
    Left front lower control arm cam bolt wouldn't budge, sawsmost took care of that one
    Guelph
    Bitchy
    Front bumper off and front end mostly done aside from the stainless braded extended lines
    Getting started on taking apart the rear
    Mmmmmmm... 3.07!
    How she sits on all 4's again
    Cold one after some work in the cold
    Guelph
    Bitchy
    I was bored one day and decided I had enough of the chrome. 3 little bolts and they're out for a quick sand and some Krylon Fusion black. I like how they turned out, i'd like them a bit more dull but they'll do for now
    The 8.8
    I've been talking about doing an 8.8 swap for a while now and have been reading about them for the last few months. Just so happened a deal on a 31 spline, disc brake, open carrier 8.8 from an Explorer popped up with some goodies and I couldn't resist. Thanks to Tony (onehoser) for meeting up to grab it!
    Some of the parts included:
    NEW in box - rotors, pads, seals, bearings
    NEW Ruff Stuff 3/8" diff cover
    NEW Ruff Stuff 8.8 leaf spring swap (sold to RDA cheers!)
    1310 flange adapter
    I got a chuckle out of the dude on the pads box.... sparkle sparkle
    Along the way Sara arranged a pickup for Kerry (Dirty Money) to grab a couple of goodies, a 40 sure does take up space in a tiny garage lol
    Bit of Kijiji and web wheeling from the garage
    Guelph
    Bitchy
    The 8.8 finally made it's way home to tear down and prep for bracketry
    cross pin out
    c-clips out
    Beefy
    A little rusty... dust shield and caliper brackets coming off
    Guelph
    Bitchy
    Another day means more acquired parts lol, thanks again Ryan (craveneh). Couple seats for Scarlett
    Neoprene covers for Sara's Wilma
    A D30 with gears matching the 8.8 and a 35 housing to possibly use some brackets from (budget build)
    Tonight's purchase was something I have been looking forward to buying and installing myself, having not done much of any work with a transfer case.
    New in box Advance Adapters 231 HD SYE:
    With the better weather fast approaching i'm really looking forward to some wrenching time in the garage and soon the driveway lol
    Things i'd like to do off the top of my head are:
    Setup the 8.8 with brackets, install new seals bearings and brakes - swap in
    Install SYE and get an XJ shaft shortened
    Buy a new set of shocks
    Rear track bar
    35's already here
    High amp alt swap
    ZJ V8 tie rod swap
    Repair 2 broken bolts in the frame from the skid plate
    Install tube fenders
    Swap seats
    Possibly bedline the inside of the tub
    Local friend has an already built TJ bumper for me, so eventually grab it and install
    Oct 2009
    The Shop
    Time Online: 1 Wk 2 Days 1 Hr 26 Mins 16 Secs
    Avg. Time Online: 44 Secs
    Subscribed. Shes starting to change quit a bit from when I saw it the day I picked up the wheels off of you. I will definitely try to make down to the guelph area in the Xj this season in hope to get the rigs dirty a bit with you !
    TIME TO KICK ASS AND CHEW BUBBLE GUM
    Mar 2010
    Time Online: 6 Mths 2 Wks 6 Days 10 Hrs 58 Mins 21 Secs
    Avg. Time Online: 16 Mins 26 Secs
    I will make sure you have plenty of s while you work , in my garage...making your Jeep better than both of mine.
    Osgoode area
    Time Online: 2 Wks 5 Days 6 Hrs 7 Mins 3 Secs
    Subscribed!! Love a good build with pics and details!... Looking good so far
    Jun 2011
    Vaughan
    Amazed
    Time Online: 2 Wks 2 Days 6 Hrs 16 Mins 20 Secs
    Quote Originally Posted by JeepGirl73 View Post
    I will make sure you have plenty of s while you work , in my gargage...making your Jeep better than both of mine.
    Now that is a luxury, I feed myself on cereal bars while working on my jeep lol.
    Looking good, will keep checking this post
    Obsessed about offroading and moved from Spain to Vaughan.
    Owner of a never ending YJ project: BUILD THREAD
    Winter beater 1998 Toyota 4Runner
    Owner of a Suzuki Sammy back in Spain
    www.d-limit.com
    ontario's west coast
    Avg. Time Online: 17 Mins 33 Secs
    whats this talk of s in trade of jeep work? where do i sign up?
    keep up with the detailed thread dude!
    subscribed.
    She's looking great, mang!
    Looks like you've got quite the project ahead of you, and you've already covered so much ground! I love what you've done with the old girl...
    Guelph
    Bitchy
    Well, no building related stuff today but there was some rubber swapping going on. How she looks with her 35's on... Can't wait to get the 8.8 in and tube fenders on
    Toronto OF4WD #3200
    Devilish
    Time Online: 1 Wk 11 Hrs 13 Mins 48 Secs
    Avg. Time Online: 36 Secs
    Build is lookin good!
    I'm glad to see your Tread Head fenders are just as rusty as mine!
    "You want that bolt loosened or can I break it?"
    Pit Boyz Rock'n it OLDSCHOOL
    Organizer of the KING OF THE SHIELD http://kingoftheshield.com/ Teaser Video
    SUPPORT LOCAL EVENTS, COME OUT AND COMPETE WITH YOUR RIG!
    Guelph
    Bitchy
    Got out to enjoy some more of this fine weather and bolted in my new seats to see how I like them...
    Verdict is....... they're great. Wouldn't fit someone much bigger than me though, but comfy and a good fit.
    Much better than those rainbow seats
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 15 Hrs 57 Mins 5 Secs
    Avg. Time Online: 38 Mins 56 Secs
    coming along real nice there troo! keep up the good work!
    WHAT WOULD MACGYVER DO?
Tags for this Thread
