Thread: project WIKKED WILLY!!
    Mar 2012
    durham region
    Time Online: 12 Hrs 13 Mins 38 Secs
    People have been asking me to post some pics, and more info on my build so here it is...
    I am building a street legal full tube buggy , it is a home built frame 2x3 .150 wall 96" wheel base to run on 36's
    i got my suspension done this weekend made my own mounts to us YJ spings with scout axles
    everything is being mounted as low as posibe to improve my center of gravity Click image for larger version.
ID:	78904Click image for larger version.
ID:	78905Click image for larger version.
ID:	78906Click image for larger version.
    this things gunna be sick, keep the pictures n progress updates comin!
    somewhere
    Avg. Time Online: 14 Mins 58 Secs
    That thing is gonna look great on 36's.
    Nice project. I've been thinking of something like this for a long time.
    Mar 2012
    durham region
    progress wicked willy
    here are some pics from the weekend progress .. fabricated and installed suspension mounts, motor mounts, crossmember .. all my mounts are done trying to take the extra time to make things with good fit and finish Click image for larger version.
ID:	78935Click image for larger version.
ID:	78927Click image for larger version.
ID:	78928Click image for larger version.
ID:	78930Click image for larger version.
ID:	78929Click image for larger version.
ID:	78931Click image for larger version.
ID:	78932Click image for larger version.
ID:	78933Click image for larger version.
ID:	78934Click image for larger version.
    somewhere
    You may want to review that shackle mount and possibly push it further out. Once you get weight on those springs, they'll flatten out. The shackle will be at too much of an angle. Also if you shorten you shackles, the angle will only get worse.
    I have my fronts set for around 45 degrees... don't think I'd want anymore than that. My rear needs some work.
    Mar 2012
    durham region
    i got the shackes set at 8 deg with no load its to late to move i got a a ton of weld on then not even god could get them off with out destrorying them but i think it will be ok back of the truck should only be about 350 lbs per corner just a fuel cell and a tire (no room for bakseat drivers lol ) its gonna be alot of trial and error also in made the shackes a 5" pitch so i have room to grow or shrink dependeng on how it sits and performs the goal is once its done build a double triangulated 4 link out back for true 90deg departure angle but i dont have the cash flow to do everything the way i want to right no but i figure upgades will make good projects once its all done and i got nothing to do in the winter
