Results 1 to 4 of 4
Thread: Adding Winch To Trailer
    Jul 2011
    Where you live
    Time Online: 2 Mths 6 Days 12 Hrs 41 Mins 4 Secs
    Avg. Time Online: 5 Mins 27 Secs
    Small list of parts and an evening at home.
    Winch
    Battery quick connects
    Battery cables
    Battery
    Battery tray
    Battery tie downs
    4" hitch for reciever on back of trailer
    3/4 tab with 1/2 hole
    Shackle
    Some 1/4 plate
    Ok, positioned winch on trailer in desired location, drilled holes through deck boards, removed deck boards, welded plate below deck boards and drilled holes to mount winch in position.
    Next up put battery tray into tool box on trailer and secured.
    Then turn reciever upside down, weld tab to top of reciever.
    This setup will alow me to pull a dead vehicle onto the trailer.
    Then insert the modified reciever with the tab and shackle, put my snatch block to shackle and pull vehicle off trailer.
    and there you have it.
    Will be adding a solar charger to outside of tool box to charge battery when not in use.
    Cheers,
    Vince
    Jul 2011
    Where you live
    Pics
    Attached Thumbnails Attached Thumbnails ImageUploadedByTapatalk1332381599.575331.jpg   ImageUploadedByTapatalk1332381628.521363.jpg   ImageUploadedByTapatalk1332381657.818763.jpg   ImageUploadedByTapatalk1332381671.306573.jpg   ImageUploadedByTapatalk1332381690.649981.jpg
    Jul 2011
    Where you live
    One more
    Attached Thumbnails Attached Thumbnails ImageUploadedByTapatalk1332381779.007315.jpg
    Odessa
    Avg. Time Online: 7 Mins 33 Secs
    i like it.... i really like the hitch idea for getting stuff off.... gonna have to remember this one!
