Results 1 to 11 of 11
Thread: '05 TJ Keeps Blowing Fuses
    Mar 2012
    Kitchener, Ontario
    Time Online: 2 Days 3 Hrs 49 Mins 1 Sec
    Avg. Time Online: 10 Secs
    Hi all,
    Recently I installed a set of Hella 500s on my Jeep TJ using the factory wiring and switch. Everything worked great...for one day until I suddenly didn't have any interior lights or tail lights and front marker lights. For some reason as soon as I turn on the headlight switch one notch, fuse number one in the fuse box (behind the glove box) blows instantly. I've been through about 6 fuses trying different things.
    The low beams, high beams, turn signals, four ways, brake lights, dome light and Hellas work(ed) fine. I've since disconnected the Hellas. I'm guessing it's a short and I've been trying to find it, but haven't had any luck. Anyone have any advice or some guidance to help me find the problem?
    edmonton alberta
    Time Online: 5 Mths 6 Days 18 Mins 19 Secs
    Avg. Time Online: 12 Mins 49 Secs
    there pulling to much power through the factroy set up i've seen guys on here using the light wire to triger a relay to power stronger lights... i set up a tj with cheap flood lights and found the wire was getting very warm ...
    Mar 2012
    Kitchener, Ontario
    At this point I cannot be certain that the Hellas are the problem as they have been disconnected and the problem remains. I think they are also on a separate circuit and fuse.
    Jul 2012
    Petawawa ON
    Time Online: 13 Hrs 44 Mins 14 Secs
    Avg. Time Online: 2 Secs
    Sound like a ground problem
    Avg. Time Online: 13 Mins 6 Secs
    Could be the switch as well.
    If you want to test you can borrow one from a CJ, YJ or TJ. I believe they are all the same. I'm using a CJ in my TJ.
    Had a similar problem. Dimmer was shorting out.
    Good luck
    Avg. Time Online: 28 Mins 55 Secs
    have you changed anything else during this time? even something as simple as a taillight bulb? anything?
    Mar 2012
    Kitchener, Ontario
    My TJ never had the fog light switch on the multi-function switch. I swapped with a friend of mine who's switch had the fog option. I've since put my old switch in and had the same result. The only other thing that has changed is the addition of a fog light relay.
    edmonton alberta
    are these setup as headlights or fog light ?
    Mar 2012
    Kitchener, Ontario
    I've found the problem. On Wednesday when I went for a drive I folded the rear seat down and in doing so carelessly pinched the trailer wiring. Now I'm off to rewire the Hellas.
    Oct 2011
    Time Online: 3 Wks 5 Hrs 12 Mins 23 Secs
    Avg. Time Online: 1 Min 44 Secs
    Great news and thanks for posting your resolution.
    Jul 2012
    Petawawa ON
    Great news
    2008 jeep jk sahara
