Thread: Honda XL350
    Jul 2006
    Guelph
    Bitchy
    Time Online: 1 Wk 3 Days 14 Hrs 31 Mins 10 Secs
    Avg. Time Online: 52 Secs
    Honda XL350
    I would like to replace the sprockets on this bike and was wondering how the different sizes will affect it but there is very limited info on this bike. Its a 1985 and as it turns out they only made the 350R in 84 and 85 go figure.
    Depends what your after, if you want more bottom end you can go as big as you want on the back. But if you want more top end you are probably better off with the stock gears unless that 350R is way more powerful than I think. You won't have enough power to red-line it in top gear or even get up to speed.
    Sent from iThingy
    Jun 2007
    Lindsay. Ont. Canada
    Time Online: 3 Days 15 Hrs 2 Mins 41 Secs
    Avg. Time Online: 17 Secs
    You can change the front sprocket size one tooth at a time smaller. The ratio of change on front sproket is one tooth smaller on the front equals three teeth on the rear. Be carefull not to over gear the bike, you would run out of gearing for top end speed. I hope this helps. Cheers. Rusty Iron
    Sharon, Ont.
    Time Online: 2 Wks 6 Days 5 Hrs 56 Mins 47 Secs
    Avg. Time Online: 1 Min 39 Secs
    One tooth on the front of my xr650r made a huge difference. Start there.
    Jul 2006
    Guelph
    Bitchy
    What kind of difference did it do. So if I change the front can I leave the rear alone.
    Merrickville. on.
    Time Online: 2 Days 14 Hrs 47 Mins 9 Secs
    Avg. Time Online: 12 Secs
    the front sprocket change is the easiest, my KLR 650 responded well on the trail with a 1 tooth reduction in size...you can go up to 3 teeth smaller but you will see excessive chain wear...
    I wanted to get rid of the stumble in 2nd gear while crawling at low rpm in the tight stuff..
    Sharon, Ont.
    Down 1 tooth in the front gave me much easier slow-speed riding for tight trails.
    I didn't change the back, didn't even have to shorten the chain.
    Jul 2006
    Guelph
    Bitchy
    It sounds like going down 1 tooth in the front is what Im looking for, I would like the front end to come up easier than it does in first and second gear. This wont take away from the top end much will it.
    Colchester / Windsor
    Avg. Time Online: 3 Mins 6 Secs
    It is a ratio. Divide front sprocket by rear. That is the drive ratio. Now you can change either front or rear but the increase or decrease will be relative to the change in ratio.
    If you know the transmission final drive ratio you can calculate the rpm vs speed change (theoretical) which will be dependent on there being enough power to overcome wind restance and parasitic losses.
