Results 1 to 20 of 22
Thread: Question: TJ extended E-brake cables
    Dec 2008
    Just North of Sudbury
    Relaxed
    Avg. Time Online: 20 Mins 34 Secs
    What have you guys been using (if anything) for longer E-Brake cables on a TJ.
    My Rubi 1 ton build is using '78 Eldorado brake/parkbrake calipers on rear wheels.
    I can get the TJ cable on there and in place....but gonna be too short now that its full width AND the cable is underslung on the axle instead of over the axle as in OEM rear disc.
    SO I am 99% sure I can make TJ (STYLE) PB Cables work....as long as I can find longer ones. The ones I have are 43" nub to nub....thinking and extra 12" would be plenty for flex.
    Any idea if LJ PB cables are longer or is the primary singe cable from the hand lever longer ?
    The axles came with Lokar cables and were junk....siezed, undersized in comparison to TJ, ends were all fawked up and not thinking I want to order over the border for something that i wasnt impressed with on first impressions.
    Many advance thanks....
    "Bite my Shiny Metal ass!"
    Retread #19
    May 2004
    Windsor On.
    Time Online: 1 Mth 2 Wks 6 Days 1 Hr 38 Mins 25 Secs
    Yes the LJ will fit and the e-brake cable is longer. I had an LJ rear swapped in to my 1997 Tj and the cables fit they were just longer. I never measured the difference but would estimate 10" longer
    The brave man may not live long but the cautious man never lives at all.
    Dec 2008
    Relaxed
    this is good info....THANKS!
    Have a bunch of feelers out there to physically measure differences.
    What year LJ rear axle was it? (might make a difference too)
    May 2004
    Windsor On.
    The variables in e brake cables are disk or drum and long or short wheelbase that's it
    Dec 2008
    Relaxed
    It appears that a Driver Side Unlimited Park Brake cable is 51-3/8" long (ABSCO # 61117). And from what I understand all LJ's were rear disc with internal PB shoes.
    As opposed to ABSCO 61115 or 61116 TJ Rubicon PB cables that are 41-3/8".
    Lengths are ABSCO catalog specs.
    Jul 2005
    Oakville
    Time Online: 1 Mth 2 Wks 6 Days 1 Hr 14 Mins 32 Secs
    LJ brake cables on my TJ (full-width and 5" stretch in the rear). Work great, but don't part numbers etc.
    Team Juggernaut - The Unstoppable Fire Dancer
    1999 TJ - RockCrusher 60's, Linked, 109" WB, Coilovers, 40" MT/R's, Atlas, PSC Cage, Armor.
    Down to one Jeep.....
    powered by - CT MOTORSPORTS
    Time Online: 1 Wk 3 Days 4 Hrs 21 Mins 22 Secs
    Avg. Time Online: 50 Secs
    Look into ZJ Grand Cherokee cables.
    I had them on my 98 with 4" lift when I swapped to disc brakes on the back (before I ditched the D35). They are lots longer then stock.
    Dec 2008
    Relaxed
    Quote Originally Posted by Dirty Money View Post
    Numbers are matching up and so are the length spec.
    So I grabbed 2 x 61117's to cable my e-brakes, they are about 10-1/2" longer than OEM TJ cables.
    Toxic River?
    Time Online: 4 Mths 2 Wks 14 Hrs 50 Mins 23 Secs
    Awesome info!
    Anybody out there running a stretched LJ and still using the factory cables?
    Osgoode area
    You said you can make it work... Are the eldorado calipers adaptable to the end hangers on TJ/LJ cables?
    I know what with the Ford (8.8), i ended up going with the M.O.R.E. E-brake cable kit but it was a costly affair IIR.
    Dec 2008
    Relaxed
    Quote Originally Posted by countryboy View Post
    I've already had the TJ cable ends on the Eldorado e-brake arms (at the calipers) - just a little file here n there I can get the square "eye" in and around the zigzag end.
    Will post pics later.
    Sep 2011
    windsor
    Time Online: 3 Days 17 Hrs 53 Mins
    Avg. Time Online: 18 Secs
    We're the arms for the caliper ( that the cable hooks to) a dealer only item? I'm having a hard time sourcing then
    Dec 2008
    Relaxed
    Quote Originally Posted by chormp View Post
    I know when I core-returned my Eldo calipers I had to swap over the e-brake arms...so not sure if they are available commercially.
    They wouldnt be hard to make (other than making the hex spline) to fit over the ebrake stud.
    ----Thinking piece of angle iron about 3 or 4" long drill a hole, file it out Hex to fit over the stud ---- notch in for the cable "eye" or bolt it direct....
    Nothing complicated or super hi-tech about those arms....(but sounds like i'm glad mine had them)
    Sep 2011
    windsor
    I didn't have any cores , and I was thinking the same thing, just fab something up
    Dec 2008
    Relaxed
    I'm in jeep build final stretch today...I'll snap a pic or two of what I have and how its all connected.
    Dec 2008
    Relaxed
    So as promised, here is how I used LJ (or TJ Unlimited) rear park brake cables WITH 78 Eldorado calipers on my 1 ton build
    Note the underslung parkbrake cable and simplistic design of the PBrake arm:
    Little bit of a bend in the arm...but not critical as far as I am concerned...(note the cable eye on axle)
    Need a notch to slip the inner cable through the eyelet once it is connected to the PB arm on the caliper"
    With a little bit of grinding / filing, this is how I got the TJ cable end onto the Eldorado arm (3 pics in series):
    Driver's side now just for kicks:
    cable routed up the handbrake primary cable:
    These dont need alot of tension to grab....works mint. Just adjusted by finger tight at the junction (primary cable) and holds good.
    I would NOT spend the money and time with the custom cables from LOKAR....save those for street machines. They seize and the unviversal cut to length crap is rinky-dink.
    Garson, Ontario
    Time Online: 5 Days 12 Hrs 52 Mins 11 Secs
    Avg. Time Online: 27 Secs
    Turned out good. Didn't even think to look this evening at that. Was too in aww at the rest of the rig.
    Sent from my BlackBerry 9800 using Tapatalk
    1998 Chevy K-1500
    Oct 2012
    Windsor,On
    Avg. Time Online: 24 Mins 51 Secs
    Anybody have access to those arms. Im in the same boat. If you find some on ebay I will buy them from you. I dont do computer stuff too good
    Dec 2008
    Relaxed
    make em....hardest part would be filing a hex for the stud
    Oct 2012
    Windsor,On
    I just checked Cardones site and they sell the callipers complete with all hardware. I emailed them and they said it comes as pictured (with the e brake arm)
    OF4WD #7392 88 Romeo
